Question about Vacuums
What is the best water quality - Vacuums
  • 85 Answers
Distilled.
Posted on Apr 21, 2014
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Bissell proheat 2x 9500e leaking water
Hello, this is Ava with Think Crucial.
First, make sure that the caps are on securely and the red rubber auto-load gaskets are in place. If the red rubber auto-load gasket is missing, check to see if it's stuck in the reservoir. Next, check the tanks for cracks or damage. If there is damage then you may need to replace it. If your gaskets are correctly assembled and your tanks don't seem to be damaged, at this point it might be best to take your carpet cleaner to a technician. You can call Bissell at 1-800-237-7691 for authorize service center near your area.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=bissell
Ava B.
Think Crucial Customer Care
Jun 22, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
Why did soap and water canister leak onto floor?
I hope this was helpful.
Ava B.
Feb 27, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do I register a purchased/
It's a Bissell. It's somewhat pointless to register a warranty with Bissell. Anything made by Bissell is made in China with the poorest engineering . It is designed to last one year at best. The customer service is very poor because they are continually overwhelmed with complaints. Use the machine as long as it will llast, then replace it with a quality vac from your local vac shop. You will be surprised at how much better a quality vacuum will perform and last. You will likely also be surprised to find they don't cost much more too. Support local and we all win.
Feb 19, 2015 | Vacuums
May I use vinegar to de calcify my Rowenta commerical steamer?
Hi clbarnes2346,
Welcome to fixya!
The cleaning instructions recommend using a solution of 1/3rd white vinegar and 2/3rds water to decalcify. This should be done once a year or every 100 hours. Run for 3 minutes then empty water. Unplug and let cool down. Then rinse and repeat with fresh water.
For best operating, distilled water is the best to use if you have hard water.
Thanks for visiting with us. I'd appreciate your vote when you accept this solution.
Thanks,
Handie Andie
Aug 21, 2011 | Vacuums
What type of water to use RO vs Bottled water I thought RO is the best to use
Yes, RO is definitely the best form of water while bottles is debatable.
Jul 15, 2011 | Vacuums
How do I change the belt on Eureka 4704 and where do I get belts
you can get belts (quality for great price) from amazon, here: Amazon com Eureka 4700A belt.
Wish you best of luck.
Ryan
May 29, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
HOW DO i GET THE WATER OUT OF THE CARPET ONCE IT'S CLEANED?
Do you have a shop vac . Take the bag out of the shop vac ,and **** up the water . When you are done open your windows and do not walk on the carpet for at least one hour . You want your carpets to dry with the pile standing up. Carpet rake is the best thing to use . Best of luck Ed.
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover f5520 steamvac duo upright wet washer
Your problem is inside the vacuum hose where they have installed a small coiled hose that carries water to the smaller power head for upholstery. After taking this apart I found the inner smaller coiled hose was broken at 2 different places. A very poor design and poor quality material. The hose looked like it was rotted. This could be from old detergent left in the line or maybe the wrong detergent. A job to get it apart but if you remove the three screws that hold the side plate over the electrical you can block that hose off and the machine will work on floors only as the water to the power head is terminated.
Nov 11, 2007 | Hoover F5520 SteamVac Duo Upright Wet...
Vacuums Logo
14 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
