Question about Gateway Computers & Internet
Internet access Computer will not access internet...specifically Internet Explorer...do not know what proxy server to type into LAN settings, nor address of proxy server, nor type of port number
  • 406 Answers
Don't use IExplorer, use firefox or chrome. You do not need to know any proxy. Stay out of Lan settings. Make sure your ethernet cord is plugged in tight on both ends. That cord should show a green light when you look directly into the ethernet jack on your computer. You should be good to go then and connect to the internet.
If you do not know how to deselect some of the factory defaults before connecting it to the internet, you will be setting yourself up to get hijacked or worse. Have someone who knows a bit about PCs to help you.
Posted on Apr 21, 2014
I can't get my LAN settings to automatically detect settings, box will not check.
Reset your proxy settings
Proxy servers, or proxies, act as intermediary servers between a Web browser and the Internet. According to Microsoft's website, proxies are mainly used by networks in companies to enhance the security and speed of their network connection.
Proxy servers can also be used to log Internet usage, mask the network address of a server or to apply global restrictions to a network.
Internet Explorer is set to automatically detect proxy servers by default.
You can reset the Internet Explorer proxy settings to their default settings from the "Internet Options" configuration.
I have found the easiest way to do this is to add the menu to the top of a webpage.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on tools option then from the drop down list Internet Options
Select the "Connections" tab, and click the "LAN Settings" button.
Delete the proxy server address and port from the "Proxy Server" settings and clear the "Use a proxy server for your LAN" check box.
Clear the check box beside the "Automatically detect settings" and "Use automatic configuration script" options in the "Automatic Configuration" section of the "LAN Settings" dialog window. Click "OK."
Click "Apply" and then "OK" to save these changes and close the "Internet Options" dialog window.
Close all Internet Explorer browser windows for these changes to take effect.
http://windows.microsoft.com/en-US/windows-vista/Change-proxy-settings-in-Internet-Explorer
Sep 12, 2013 | Computers & Internet
I use proxy servers, where should the proxy be inserted so that my drivers can update directly from my windows7
Internet options
Access it via Internet Explorer or Control Panel.
Choose the "Connections" tab and then press the "LAN settings" button.
Changes here should affect all programs that access the internet.
Mar 03, 2011 | Computers & Internet
Neither Internet Explorer or Firefox will connect to internet. Firefox say it cant connect to proxy server. How do I check proxy settings?
Open your Internet Explorer,
Go to Tools -> Internet Options -> Connections "Tab" -> LAN Settings -> Proxy server, uncheck the box -> OK
Restart your Browsers ie IE or Firefox, you don't need the proxy server if your are a home users.
Hope it helps.
Jan 29, 2011 | Microsoft Windows XP Professional
Not able to apply the proxy settings for internet explorer
Open Microsoft Internet Explorer and from the 'Tools' menu select 'Internet Options'. from the 'tools' menu.
Select the 'Connections' tab.
Select 'LAN Settings'. In the 'Proxy server' section select 'Use a proxy server for LAN ..., enter your proxy address, and enter port 8080. 'Bypass proxy server for local addresses' is selected if you are accessing network resources through a intranet. When complete, select OK twice.
NOTE:
After you apply your settings to the web browser test your Internet connection by attempting to access an external Web site such as http://www.google.com. Test more than one Web site. If you are unable to access external Internet resources, verify the spelling of your entries. If spelling is correct, contact your company's helpdesk to find out if there is a problem with the corporate proxy server.
Regards.
Jan 12, 2011 | Microsoft Computers & Internet
I formatted my system and reinstalled Win XP on it, but now I could not use wireless to connect with internet
Make sure you have Wireless network adapter driver installed.
Manually assigned IP address and DNS address as earlier (if your IP setting is not automatically assigned by DHCP server).
If you are using router set your Router IP address as your Default Gateway Address.
If you are using Internet through a Proxy Server then Open "Internet Explorer ",
Click "Tools",
Click "Internet options",
click on tab called "Connection",
Click "Lan settings" Button.
Remove "Automatically detect settings".
Tick "use a proxy server for your LAN....."
Type the IP address of your Proxy Server and the port no.
It will work.
Dec 26, 2009 | ASUS A8HE-X1 Notebook
How to fix error HTTP 403 Forbiden i can't log on bitsoup i keep getting 403 forbiden ....thanx for help
This error message means :-
403 - Forbidden - You can't access the page. You may not have access (it may require a password), or it may be blocked from your domain.
or your Internet site parent controlled site blocker.
Oct 28, 2009 | Dell Inspiron 1525 Laptop
Error code 80048820
MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
Aug 12, 2008 | Computers & Internet
Laptop computer, just repaired by Geeksquad, now will not connect to the internet
Open internet explorer, go to: Tools > Connections > LAN Settings > Un-check "Use a Proxy Server for your LAN".
Jun 09, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
