Kerboard My nobis is only a few days old I was able to use my keyboard. It now it won't work is their a setting I may have messed with. I looked but cannot find it.
  • 406 Answers
Connect an external keyboard. If you decide to not keep external then do a system restore to a date just before you did the mess up. System restore can be found in your system help files
Posted on Apr 21, 2014
How do i factory rezet my nobis tablet when its froze and wont go past the nobis emblem screen?
Hi Jeffrey, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 30, 2016 | Tablets & eReaders
Lost password Nobis 1022C what do I do.
I already answered you. You need to do a Factory Reset.
  • How to reset 9" nobis tablet to factory setting? - How do ... www.askmefast.com > Consumer Electronics > TVs > Reset Nobis internet table recovery mode. You can perform a factory restore on the phone to get back in. power off phone, then boot into recovery mode by holding volume up ...
  • Nobis 9" Tablet 8GB Memory Dual Core - Walmart.com www.walmart.com > ... > Nobis 9" Tablet 8GB Memory Dual Core Nobis 9" Tablet 8GB Memory Dual Core. ... I have called customer support twice and performed a simple reset and a factory ... I went on the Nobis site to look ...
  • How to I factory reset my nobis 7" tablet? - Ask Me Fast www.askmefast.com > ... > Reset Factory reset nobis pad. The volume keys wont navigate when trying to factory reset my tablet? ... How to i factory reset my nobis 7 tablet?
  • Apr 03, 2016 | Tablets & eReaders
    My keyboard will not work. All connections are correct and tight
    From what I've read about that keyboard, you are not the only one with it not working. There is one thing you can check however that might help.
    Touch Settings > Storage > three horzontal dots in upper right, it should say USB computer connection.
    Then touch Developer Options > USB Debugging and select *Allow*
    If these do you no good then it's probably the keyboard itself that went bad.
    May 21, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
    Streambook 13 keyboard locked up. How to return it to original settings
    since the laptop is only a few days old I would recommend performing a factory restore to the "out of box" state.
    Jan 05, 2015 | HP Computers & Internet
    Why won't my nobis 9 keyboard work?
    go into settings an check the usb . change it anyway
    Jul 22, 2014 | DOUBLE POWER TECHNOLOGY Nobis NB09 9" 8 GB...
    Keyboard wont work on my nobis nb09
    Try a different USB port. Try a different keyboard. Reboot. Go into the bios and check the settings.
    Mar 10, 2014 | Computers & Internet
    Laptop won't start after installing new keyboard
    Check the screws. One of them may be too long and is shorting out the laptop. If they are all the same length, I would remove them all and try it. Then install them one at a time to find out which one makes it work or, not work.
    Jul 13, 2012 | Intel Dell Inspiron 15r N5010 Laptop...
    1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
    This is called the blinking green light of death-----only one of two things can cause this problem.
    First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
    Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
    Try (after 70 seconds) to turn on with remote
    If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
    Second: if disconnection of the front keyboard does not help, the DM unit is bad.
    As you look from back of set it is large metal box at extreme left side.
    The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
    Let me know if you have questions and try disconnection of the front keyboard FIRST.
    REGARDS, SD TECH
    Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
    Compaq presario v2414NR, HD acting weird.
    They probably never updated the bios, and it's still looking for the old drive, if you get into the bios, you can remove that drive that it's searching for and then make sure that the new drive is being recognised at the 0 position, not 1 but zero, if that doesn't fix it we can go further but that mnmay be the problem, also go into your device manager and make sure you remove the old drive if it's still showing that it is in there. Just uninstall it and restart. the cmos settings should also be cleared by removing the plug and poping out the battery, on the motherboard, it looks like a quarter, it may stll have the old settings stoed in there Good luck, and let us know if it worked
    Mar 18, 2009 | Toshiba MK8025GAS 80 GB Hard Drive
    Scrambled keyboard
    y dont you try to connect the keyboard to another computer and check out whether there is any problem with the keyboard also... after this u will know whether it is a problem with the keyboard or not...
    Feb 08, 2009 | Sony VAIO VGC-LS30E Desktop PC
    Computers & Internet Logo
    69 people viewed this question
    David Payne
    David Payne
