Question about Bolens 13.5 HP Manual 38-in Riding Lawn Mower with Briggs & Stratton E
Had my yard almost done when i hit a low spot and think my blades couldnt move b4 i could stop it quit and when i tried to start it back up it canked bout 3 times started turning over than BANG and smoke, is this an easy fix or pro job?
  • Bolens Master
  • 17,326 Answers
This is most likely the flywheel on the motor that has slipped out of timing. You need to replace the woodruff key and set the flywwheel back in line with the slots for the key.
Posted on Apr 21, 2014
I have GE ADORA DSS25KSRDSS FREEZER FAN NOISE, how do you remove the cover panel to get to the fan that hits the cover ?
This model is quite the stinker and everything, and I mean everything has to come out to make it easy to remove the fan motor.
I have found that on GE's the blade becomes loose and that is what hits. Sometimes the blade is no longer available since Haier now owns them.
Take pictures during disassembly and lay everything out on towels so it can go back together right and take your time! This is a tough one
Feb 09, 2018 | Refrigerators
I hit a brick, lawnmower won't move help
check for bent crankshaft at blade connection point. do this by removing spark plug and turn the mower on its side with carburator side up, now spin blade by hand and see if it will spin without a wobble. if it does not want to move, something else inside the engine is damaged and probably not worth fixing. if the blade does not spin true, it is a bent crank and might be able to be straightened by a mechanically inclined person without further damage to the motor. also check to see if the piston is moving while spinning the blade if it will turn at all. R
Sep 02, 2012 | Mtd 22" Yard Machine Push Mower
I apologize if this post sounds familiar. The Deal: I have a Poulan Pro Model#PR675Y21RHH Walk-Behind mower with a B&S 6.75hp engine. I was in the process of mowing the lawn when I hit a high spot in...
Two things likely happened, but one is real bad and I think that both probably happened here. The lesser of the two is a sheared flywheel key, which explains why it will not start. The greater is a bent shaft which is why it is so hard to turn even with the spark plug removed. To check for the bent shaft, remove the spark plug and tip the deck enough to get a good look at the blades and turn the blade. If there is a wobble of any kind then the shaft is bent. Also if the shaft is bent, with a push mower it is not cost effective to repair unless you are willing to do it yourself.
Aug 17, 2011 | Poulan Pro " Pro" Self Propelled Mower
Everytime we hit low ground and stop the blades, it quits and won't start again. We took it in and the mechanic fixed it easy, but didn't tell us what he did. I caught bailing twine in it this evening...
I don;t know what kind of mower you have but if it is a push type mower where the blade is bolted directly to the engines crankshaft if you hit something solid enough to kill the engine it will sometimes shear the flywheel key. This throws the ignition timing off and the engine will not start. Hope this helps.
Sep 15, 2010 | Garden
I had hit a somewhat hidden stump on the lawn..bending the blade. Took the deck off and replaced the bent blade. Put the deck back on and now the cut seems uneven. It appears that the deck is now...
I've only had luck removeing the deck, turn it upside down. Measure blade, mark, remove blade, insert large pipe over spindle, bend in direction. Re-install blade, and do it all over and over till straight. Measure in several locations.
Aug 18, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Deck may be bent?
On your problem it is diffiuct to say. I don't know how old it is and if it has been run hard in gravel or how many roots you hit. However if the blades hit it hard enough you may have hit the deck brackets. You need to get it no concrte so you can mesure the for corners of the deck on the level surface, then check which side and if it's front or back that is higher. Most likely the lowering arm Is what is bent where the lever you Drop the deck down with is, look tthere first. Also look at the top of the deck and side to side at the lawen mower and see if you can see if the deck is up higher on one spot more than anywhere else. . I know this is confuseing but hope you understand what I am saying. I would also check the front axle mesure the top o the axle on both sides are they even? Yes? then mesure from ground to top of the hood on the lawnmower. Good luck.
Aug 28, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Wife hit hammer in yard tractor died turns over dont sound right took out plug some compression dont think the valves are moving will back fire ater cranking for a wile
Check your blades, replace with straight ones. It is impossible to further diagnose until you've done this, and it may be your only problem.
Regards, --W/D--
Jul 21, 2009 | Garden
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Blade too close to ground
move them foward to raise wheel height. you can confirm by moving to full foward posistion on front wheels then adjust down to get height you desire.and repeat with back wheels and set accordingly. hope this helps..chris
May 12, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Bolens 13.5 HP Manual 38-in Riding Lawn Mower with Briggs & Stratton E Logo
Top Bolens Garden Experts
cwradio73
ray gallant
Mike Denton
Mike Denton
Level 1 Expert
Are you a Bolens Garden Expert? Answer questions, earn points and help others
