Question about Crosley CFFH10W Top Freezer Refrigerator
I want to know the year in which the refrigerator was made
I have a refrigerator Crosley model number CT17A2W serial number 12128123SS, i want to know what which year it was made, itry to look for the date inside and behind the fridge but i found nothing. thanks for your help
  • elatifa13 Jun 19, 2009
    i don't know
Basti
  • 1447 Answers
SOURCE: Crosley Refrigerator Nent196H BM7A81A
Hi-
Chances are you need to check the freon for the refrigerator. It might dried up. You need to call or bring this over to a service technician.
Thanks for using Fixya!
Posted on Jul 21, 2008
peyton32034
  • 410 Answers
SOURCE: Crosley Servidor WCR17/E K3 Top Shelf and Drain Plug Freezes Over
first thing I would suggest is to flush the drain line. defrost any ice in the drain and then flush warm water thru the line until it flows freelyif  your having a hard time getting the line flushed out you may try using a large syringe or turrkey baster filled with warm water to forcfully flush water thru the line. this will most likely fix the problem.
you didnt mention if food was freezing in the refrig as well as the drain but there may be an off chance that the temperature control could be bad. since this is a manual defrost unit it depends on above freezing temps to help keep frost off of the cooling coil. if the temp control goes bad it will allow sub-freezing temps and possible drain freeze ups. so if the drain continues to freeze you will need to replace the temperature control.
if it comes to that, the control actually has a part number on it since maytag cant find your model number.
message me back if you have any further questions. thx peyton
Posted on Jan 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Posted on Mar 29, 2009
woodchuck789
  • 4070 Answers
SOURCE: crosley conservator is freezing, fridge not cooling
No, it is not normal. The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 05, 2009
localwonder
  • 6784 Answers
SOURCE: I have a Frigidaire refrigerator Model#
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Dec 04, 2009
I want to find the year of fabrication of my refrigerator. Thanks
Hello;
There is a label on the inside wall of your fresh food section with this information.
May 01, 2015 | Refrigerators
How muc`h is a door handle for a Crosley Shelvador 1952 model?
The one shown in the link below is $20.90. However, you will need your exact model number to be sure it's the right one.
Crosley Refrigerator Handle 218428101
Dec 09, 2014 | Crosley Refrigerators
I have a Whirlpool side -by- side 25 cu.ft. want to know about what age it is?
Hi.
It depends on the model number. Whirlpool started building 25 cu.ft over ten years ago and the model is still being produced. Please find the serial and number printed on the refrigerator service tag and give us the complete model number along with serial number. The model number will tell us the initial date of production, the serial number tells us the date of production of the specific unit. Here whirlpool date codes explained. To find the service tag check in locations illustrated below.
Aug 19, 2011 | Refrigerators
I need to know wich refrigerant a crosley window a/c uses model#CEA8M serial#IK75091108 and also if it is possible to use R-22 thank you
look on the data plate it will tell you the refrigerant.. its R/22 i bet... if its a real new one it may have the 410-A .but very doubtful because its a window unit ..let me know ..good luck/joe/
Aug 25, 2010 | Crosley Heating & Cooling
What year was the hotpoint refrigerator CTX21DA made?
Good day,
Sorry, but this is what they came back with...
Quote: This product could have been manufactured April of 1974 or 1986 or 1998 or 2010.
Jan 24, 2010 | Refrigerators
Freezerless Crosley Model FFoR18/W3. What kind of refrigerant does it use?
It should tell on the model/serial number ID tag the type of refrigerant and how much it takes.
Jun 30, 2009 | Crosley CFFH10W Top Freezer Refrigerator
What was the year of manufacture for refrigerator model HMG211747
go to this web site servicematters.com you will need the serial number off of your refrig. this is a maytag and whirlpool site but admiral is made by maytag. remember to use the serial number NOT the model number. thanks Peyton
Mar 12, 2009 | Refrigerators
Frig recall which model? Maytag refrigerator MTB2156GE* heard report of recall due to possible fire hazard
Name of product: Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand refrigerators
Units: About 1.6 million
Manufacturer: Maytag Corp., of Newton, Iowa
Hazard: An electrical failure in the relay, the component that turns on the refrigerator’s compressor, can cause overheating and pose a serious fire hazard.
Incidents/Injuries: Maytag has received 41 reports of refrigerator relay ignition, including 16 reports of property damage ranging from smoke damage to extensive kitchen damage.
Description: The recall includes certain Maytag®, Jenn-Air®, Amana®, Admiral®, Magic Chef®, Performa by Maytag® and Crosley® brand side by side and top freezer refrigerators. The affected refrigerators were manufactured in black, bisque, white and stainless steel. They have model and serial numbers printed on a label located on the top middle or left upper side of the refrigerator liner and have the following model and serial number combinations:
Serial Numbers ENDING with AND Model Numbers BEGINNING with Side by Side
Refrigerators AA, AC, AE, AG, AJ, AL, AN, AP, AR,
AT, AV, AX, CA, CC, CE, CG, CJ, CL,
ZB, ZD, ZF, ZH, ZK, ZM, ZQ, ZS, ZU,
ZW, ZY, ZZ ARS, CS, JC, JS, MS, MZ, PS Top Freezer
AT, AV, AX, ZK, ZM, ZQ, ZS, ZU, ZW,
ZY, ZZ AT, CT, MT, PT Refrigerators with freezers on the bottom are not included in this recall.
Sold at: Department and appliance stores and by homebuilders nationwide from January 2001 through January 2004 for between about $350 and $1600.
Manufactured in: United States
Remedy: Consumers should immediately contact Maytag to determine if their refrigerator is included in the recall and to schedule a free in-home repair. Consumers should not return the refrigerator to the retailer where it was purchased.
Consumer Contact: For more information, contact Maytag toll-free at (866) 533-9817 anytime,
Mar 10, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
Help Ice Maker problems
I'm not familiar with Crosley but you can get advice and parts from repairclinic.com but first of all find the model number & serial number. This is a great site for appliance
repair. Ken
Nov 24, 2017 | Crosley Refrigerators
Refrigerators Logo
151 people viewed this question
Top Crosley Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
fta777
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
