Question about Panasonic TC-20LA2D 20 in. LCD Television
Clixking nose makes clicking nose when I turn power on
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
There are several relays that turn on when a car's electrical system is engaged. It sounds like one of them is having trouble staying turned on. It may be indicative of a short or old frayed wiring that is causing a circuit to cycle continuously; or it could just be a bad relay.
I have an old battered truck with cracked, dried up wiring that his that problem with the relay on the little door under the dash that lets in fresh air. it draws juice, opens the door, overheats the bad wiring, the circuit cuts out, it cools off almost immediately, then turns on again, causing the relay to be constantly flickering on and off, and because it is old too - it clicks loudly both going off and coming on.
Posted on Apr 21, 2014
GE dryer nose dryer is making a squiking nose when running
Please check idler pulley. It is located beside the electric motor.
Make sure power is disconnected. If pulley worn replace it.
Apr 03, 2014 | managemylife.com
My audio is not working the problem is in the realtek AC'97 audio for via r audio controller
Things you can try; right click on speaker icon at lower right of screen in task bar, is there a red x on it? Click on playback devices. you dhould have "realtek' or "hd sound device", etc.. You should have a green check on left side and power bars on right. Right click on device, and you should see "disable". If you see "enable" click on that and exit. Right click on devoce again and click on "open sound mixer" and adjust your volume. You can also try ; clixk "start" find and click on "control panel". In your list (icons) click on "device manager", open and click on continue. Click on the box with + next to "sound audioand game controllers". You shpuld have a drop down with your device. Right click on it and you should see "disable". If you see "enable",click on that and exit. Right click on it again and click on "properties" tab. You should see "this device is working properly". Go to your speaker icon back in desktop and adjust your volume.
I could be of more service if you provide more details about your problem. It sounds like you have a VIA chipset with Realtek audio. If I can help you further let me know.
Dave
Mar 29, 2011 | Audio Players & Recorders
How can you make your nose look smaller with make-up?
Use concealer on the bridge of your nose and use a power on top... I saw it on Oprah.
Use an eye shadow that is a little darker than your skin, and put it on the sides of your nose to make it look thinner. An eyeshadow with a slight green tint will help minimize the appearance of depth around the edges, thus creating a smaller appearing nose.
Buy a thing of powder that's two or three shades darker than the powder you put on the rest of your face, and brush it on the sides of your nose.
I used to do make-up and costume design for theater. The advice above is spot-on: you want a color a few shades darker on either side of your nose. To make your nose look even thinner, use a color a few shades lighter than your skin right along the top of your nose, down to the "ball" --the part that sticks out the most. If you're trying to create a curve to your nose, ie, make the bridge seem like it sticks out less, use the same color that you used on the sides and blend it--gently!--over the bridge, then apply the highlight color just to the ball and blend thoroughly. Less is more here: in Theater, we heap the makeup on so that the audience can see it under the bright lights. In the real world, you want to go very easy on it. If you use too much, or too dark a color, your nose will just look dirty.
Make sure the foundation and concealer you use is matt making your nose appear less shiny and less attention will be drawn to it, also make your eyes, cheeks stand out that way the attention will be drawn to your nose. I have a fairly large nose and just for the past year what I've been doing is taking blush, and rub it gently up and down the nose. but don't touch the sides at all, this will make your nose appear thinner and more narrow than big.
Added an illustrating related link. It's easier to understand by seeing a picture or video.
Another way is to draw attention away from your nose, all you need to do is to apply more make up to your eyes.
Nov 22, 2010 | Health & Beauty
My stove (Caloric) keeps making a clicking nose when all burners and the stove are turned off. I would appreciate any suggestions for how to fix this
This means that the oven has detected a condition it needs to check. Press "Cancel" to clear the display and to stop the clicking sound, then try turning the oven off and on again. If you still note the sound turn off the power to your oven and wait five minutes before turning it on again. If you hear the beep or see the any code when you try to bake or broil again,
then you will have to open the oven to solve the problem by checking on the panel carefully if there is any over flow of water on the panel or the element will need to be replace.
thanks.
Sep 29, 2010 | Stoves Ovens
My 93 jeep grand cherokee turns over but has no spark. it has fuel pressure and gas. what is wrong with my car?
First test the coil, Make sure you have power to it? If you do? Inspect the cap and rotor button for damage. If that all checks out? replace crank sensor
Jun 15, 2010 | 1993 Jeep Grand Cherokee
The unit stopped dispensing water, makes clicking nose
If you would like to do this yourself and save the fee of a service tech I ill tell you the motherboard and compressor start components have been affected. Just replacing the board is not always the answer. These refrigerators are sensitive to electrical surge, fan failure, compressor start component failure and eliminating the cause is the best and less expensive way to approach this, I will return later and discuss parts and I do need you to confirm your model is the GSH25JFR, Thanks, Sea Breeze
Feb 08, 2010 | GE GSH25JFR Side by Side Refrigerator
My tracker ball works just when i clixk on anything nothing happens also when i try calling a number i get letters instead of numbers blackberry curv
Try doing a hard reset. Take the battery out of your phone with the power still on. Let it start up, which may take a while. If things don't improve then, make sure your blackberry software is up to date with the 4.7 or 4.5 software. If still no luck, call your phone company. Get a replacement or find a technician near you. I wish you the best of luck! Need any help, just let me know ! :)
Mar 18, 2009 | RIM BlackBerry Curve 8310 Smartphone
Panasonic TC-20LA2D 20 in. LCD Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
