How do you reset a hdmi cable on a toshiba ct-90329 tv
We have a ct-90329 tv and we connected a hdmi cable but now no other cables will work and we need to reset it but we don't know how
Heiny
  • 10 Answers
SOURCE: PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Posted on Dec 17, 2007
cammykins
  • 149 Answers
SOURCE: Programming remote control to Cable TV Box
What you need to do is contact the manufacturer of either your remote control otherwise the manufacturer of the Time Warner [aka: cable providers some times also have the info on file for their customers] they store the code information within their internal systems for their customers such as yourself. Otherwise there is normally a paper insert with the remote control or the Time Warner that would list the info for select manufacturers on there. Toshiba has pretty universal IR signals/codes so you should be okay when trying to program in the codes. The manufacturers can also assist you through the steps--believe me it can get frustrating some times!
Posted on Jun 16, 2008
SOURCE: HDMI connection on HP Pavilion dv9000
try going to windows mobility center & click connect displays
Posted on Jan 09, 2009
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Posted on Feb 17, 2009
phongnv
  • 56 Answers
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
Posted on May 12, 2009
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
Can't record from box/dvr to a dvd-r
get a new one amd instage it and tell the manger that it is not working
Dec 26, 2013 | Toshiba DR410 DVD Recorder
Connecting HT-ct 150 to cable box, and tv with HDMI cables
The user manual for the device should contain a schematic of the various cable sockets:
Sony HT CT150 manual
Feb 05, 2013 | Sony HT-CT150 Theater System
How to connect a toshiba satellite L675 to a tv using HDMI cable
If you TV has HDMI connections. All you need is a HDMI cable. Hook the HDMI cable into the laptop and into the TV. Turn the TV on and go to that HDMI connection on the TV. It will show everything on the laptop on the TV. Videos, Documents, and anything else.
Jan 18, 2013 | Toshiba Satellite L675-S7044 Notebook
How to connect sony ps3 to toshiba 32av500a
Use any HDMI cable to to this.
Connect cable to the "HDMI" port on the back of the PS3. Connect the other side of the HDMI cable to the "HDMI" port on the Toshiba TV. If the Toshiba TV has multiple HDMI ports, make note of which port you plugged the HDMI cable into.
Change the Toshiba TV to its "HDMI" video display mode. Press the "Power" button on the PS3 to turn the console on. The PS3 will automatically detect the HDMI cable. Select "Yes" to use the audio and video from the HDMI cable. Select "Yes" to have the PS3 automatically use the optimal settings for the Toshiba TV. Select "Yes" to accept the recommended resolution. Press the "X" button to save the settings
Dec 22, 2012 | Toshiba Televison & Video
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
No sound with HDMI cable and Xbox 360
FROM THE TOSHIBA MENU, (FIRST MAKE SURE YOU ARE SET TO
THE HDMI PORT THAT THE XBOX IS PLUGGED INTO) THEN SELECT
HDMI SETTINGS, UNPLUG HDMI CABLE FROM THE TOSHIBA TV (LCD
FLAT, MINE IS A 42") WAIT FOR THE SETTINGS TO HIGHLIGHT OR NOT
BE GRAYED OUT, THEN TURN OFF THE THREE SETTINGS, FOR COLOR
AND LIP-SYNC., SCROLL DOWN AND PRESS THE RESET BUTTON,
WAIT FOR MESSAGE TO APPEAR. TURN OFF THE TV AND PLUG IN THE XBOX.
TURN EVERY THING BACK ON. SEE IF IT WORKS.
NOT ALL CABLES ARE THE SAME AND NOT ALL TVS ARE THE SAME.
READ THE TV OWNERS MANUAL CAREFULLY, (RTFM), I FOUND A NOTE ABOUT
THESE SETTING ON THE SPECIFICATIONS PAGE.
Mar 26, 2009 | Toshiba 40RV525U 40 in. LCD TV
Panasonic CT-32SF36 isn't getting video from A/V receiver
Hello, I hope this message can help you, After reviewing the Panasonic TV info, and the Yamaha reciever info., I have found on page 19 of your owners manual for the Yamaha reciecver that you can connect the the cable box HDMI cable to the reciever, but the reciever needs to connect to the T.V. HDMI.
I see your T.V. has S-video in and your reciever has S-video out, what about your cable box if it has S-video than I would connect all your device together through the S-video jacks.
A further note is you can't down grade the signal from the cable box through the reciever to the T.V., so even though the technology is there on your cable box, it's not there on the T.V.. On that note there is 2 options 1) buy a new T.V. with HDMI inputs. 2) connect the system together using S-video or component cables (RCA). It will give you almost the same quailty if you use good cables. I hope this will help you and I look forward to helping you in the future.
Jan 14, 2009 | Panasonic CT-32SF36 32" TV
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
All: Try this -
P
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
