Question about Ricoh Office Equipment & Supplies
Service call sc542
No reday to copy his no soppated in zerox service call sc542
  • Ricoh Expert
  • 393 Answers
Its a hot section error, not a good one, to reset push in order, clear modes(yellow), 1, 0, 7, hold stop/clear for 5 seconds, if it comes right back service needed. -Carl
Posted on Apr 21, 2014
Gestetner 2212 copier Service Code SC542 I"ve
In your machine (model) you have to enter in SP mode to reset your error code.
Try this:
Yellow key.
1-0-7 on the key pad
Red key at least 3 sec.
Press "copy sp"
On the key pad press 5 810 and #.
Press execute
Exit all the way out.
Turn the machine off and on.
Feb 28, 2011 | Gestetner 2212 Digital Imaging System...
SC542 on Ricoh Aficio 1035 - I replaced both thermistors with new ones. I did the service code thing yellow button 1,0,7 then red and hold and shut the machine down. It copied for a little while and the...
You only change the thermistors????
What about the hot roller???? If there is crusted toner in the hot roller the thermistor cant read the temperature. Also see if the thermistor are in good position (they have to touch the surface of the drum).
I advise you to also check the thermostats and the fusing lamp (see if they have continuity)
Feb 24, 2011 | Ricoh Aficio 1035 Copier
SAvin error code Sc542 need to reset
press clear mode once- its a yellow button
pres 107 clear/stop and hold for a while untill you see the screen changes to copy sp mode. this is the machines service program mode.
press copy sp on screen and off and on the machine.
it should reset the code. if not email me on ronils_singh@yahoo.com.au. i am a Ricoh techinician
Sep 30, 2010 | Savin 8035e Copier
Ricoh 1045 only one copy printed then error code sc 342 will seen
Hi, there's no sc342 listed in the service manual, and I've never seen that code in years working on these machines. Are you sure it's not a different code, like sc542?
Sep 14, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
Sc 542
SC 542 is a fuser code that may need resetting. and this should be only done by an qualifyed service representitive as it requiers going into service mode and going into copy sp 5-810 and having it reset or if this does not work you may need a new fuser unit! Again service mode will need to be entered to reset the SC542 as this is a safty feature built in to the copier to keep it from ferther damage
Jan 13, 2009 | Ricoh Aficio AP3800C Laser Printer
Printing problem
Have you tried changing the cartridge or refilling the black and colored ink cartridges?
Jul 25, 2008 | HP DeskJet F380 All-In-One Printer
SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Feb 19, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
201 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
