Question about Garden
Poulon 18 horse more 42' inch orange color deck engine turns but wqont start. no fire at plug. What should check?
    President:
  • 2,692 Answers
Coil , Wiring.
Posted on Jun 19, 2009
How do I drop the deck on a 42 inch riding Poulon lawn mower
Look to each side of the deck just in front of the rear tires. You will see an spring clip on each side. Remove these clips. There is also a clip on the front of the deck, remove it as well. Remove the belt and the deck will slide out from under the tractor.
Mar 09, 2017 | Garden
Craftsman 42 " mower w/Kohler 18 horse engine clicks, but will not turn over.
my westwood tractor 1600hp will not charge the battery
Apr 17, 2013 | Craftsman Garden
17.5 intek engine will not start, engine has fire and gas. craftsman LT2000 42 in deck lown mower
Is the flwheel key ok? Or you may problem like me. Pull
valve cover and see if both pushrods move.
Jul 19, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What size belt for powr kraft 18/42 industrial commercial twin cylinder automatic hyrostatic dive .need deck belt.
My mower is 18/42 power kraft, limited addition, hydrostatic. I need to replace deck belt because deck belt was bitten by mouse. May I know belt routing and how to replce it. Thank you.
Jan 28, 2012 | Garden
Mower dies when put in gear
have you checked the mower bed to see if its free to turn over,,if the bearings have sezed up or are tight this loads up the mower engine
Jul 05, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman riding mower will not start
Same thing happened to me with my 26 horse kohler craftsman. Replaced EVERYTHING (spark plug, fuel filter, oil filter, and degunked the carborator), and still was flooding. It ended up being the flywheel key. Cheap part, quick fix. I guess it can happen when you hit something hard with the deck, or it can just happen without reason... I hit a snowbank hard with my snowblower attachment, but I didn't even realize it until afterwards because it kept running fine. Supposedly, even after the strain to the engine, it won't always stall out. It will keep running (but maybe rougher) until you shut it off. Then when you go to start it again, you will have no luck because all the timing is out of whack. It cost me $80 to have a repair company fix it. I think the part was only $5.
May 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
It is firing from the spark plug but will not attempt to start . this is a poulon pro 42cc chainsaw.
Try a squirt of starting fluid in the plug hole, replace the plug and try to start. If you get a pop or two, then you have fuel problems. Make sure you have fresh fuel mix in the tank. Check the condition of all fuel lines including the in-tank line plus the fuel filter for plugging. Check the muffler and air cleaner for plugging. Does the engine seem to have good compression? If everything looks ok, then it may be time to disassemble the carburetor, clean and re-kit it. Set both needle jet screws initially at 1-1/2 turns out CCW from the CW stops (lightly). The engine should start and run--allow to warm up. Pull the throttle full on and adjust H CW until the engine runs faster, but is still 4-stroking. The correct adjustment is for the engine to 4-stroke, but immediately 2-stroke when cutting. Release the throttle and adjust L CW for fairly smooth running, yet allows the engine to 'follow the throttle'. Set idle speed screw to stop the chain from turning at idle, but keeps the engine running. Hope some of this helps!
Apr 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Replace key assembly
any small engine repair shop should carry that switch - or sears . com - just put in your model number
Oct 21, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
46 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
