Question about Air Tools & Compressors
Turbotorch extreme tx504 parts diagram
Won't light but will with match
Why won't my light or ceiling fan come on? I have changed the batteries in the remote. It is twelve years old.
We are desperate to find one of these fans..I will buy it for 75 so it can match the 7 other ones I have and I will use my parts to make it work..Scott 321-228-3081 THANKS>>I just have soo many and I need my house to all match
Apr 30, 2013 | Craftmade International Televison & Video
Tip
Finding kawasaki specifications/parts diagrams
to find Kawasaki specs & parts diagrams I use the web site buykawasaki.com or www.buymotorcycleparts.com
These sites can prove usefull to see exploded diagrams of different parts that can be extremely usefull when working on your bike.
regards Andrew porrelli
on Dec 03, 2009 | Motorcycles
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
How can i set up the time of the pool light in the a box model T10004R?
Typical T1000R series pool control center has space for 2 timers, and comes with one T104M 240Volt timer. Additional timer mechanism can be added to control lights, etc.
Copy following link for setting T104 series Intermatic clock, with link to wiring diagrams.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Intermatic pool timers are extremely durable and versatile, and modular so they can be repaired almost indefinitely using ez-to-locate parts
Additional link for replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Oct 28, 2012 | Intermatic T10004R - Pool-Spa Mechanical...
Can't plug 400watt ballast into a digital timer,bulb won't light.
How did you connect the 2 cords if they don't match up ? Usually the cord configuration on just about anything electrical is for a reason . It is to keep from plugging inthe wrong things ! It is possible that your digital ballst won't run your fixture due to miss matched intternal parts . One may be magnetic and one digital electronic .
Aug 23, 2012 | Garden
My lights won't turn off
see the diagram attached, and use the logic sense for troubleshooting, please use the VOM for test the parts defective, loose wires, open or break, switch defective, fuse open. bulbs open.
God bless you
Jul 10, 2012 | 1994 Honda Accord
Rinnai 300eb won't fire up maybe pilot light is too small?
how long have you left the pilot light a light, as they usually start small and over time say 3 min they get bigger, the size of the flame doesn't real matter as long as its lit, as the fumes from the fuel will ignite, if its not igniting it could be a problem with the flow meter this feed the boiler, starts off slow and builds up as the thermostat is heated. if you are smelling fumes don't use it and have it repair as a leak is dangerous for you and your family
Jun 21, 2017 | Heating & Cooling
Yamaha 2005 150 HPDI wiring diagram
Looking for wiring diagrams for digital tachometer with trim indicators and warning signals. Mine had the plastic trip arm break. No trim reading on Tach face. Replaced trip arm forsensor arm and now have no reading on the tach at all except extremely light tach Number. All other electrical components work OK.
Jan 24, 2012 | Yamaha Motorcycles
Main gas valve won't stay on when there is a call for heat from the thermostat
Open the front panel of the furnace to see the blinking light. It usually indicates a code based on the number of flashes. Check the inside of the panel for an electric diagram. You will find a troubleshooting chart. Match the code and find out the problem. Sometimes the troubleshooting chart can be found in your furnace manual. Good luck!
Oct 09, 2011 | Goodman GMS90703BXA Heater
The diagram on a 1998 ford contour does not match the way to put on the serpentine belt. It's a diagram under the hood of my car but does not match that diagram Can u show me a picture
Follow the diagram again. Sometimes the belt goes on the inside or the outside of the belt. If you see a pulley that has a smooth surface only then the outside smooth part of the belt goes over it. When you see a pulley that has the ribs in it the belt matches the ribs. If you follow the pulleys you will get the belt on correctly. They can be confusing until you have replaced a few. But, just follow the pulley surfaces and you will get it. Remember match ribs to ribs and smooth to smooth. Good luck.
Mar 06, 2009 | 1998 Ford Contour
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
