Question about KitchenAid KERS807SSS Electric Kitchen Range
Oven shuts down while baking
When I start the oven in bake mode and set the temperature, the oven heats up to the set temperature but then it shuts down. The temperature setting on the front panel shows still shows the set temperature making me think the oven is baking but the heating has stopped and the oven is cooling off.
    Problem Solver:
  • 15 Answers
Thermostat my be brokenit thinks its hot so it shuts the heat off....
Posted on Apr 21, 2014
catriver
  • 878 Answers
SOURCE: Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Posted on Sep 07, 2006
SOURCE: KGST307 Gas Kitchen Range: gas range will not heat up when using Bake setting...
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
  • 23 Answers
SOURCE: Set the oven on clean before I went to bed. this
REad owners instructions. If all else fails, completely disconnect power for 45 seconds
(breaker will do), and try again.
Posted on Dec 18, 2010
TheMobilian
  • 8220 Answers
SOURCE: My Kitchen Aid Superba oven will not heat up. As
That sounds like a bad oven sensor. I would check that sensor for short or open.themobilian_850.jpgthemobilian_851.jpgthemobilian_852.jpg
Error codes and service manuals posted HERE
Posted on Jan 12, 2011
  • 180 Answers
SOURCE: The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Posted on Jan 30, 2011
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Why is my oven burning baked goods on the outside but still raw on the inside, when baking at the correct temperature setting?
Sounds like you need to set your thermostat as its not reading properly. Ours has a little screw on the side of the thermostat and I use an oven thermometer to make sure the heat is right. Ours was twenty five degrees out.
Dec 16, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Frigidaire range model #fgfl67dcf needs to be calabrated, too hot for setting
OVEN CALIBRATION Set the electronic oven control for normal baking at 350°F. Obtain an average oven temperature after a minimum of 5 cycles. Press CANCEL or CLEAR to end bake mode. TEMPERATURE ADJUSTMENT 1. Set EOC to bake at 550°F. 2. Within 5 seconds of setting 550°F, press and hold the bake pad for approximately 15 seconds until a single beep is heard (longer may cause F11 shorted keypad alarm). 3. Calibration offset should appear in the display. 4. Use the slew keys to adjust the oven temperature up or down 35°F in 5°F increments. 5. Once the desired (-35° to 35°) offset has been applied, press CANCEL or CLEAR. Note: Changing calibration affects both Speed Bake and normal bake modes. The adjustments made will not change the self-cleaning temperature.
Jun 18, 2009 | Kitchen Ranges
How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Mar 11, 2009 | Electrolux Kitchen Ranges
INSTRUCTION BOOKLET
Chances are that both elements should energize when starting up in bake mode. Since bake is by the very nature of the principle "constant heat" then the job of the control on the unit is to maintain an stable temperature for a specific period of time. Sooo... when starting up, both elements would be available to quickly raise the temperature. Once that temperature is reached then the bottom element would be all that is required to maintain the set temperature. Watch the elements for a period of time, until the "bake" temp is met and see if the bottom element is the only one energizing for the remainder of the time alloted.
Mar 27, 2008 | Kitchen Appliances - Others
KitchenAid KERS807SSS Electric Kitchen Range Logo
213 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
