Question about Panasonic Audio Players & Recorders
Panasonic replaced ic
Hello everyone..good day,can i ask what is the replacement of this ic part number LA4645,i can't find anymore in electronics store,thank you!
    New Friend:
  • 33 Answers
Check ebay and china website for second hand one.
Posted on Apr 21, 2014
Anybody knows what is the replacement of IC LA 4645 SANYO [Sanyo Semicon Device]
Hi try http://www.donberg.ie bit expensive but they sell them?
Oct 22, 2014 | Electronics - Others
I have a panasonic PT-47wxc43 projection tv. I have green and purple halos coming up from the bottom. The screen has purple and green double images which are worse from the bottom up.
This problem is due to convergence output ICs failure and both chips will be replaced to fix the issue.
There are two big black ICs installed with aluminum heat sink on deflection board, these are convergence output ICs and will be replaced to correct the problem, it is common problem of rear projection tv.
Below image of deflection shows ICs (marked in red) that are need to be replaced.
IC number is STK392-110 and available with Part Store for $32 each.
Click above link to see an image of IC.
If you are handy with electronics stuff repair and can replace parts in tv circuit board then can replace these parts yourself or ask local tech to help you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
May 25, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
2002 samsung rear projection tv wont turn on
Go to this website they will List Parts and Part Number for this Model Your STK ICS need to be replaced or convergence board that has ICs on it!. ICs will have Part # on them STK392-020 Encompass Parts Distrubtion
1-800-638-3328
For ICs Call Mats Electronics 1-800-628-1118 If you are able to repair/replace just ICs replace 2 resistors also 3.9 ohms or 2.7ohms in front of ICs
Mar 21, 2010 | Samsung HCM4215W 42" Rear Projection...
Please seeking help on how Ican get IC NUMBER LA 4645 FOR RADIO PANASONIC RX-DT 707 COBRA.
A vendor I frequently use is Encompass. They list the part here. You might try contacting them and find out if they actually can get the IC. It says there are none in stock, a special order item, but say 6 day ship time after you buy it.
I haven't been able to locate a replacement part number for the LA4645. Seems that there is no exact replacement by another manufacturer.
Good luck with your repair!
Feb 16, 2010 | Audio Players & Recorders
What is conversion problems and how do I fix it on a 47 inch panasonic rear projection tv
Replace Both of your STK ICs they are big black ICs will have Part number on them Call Mats Electronics for Parts 1-800-628-1118 STKs are your convergence ICs
Nov 13, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red ,Blue and Yellow lines off,curving inword from top and bottom
Its failure of 2 convergence out ICs and requires replacement.
You can replace these ICs if you have basic electronics knowledge and good soldering experience. let me know to provide you more info about parts.
Feb 20, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Have a pioneer SD-532HD5. The red convergence is way out and curved. I am looking for the replacement numbers and where to purchase new ic's. From reading online this seems to be the solution. Does this...
Convergence ICs STK392-110s upgrade to STK392-180s Better ICs you will also need silicon heat sink compound to put on New ICs,so they dont conduct alot of heat from heat sink they are mounted too.For Parts www.electronix.com or Call 1-800-223-3205. Another compay Acme Parts 1-800-575-9833 www.acme-sales.net If you need anymore help let me know ,Thank you and have a nice Day.
Jan 03, 2009 | Televison & Video
Panasonic PT-56TW53 56 in. Rear Projection Television- won't turn on -flashes 3 red lights- what's up? Turns on for a second, then it turns off and red light flashes 3 times... I've seen several other...
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part numberAA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Feb 16, 2018 | Panasonic PT-56TW53 56" Rear Projection...
Convergence
Next to the ICs you will see about 6 or 7 resistors with no color bands usually green in panasonic they all look identical. Check them with a ohms meter to see if any are open. The ICs usually take out one or two of these resistors when they go out.
Jan 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence adjustments
did you use the proper STK IC's Do the replacement IC's have SANYO on the face of them? If they do not, this could be your problem. You must use the IC that the manufacturer recommends. All IC's are not alike. Go to MCM electronics and enter your IC number and they sell original SANYO IC's. Good Luck
Jul 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
67 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
