Question about Samsung SW62ASP Top Load Washer
Code dE My machine shows the code dE and won't start. Any suggestions?
    New Friend:
Right hand side under lid there is a magnet may have come unstuck. mine did through corrosion just put it back in same position with glue or something else. should do the job.
Posted on Feb 09, 2015
As Far As I Am Aware That Is A Washing Machine Door Error Code
Posted on Apr 21, 2014
  • Mohammed Rabih
    Mohammed Rabih Apr 22, 2014
    door error problem
  • Mohammed Rabih
    try to fix the door proper .
Washing machine started and water filled, then alarm came and showing " de". Then not working
de code usually means "door error" might have a bad door switch. loose or not closed propery
Dec 07, 2016 | Washing Machines
No power but a de code when I spin drum
DE error code shows that there is a problem with the door latch assembly. If this latch switch does not work, the machine will not turn on.
Check the continuity of the door switch with a multimeter on OHMS.
Apr 26, 2015 | LG WM2701HV Washer
Code de will not go away
You have not included the Make and model of your washer. Below is a google search for Washing machine error code de
This refers to a Samsung washing machine.
I suggest that you edit your question to include both the Make and model number. This question has been answered before on FIXYA for a samsung washing machine. Link included below. dE
dE1 Ed Door issue ·Check that the door is closed fully.
·Check nothing is trapping in the door.
·Check unit is not overloaded.
· If problem persists please call the customer support team.
Samsung washer machine error code dE
Aug 16, 2014 | Washing Machines
Why does my LG washing machine model WD(M) 16115FD show error code dE?
It appears to be a problem with the door? You can go to the following link and try their troubleshooting, hope it helps. http://www.ehow.com/how_7850983_troubleshoot-de-code-lg-washer.html How to Troubleshoot DE Code for an LG Washer eHow
Aug 10, 2014 | LG WD-16115FD Front Load Washer
Code dE showing
Does your washer have a lid lock mech. If so and the lid is not locking or is staying locked you may want to check the locking adjustments
Apr 21, 2014 | Samsung SW62ASP Top Load Washer
Hi! My LG washing machine is showing a "de" error code. It won't allow water into the drum. Please help
Hi, the error code "dE" signifies a door open error. This may simply be because the door is not all the way closed. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it, though it could also represent a number of other problems. There may be a faulty door switch, a malfunctioning electrical connection or a damaged gasket.
Jun 24, 2011 | Kitchen Ranges
I have purchased a samsung WF7602NAW and will not start and shows code (de) and starts to beep.
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Apr 05, 2011 | Samsung Washing Machines
Try to start machine code de showing and beeping
DE = Door Error.
Latch, sensor or similar has failed.
See this link:
LG -
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 13, 2011 | Washing Machines
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Samsung SW62ASP Top Load Washer Logo
223 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
