Cmos setup not save - Computers & Internet
    President:
  • 987 Answers
Your cmos battery needs to be replaced..
Posted on Jun 19, 2009
Pxe-61 media test failure.check cable pxe-mof: existing pxe rom.loading drmk v8.00
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard drive.
Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
If your CMOS Setup has an option to boot from the LAN disable this option.
If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
Then try re-booting and tapping the f12 key which should start up a diagnostics page
Mar 06, 2014 | Dell Vostro 3700 Laptop Computer PC...
Aspire 3690
  1. Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
  2. If your CMOS Setup has an option to boot from the LAN disable this option.
  3. If you have changed any CMOS settings, make sure to save and reboot the computer.
Finally, if none of the above suggestions resolve this error go through the Invalid or Non System Disk error troubleshooting steps, which is related to this error message.
Dec 17, 2013 | Acer Aspire Computers & Internet
Bios not save
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Bios setting are saved in cmos batteries
make cmos battery has charge and is not loose
cmos battery images
http://www.bing.com/images/search?q=cmos+battery+images&qpvt=cmos+battery+images&FORM=IGRE
hope this helps
Oct 11, 2012 | Computers & Internet
Reset CMOS on IBM 2847
  1. cmossave.jpgEnter CMOS setup.
  2. In CMOS setup look for an option to reset the CMOS values to the default setting or an option to load the fail-safe defaults. With many CMOS setup screens there will be a function key to do this; for example, the F5, F6, F9, F11, or F12 key like shown in the picture to the right. Other setups may actually list an option that you can arrow over to using the arrow keys and press Enter.
  3. When found and selected you'll likely be asked if you're sure you wish to load the defaults press Y for yes or arrow to the yes option.
  4. Once the default values have been set make sure to Save and Exit and not just exit.
May 14, 2012 | IBM Computers & Internet
How can i remove setup password ?
If you short the CMOS jumper on the motherboard , you can reset the setup password . Find the CMOS jumper near to the CMOS battery . If you can't find the jumper , just remove the CMOS battery and smps power cord . Wait 3 min and re insert the battery . Now check it will not ask setup password .
Thanks
Nov 28, 2011 | IBM NetVista PC Desktop
Laptop wont start
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard disk drive.
  1. Verify your boot options are properly set in CMOS setup. I recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
If this fixes the problem but it reoccurs again later you main need a new cmos battery. Or keep your battery always slightly charged.
Nov 16, 2011 | Toshiba Computers & Internet
What are the implications of changing the cmos battery without saving the cmos data? what will happen when i restart with the new battery? can I download a set of default cmos data?
your computer should have a default setting for your cmos you will need to go into the setup screen of computer using a f10 or f-12 button usually at startup. when you boot your computer it should tell you what f buttoin to hit. once in the setup go to cmos default and click it then you should have to answer yes and then save and exit.
Apr 24, 2011 | HP xw8200 PC Desktop
I have a dell studio 1555. I did some thing with CMOS screen and I cannot start up WinXP afterward, a continuous reboot with dump screen (blue screen). Any solution ? Thanks
This is problem with your CMOS setup.
Go to CMOS setup in that find your hard disk in that that change your hard disk mode from SATA to IDE save changes than ok
Sep 25, 2010 | Computers & Internet
My computer won't start up and my mouse and keyboard are not working. Do I need to replace my CMOS Battery?
Yes turn off your computer and replace the Cmos battery. It seems that your keyboard and mouse is connected into the usb port of your computer, the usb function in the Cmos setup is disabled that's why your keyboard and mouse is not working. Upon checking the Cmos setup enabled the usb function and save the changes and restart the computer to take effect.
Feb 08, 2010 | Computers & Internet
When I turn my computer on, I get an istant error message: CMOS setttings error. Any idea what to do?
I THINK YOUR MOTHERBOARD BATTERY MAY BE DAMAGED OR DOWN. YOU HAVE TO REPALCE THE BATTERY AND TRY AGAIN TO START THE PC.
Oct 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Computers & Internet Logo
96 people viewed this question
Alun Cox
David Payne
David Payne
