Question about GE Refrigerators
I cant remove the ice bin. it appears to be stuck. dont want to force it, maybe release lever is broken? model #PFSS6PKXASS
    Problem Solver:
  • 18 Answers
With gentle force pull up and out at the same time
Posted on Apr 28, 2014
HVACRH20
  • 237 Answers
SOURCE: Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Posted on Dec 26, 2006
  • 25 Answers
SOURCE: Ice Maker not making ice
replace the icemaker is the best solution , or possibly jst the control module
Posted on Feb 10, 2008
  • 864 Answers
SOURCE: Ice maker bin indicator arm is stuck in the bin is full position
You should be able to move it gently to the lower position.  If it doesn't want to move don't force it.  Try shutting the ice maker off in case the arm is frozen in the up position.  After the ice maker defrosts a bit try again to move the arm gently.
Posted on May 29, 2009
aasc
  • 1606 Answers
SOURCE: After 3 years we have ice but no water from the dispenser
Remove the bottom kickplate and the hose at the bottom of the door goes underneath the refrig about 3 inches , to a hose connector . Push in on the end of the connector and pull out the hose . Close the freezer door and press water . If water comes sprays out from hose under frig , then your door is frozen internally .If no water sprays out of hose , then your watervalve is bad . One coil is for ice and the other is for water but they come togather as one.
Posted on Jul 19, 2009
EllaWatson25
  • 725 Answers
SOURCE: Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Posted on Nov 05, 2009
I have a Samsung fridge RFG238AARS an the ice bin in that services the door ice will not come out. The release switch is struck ?
Joe Snow... Hello,
Pretty sure you have had some loose water freezing those sections together... once thusly... you are either looking at brute force and hoping to find/buy the parts you break...
I have the Kenmore Elite... My opinion... the MOST HIGHLY sensitive BIN for jamming onto the door... SINCE I have learned to completely DRY the BIN before putting it back into PRODUCTION... I HAVE had NO trouble GETTING THIS ugly little bin to release...
Still can't get it loose...
You may need the more cerebral approach of allowing the room temperature (perhaps rushed along with a room fan... TO SEPARATE... DRY & REASSEBLE INTO their original design... sans BLOCK ICE.
Using HEAT sources on SOFT PLASTIC parts would/could prove quite EXPENSIVE (assuming you could actually get the PARTS/SPARES... YOU HAVE Warped, Melted & otherwise ruined.... (I'm just saying).
I periodically remove ... dump & clean the ice bin... On the first couple of times I left a little water inside...
What could it harm...
Now that I know the SECRET... It is my go to bin for picnics, parties, champagne buckets, black-eyes, sprains & bruises...
Great fun.
Moisture PROBLEMS = EVERYTHING!!
If THIS proves to be a CHRONIC PROBLEM...
Start checking the ICE Shute is properly closed... door seals are good... warm air penetrating the FREEZER space can cause ice to thaw... water to refreeze... and ICE BINS to turn into serious PROBLEM AREAS.
Go with the EASY & CHEAP issues first...
Make sure you temperatures are where you want them...
Comment me back IF YOU ARE stumped... I like refrigerators!
Jul 19, 2016 | Samsung Refrigerators
When crushed ice is selected it will continue and not stop
auger stuck remove bin check for ice build up behind bin or in bin clear make sure lever moves freely on bin& auger relay at rear if its a ling bin unit .
Mar 16, 2015 | Frigidaire Refrigerators
Craftsman lawn tractor
I have had this before. Most likely it is a broken or missing return spring which is pulling the pulley to stop position (this is part of what pulls against the engage lever when you pull it up to engage the deck). Also there might either be debris under the lever on the deck that the moving pulley is attached to or it could be bent. Remove the deck and check for the spring (if you have owners manual that will show exactly where it would be located. If you dont and cant find one, give me the model number from under the seat and I will see if I can find one). If the spring is there, try forcing that lever on the deck by hand to see if you can get it to release (keep yours and others fingers away as when it breaks free, the spring provides some good force.
Aug 05, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ge model pfss6pkxass integrated ice maker not making enough ice
it could be to much force maybe back off the supply tap to the water side of it and see how it goes
Apr 08, 2014 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Kitchenaid KSRS25 Ice dispenser blades get stuck
Greetings,
In looking up this partial model # KSRS25, it shows you have
the model with the large ice bin inside the freezer.
My question to you is: Does the auger motor run when you
push the ice lever?
2 trouble prone parts on this model. Both in the case of NO
auger motor activation.
#1 broken pin that hold the micro-switch on to the switch bracket.
Item # 15
1690545?addlogo=false
Next #2 and the Worst, A Broken Blue wire or wires in the wire loom
under the freezer door hinge. Un-repairable new door needed if still
available.. You have to get creative restoring the power.
So before I continue, Does the Auger motor Run?
And if it does, remove the bin and close the door switch that turns the
light off, and tape switch shut. With door open and ice cradle pushed
in watch the auger drive fork turn? Is the the key hole stripped in the
fork.(rounded out) May need the fork or motor. #9 & #2
1708855?addlogo=false
May 28, 2013 | KitchenAid Architect® Series II KSRS25RS
Icemaker seems to be stuck, making strange noise and not producing ice
first of all they make a few different kinds of i\m let alone models and brands of fridges, if its electronic then the module is propably broken
Jul 07, 2009 | Refrigerators
GE Monogram refrigerator ZFSB26DRE - ice bin stuck
their has to be a release botton on it look around inside
Jun 06, 2009 | Refrigerators
Frost build up on the ice bin
the ice door is not closing or not sealing .. maybe a broken spring or lever...you will need to replace that broken part..
Sep 13, 2008 | GE GSS20IEM Side by Side Refrigerator
Jan 14, 2008 | Jenn-Air JCD2389G Side by Side...
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
