Question about Garden
Jet usa pressure washer
High pressure model PRSWSH4250PTL-SREL wont **** detergent from the tank. Can you help ???
SOURCE: bosch aquatak 120i pressure washer/tetergent
Hi Guys there isnt a problem with your machine you just need to pull the end of the spray lance out -the lumpy bit where the water exits the machine (it kinda clicks out)
Posted on Jun 27, 2008
  • 313 Answers
SOURCE: hooking up detergent to pressure washer
detergent can only be **** from the container only on low pressure.
Posted on Jul 08, 2008
  • 1388 Answers
SOURCE: Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Posted on Dec 01, 2008
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
SOURCE: pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
Posted on Sep 03, 2010
On my Karcher 2600, I filled the detergent tank but as I was washing the bus none of it was coming out, it was still full when I finished, any suggestions Ted?
I see this lots of times , the detergent tank will only mt in the low pressure mode of nozzle , this is the only way a siphion will develop inside the soap tank and then high pressure can be used later to wrinse the item off well using just water
Nov 06, 2015 | Karcher Garden
How do I connect detergent tank to pump? This is a g3000 washer
G3000 is not much help. I have a car with an engine, can you help me get parts for it?
In general it is not a good idea to run solvents and cleaners through the pump. It tends to destroy the pressure seals ( people are often creative in what they use as cleaners) To protect the pump there is usually a siphon fitting on the high pressure side of the pump. There is usually a hose that you stick into your detergent. You then put in a large capacity cleaning nozzle and the detergent is sucked up the hose and out the low pressure cleaning nozzle. When you put on the high pressure spray nozzle the siphon valve seals and it does not draw detergent through the hose.
Oct 08, 2014 | Karcher Garden
Troy bilt pressure washer 020207 won't draw soap
Below is a list of the MOST COMMONLY reported troubleshooting issues.
you might want to try these steps:
No detergent
Reservoir is empty
Add more detergent
No detergent
Detergent suction tube not properly connected to the machine
Check connection
No detergent
Detergent is too thick Dilute detergent
No detergent
Filter on detergent suction tube is closed
Open the filter by turning it to the desired detergent intake
No detergent
Filter on detergent suction tube is clogged
Run warm water through filter to remove debris
No detergent
Damaged or clogged detergent suction tube
Remove obstruction or replace detergent suction tube
No detergent
Spray wand is in high pressure position
Turn spray wand tip to low pressure position
No detergent
Discharge nozzle is obstructed Blow out or remove debris with a fine needle
reference from:
http://troybilt.custhelp.com/app/answers/detail/a_id/10652/~/basic-troubleshooting---pressure-washers-%28gasoline-powered%29
please consult the operators manual you can get from link below:
Parts Manual Finder
or a Professional Shop Manual for model specific technical information.
If professional service is needed, please utilize the Authorized Service Center Directory to have the equipment professionally inspected and serviced.
You may also contact our Customer Technical Support department at:
Toll-Free Sales and Support (U.S.A. Only) 800.828.5500
Hours of Operation (EST)
Monday-Friday: 8:00am - 8:00pm
Saturdays: 9:00am - 8:00pm
Sundays: 10:00am-6:00pm
May 11, 2014 | Comet BXD2527 Pressure Washer Pump
TerHow does the detergent tank on a Challenge Extreme Pressure washer operate? I cannot find a trigger to release the detergent into the water or does it happen automatically when there is detergent in...
The water pressure moving through the main hose siphons detergent out of the tank as long as you are pressure washing. It might take some time before you see the detergent coming out the nozzle.
Sep 04, 2011 | Garden
Preasure washer want preasure up. engine runs find but wand want kick into high preasure
Start the engine on your pressure cleaner then with your lance change it to low pressure as if you were applying detergent i think your model has the 5 different quickfit jets put the large derergent one in and give it a hit...
Then put the high pressure jet back in and see if it will build up pressure now, if this works then your bypass/unloader valve is sticking in the head it will need removing and cleaning up and lubricating...
This is the most common cause of not building up pressure and is usually caused by sitting around and not using the pressure cleaner regulary...
Good Luck!!! Hope this helps
Kind Regards
Brad
Jan 03, 2010 | Karcher 2500 PSI Pressure Washer
Pump working - no pressure from hose. B2002?
Sounds to me that you may have a blocked high pressure jet.
Dec 13, 2009 | Karcher K2.26 Electric Power Washer
Poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Pressure washer doesn't get up to high pressure
what model of pressure washer? is it sucking out of a barrel or is it on mains water pressure.?
do you have detergent on this machine?
a bit more info will help a lot.
bit like ringing the garage and saying my car wont start, what do you think it is?
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
Bosch aquatak 120i pressure washer/tetergent
Hi hope i can help!!
Try this empty the detergent tank then have your machine ready to work then half fill the tank with warm water and use the machine, this may take a few attempts so dont think its a 5 min fix! What happends is the detergent when left in the machine goes thick and gooy the warm water thins this and eventualy cleans it out but dont use boiling hot water this may damage the seals.before storing machine away do this method.
Hope this helps .Sean
Mar 02, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
