Question about Coffee Makers & Espresso Machines
Deonghi magnifica stuck at "replace grounds container"
Unplugging/plugging doesn't work. NOTHING functions. In the midst of cleaning and about to descale.
kram26
  • 544 Answers
SOURCE: delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
Posted on Mar 21, 2009
  • 55 Answers
SOURCE: Lights for descale and grounds drawer flashing red
Have you ventilated the machine . turn to hot water and see if can get water out .
Posted on Dec 18, 2009
freetek
  • 5568 Answers
SOURCE: Descaling light still blinks on our Magnifica 3300
I would move the machine to another room and use a couple of cups of plain white vinegar and let it sit overnight before running the cycle again. The mild acid should remove the calcium buildup.
Posted on Mar 14, 2010
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
mnwarfield10
  • 452 Answers
SOURCE: Lost the instructions / booklet
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
Posted on Feb 28, 2011
Delonghi magnifica raid cappuccino keeps on displaying insert grounds container when all clean and inserted please help can not get it to work
looks like the micro switch on the bottom might have some coffee grounds and prevent the grounds container from correctly closing
Clean with old brush and re insert.
If you still have a problem....it could be the micro switch
Nov 15, 2016 | DeLonghi Coffee Makers & Espresso Machines
Grounds container indicator light stays on, grounds container is in place
I have the same problem as this after cleaning. The machine won't power on. It does a power on self test and then the grounds tray full or missing light comes on and nothing else can be done.
A friend of mine with a similar machine says hers fixed itself after a while so assume some sensor got jammed/obscured with my over zealous cleaning. However I'm not hopeful. Might try taking it apart.
Jun 10, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica Light B12 in manual states that
I had a problem where the machine would not operate and the water and grounds lights were on steady (red). After contacting customer support, they directed me to do a reset. This is done by disconnecting the power and holding down the ground coffee and decalcification buttons while reconnecting power. Then release the buttons and power on the unit. This revived my Magnifica from the dead, maybe it will work for you...
Nov 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
My delonghi magnifica is having a problem with milk..steam is coming through but no milk..can you suggest what the problem may be?
There are 'o' rings on the pipes (on machine - not milk container) where the milk container fits into. replace or clean them - should work like new.
Jun 21, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
Dec 19, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
