My son's scribble and write letter pad doesn't work Won't enter and letters or numbers
    Champion:
    New Friend:
  • 219 Answers
Try reinstalling drivers for touchpad.
Posted on Jun 09, 2014
2 Suggested Answers
  • 1043 Answers
SOURCE: i cant undo the fn key on the mini note
You should be able to turn off the built in numeric keypad by pressing the fn key and the num lk simultaneously. The num lk is directly above the +/= key. If after doing this you still find you only momentarily turn off the numeric keyboard then there is another underlying issue. At that point you should take your unit to your area HP repair center.
Posted on Jul 15, 2009
Cs6629 how do i enter numbers on to key pad instead of numbers
Assuming you want to enter a name into the directory, simply keep pressing the appropriate key until you get the desired letter. For example, if you want one of "ABC" then keep pressing the "2" key to cycle through these letters.
Dec 30, 2013 | Panasonic KX-TG2357 Cordless Phone
Hi, I have a trouble with this toy, the writing pad don´t works, if I type a line or a letter, the pad fill areas that I don´t mark, the square pad fills completely and I can´t see what I...
Hi!
Please try removing the batteries first and make sure you use fresh ones. If it is still not working properly, it could be a malfunctioning LCD screen and might need replacing.
Feb 21, 2012 | LeapFrog Scribble and Write
The touhscreen is not working properly. I touch Change State and it takes me to Postal code with the letter pad. I touch 123 and it enters a letter. The erase button does not erase. Every button I touch...
with unit off slide the power switch to the Left as to power unit on BUT HOLD the switch to left about 30-45 sec then you should see the calibration screen. Tap the corresponding taps very lightly and use a pencil eraser to be more precise with your touches.
Sep 25, 2011 | Garmin nuvi 255W GPS Receiver
How do I use the number and letter keys on the key pad to enter password?
If you hit shift on the text pad or plug in a keyboard to the usb port, that's a lot easier. :)
May 11, 2010 | Video Game Consoles & Games
How do I chance the names on an NEC phone
NAME DISPLAY
NOTE: Display Dterm
A name with up to 16 characters can be entered to display the name on
other Dterm telephones when making a call.
• Press Speaker key, Receive dial tone.
• Dial the Name Assignment access code and receive special dial tone.
• Using the keypad, depress the key with the desired letter to display the
first letter on the key. The
display will indicate the
numerical designation.
Subsequent depressions will
advance through the letters
on that key. The Dial Pad Key
TABLE can be used as a
guide to indicate the key and
the number of depressions required to display numbers, letters, spaces
and periods.
• When the desired letter is displayed, depression of the Transfer key will
change the letter to a lower case letter (default is upper case). Depress
the Hold key to enter that letter and advance to the next entry.
• Repeat the previous two steps until the desired name is displayed and
entered
Apr 05, 2010 | NEC Dterm DTP 16D-1 Corded Phone
CAN'T GET ALPHABET LETTER TO APPEAR FOR STATION ID.
Letters are on the soft pad to the left of the number keys. Very tiny, so look close. You can also lift up the mylar sheet and remove the paper sheet.
Mar 04, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
Need to record phone numbers on speed dial - have lost the owners manuel - 4 line phone
Storing a Name and Number in Memory
1. Press the STORE button on the handset, ENTER NUMBER is displayed.
2. Use the keypad to enter the phone number (up to 32 digits).
3. Press the SELECT button. The display shows ENTER NAME.
Telephone Operation
17
4. Use the touch-tone pad to enter a name (up to 21 characters). More than one letter is stored in each of the number keys. For example, to enter Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Press the 5 key 3 times for the second letter L, and press the 1 key to insert a space between the first and last name. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H.
5. Press the STORE button again to save your selection. ENTER LOCATION is displayed.
6. Enter two digits to enter the location, ranging from 01 to 40. For example, to store the record in location #5, press “0”, “5”. After entering a valid location number, the record will be saved. If the memory location you selected is not empty, OVERWRITE? will show in the display. Press the STORE button again to confirm the current record and overwrite the old one or press the EXIT button to select another location.
7. To enter another name and number in a different memory location, return to step 1 and repeat the process.
Good Luck.
Jan 30, 2010 | RCA 25413RE3 Corded Phone
My son received the game yesterday. When we try to enter coordinates for Player 1's ships, it repeatedly says "incorrect coordinates." We are entering the letter, then the number, then enter.
Hi there... not sure which version of the game you have... but I was told.... If you want to enter for example.... b6... you first push B.... and then the buttons automatically change to numbers... then push F.. which is the 6th letter....
or c4 would be c.... and the d.. (the fourth letter)...
Hope this helps... just got the answer now... so gonna try it myself...
Kind regards
Debbie, New Zealand
Dec 03, 2008 | Hasbro Electronic Battleship
Storing #s in memory
Try this. Memory The handset can store up to ten 24-digit numbers with up to 15-character names in memory for quick dialing. This memory feature is in addition to the CID memory log, which stores up to 40 CID records in the handset. Storing a Name and Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the mem button. 3. Press the desired memory location (0 through 9) or use Caller ID/vol (+ or to scroll to the desired memory location. NOTE: If the memory location is occupied, the memory location number and its contents show in the display. 4. Press the mem button again. The display shows ENTER NAME. NOTE: If you don?t want to enter the name, skip step 5. 5. Use the touch-tone pad on the handset to enter the name (up to 15 characters) and press the mem button to save. More than one letter is stored in each of the number keys. For example, to enter the name Bill Smith, press the 2 key twice for the letter B. Press the 4 key 3 times for the letter I. Press the 5 key 3 times for the letter L. Wait for one second. Press the 5 key 3 times for the second letter L. Press the 1 key to insert a space between the L and the S. Press the 7 key 4 times for the letter S; press the 6 key once for the letter M; press the 4 key 3 times for the letter I; press the 8 key for the letter T; press the 4 key twice for the letter H. 6. Press the mem button to save the name. The display shows ENTER TEL NUMBR. 7. Use the touch-tone pad to enter the telephone number you want to store (up to 24 digits). 8. Press mem again to store the number. You will hear a confirmation tone. NOTE: If you make a mistake press the del/chan button to backspace and erase the wrong character(s) or number(s). If there are any further questions or comments, please post here. Please rate this solution through fix-ya.com Thank you
Jun 18, 2007 | GE 25836 Cordless Phone
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
