Question about Intersource Enterprises Co Ltd Adventurer Six-Speed Folding Bike
Where can I get part numbers and purchase parts for 6 speed adventure folding bike
Chain guide
How do the gears work
Have a read and watch some videos.
  • How do Bike Gears Work? ' Design Squad - YouTube www.youtube.com/watch?v=oauDyIu_swM
    • BY DESIGN SQUAD GLOBAL
    • 3 MIN
    • 107K VIEWS
    2012-10-12 · How do Bike Gears Work? ' Design Squad ... What Is Inside A Bike Freewheel/How Does It Work? - Duration: 3:56. RJ The Bike Guy ...
  • Bicycle Gears - How Bicycles Work ' HowStuffWorks adventure.howstuffworks.com/outdoor-activities/biking/bicycle3.htm Bicycle Gears - Bicycles aren't just for kids. ... How Bicycles Work. by Marshall Brain Adventure ' Biking. Bicycle Gears. Prev Next . You have ...
  • Bike Gears: How Do They Work - Sportive Cyclist sportivecyclist.com/bike-gears-how-do-they-work Now, if you'd like to learn more about bike gears, and chainsets in particular ... Bike Gears: How Do They Work (learn what terms like '53/19? mean) ...
  • Bicycle gearing - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Bicycle_gearing Bicycle gearing is the aspect of a bicycle drivetrain that determines the relation between the cadence, ... Hub gears work using internal planetary, ...
  • How to use Bicycle Gears ' Gears on a Bike bicycleuniverse.info/eqp/gears.html How to use Bicycle Gears. ... This works because the higher gears move you farther for each spin of the pedals, making you do more "work" ...
  • Hub gear - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Hub_gear A hub gear, internal-gear hub, or just gear hub is a ... 1959 Elizabethan Apr. 35/1 My lightweight bike with 4-speed hub gear ...
  • Technique: How to use your gears efficiently ' Total Women ... totalwomenscycling.com/...how-to-use-your-gears-efficiently-9497 Total Women's Cycling . ... Find out how to change gears on a bike and learn to use your gears efficiently, ... Liked this guide on how to use your gears efficiently?
  • How do bicycle gears work? - Ask.com www.ask.com > ... > Biking & Cycling > Bicycles Bicycle gears work by moving the bike's chain on varying chainring and cog combinations to match the desired drive wheel speed, cadence and pedaling speed of ...
  • Apr 21, 2016 | Cycling
    Where can I find a manual for a Falcon adventurer bike? I haven't ridden it for a few years and can't remember how to work the gears
    It means its an 18 speed bike. The shifting is easy. Start with the left side, begin riding, keep pedaling, don't stop pedaling in ther middle of a shift, it will throw the chain. As you ride, twist the shift grip, up and back. Still pedaling? Now after you have tried that one, try the other side, its the rear with 6 gears. Up and back, keep pedaling. After you have tried each individually, try them together. And now you're shifting. Looking good
    . KEEP Pedaling
    Sep 21, 2014 | Cycling
    How can you tell how old KTM 85 is
    serial number on engine and frame ! shape and design of plastics and bike as most years have some sort of change ! take pictures and numbers to KTM dealer !
    Feb 13, 2014 | Saddlemen Standard Adventure Track...
    Chain keeps comming off
    Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
    It sounds like you are dealing with a stretched chain. If the chain will not tension any further, you may be looking at the need to purchase a new chain. Use your model and serial number at the following link to order a new chain.
    Bike Parts for LifeFitness LifeCycle 9500 Upright Belts Pedals Seats...
    Jan 29, 2014 | Life Fitness Lifecycle 9500 Upright...
    I purchased an Adventurer Electric Folding Bicycle from Camping World in 2012. I would like to purchase a lithium Ion Battery for this bike. Camping World no longer carries this product. I am told that...
    As usual it would be good to give an approximate area in the world that you are at for anyone to answer a question of this sort. I live in Ontario Canada by the way. Many in here live in Africa, Asia, Europe, South America And Australia, some even live in the USA.
    Oct 25, 2013 | Electric Cycling
    I need to change the rear gear sprocket, but don't know what speed the mountain bike is. How can I tell what speed the bike is.
    Count the cogs, duh. You're going to need some help even after you know if it's 6-, 7-, 8, 9- or 10-speed in the rear. Special tools and 'how-to' knowledge. Take it to a Bicycle Shop an experienced DIY cycling friend.
    http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
    Sep 01, 2011 | Cycling
    How to make a 2005 ktm 50 mini adventure faster with out parts
    Thank you for contacting FixYa with your inquiry.
    If the bike is running correctly and RPM's through all the gearing range you are probably at the bikes optimum speed range with present set up as is.
    If it's down on power or faltering while running we probably need to do some tuning or replacement of power components (Piston & Rings, Gaskets etc....) Check the spark plug after running and make sure it's a cocoa brown color and the jetting should be correct. Check the manual for jetting instructions if the color is off.
    The simplest speed increase is gearing (requires some in-expensive parts). Easiest way is to go up one tooth on the primary sprocket and add a master or half link to the chain (if needed) to adjust the length. Would try only 1 tooth increase at a time to test.
    In Oregon we many times use the stock primary sprocket when running in the mountains, up one tooth for running in the desert, and up 2 teeth on the primary when running over 100mph down in Mexico. This mostly applies to the big bikes but it's the same for the mini's.
    Hope this helps and thanks again for contacting FixYa.
    TF
    Jul 04, 2011 | 2005 KTM 50 Mini Adventure
    Schwinn S40 DSX part name
    Forget new guide wheels. A new rear derailer is the real fix. You will need to order a new one by the number of gears on the rear gear cluster. How the derailer is mounted, Which way it moves when by the spring direction etc... By the way, get a higher quality one than the one you have got. If you go megawheel on the lower guide wheel; which I recommend, you might need a couple more segments in your chain. Yes, you need a new chain. If you wore out a part on you derailer, your chain is getting old. I recently bought a new rear derailure for my wife's bike for 29 bucks at a much better quality than the old one. It does not have problems of getting between gears, clicking etc... like the old one did new.
    May 30, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
    I need a grip shifter falcon MLG-26i dyna grip 6 speed where can i locate one thanks
    You can purchase a new 6 speed SRAM grif shifter for about $9.00 on Cambria Bikes.com They even come with derailleur cables installed!
    I purchased a few 6 and 7 speed versions for my bikes, and they work fine.
    Jan 03, 2009 | Cycling
    Intersource Enterprises Co Ltd Adventurer Six-Speed Folding Bike Logo
    46 people viewed this question
    Top Intersource Enterprises Co Ltd Cycling Experts
    Michial Gueffroy
    Andrew Taylor
    Andrew Taylor
    Are you an Intersource Enterprises Co Ltd Cycling Expert? Answer questions, earn points and help others
