Question about Lenovo 3000 Y410 Notebook
After bios update my laptop wont boot only network boot option is there.
    Master:
  • 409 Answers
You need to enter the BIOS and configure it. Though there is usually not much to configure in a standard Laptop BIOS. Can you Reload the older one ?
Posted on Apr 21, 2014
Can you boot from usb on a sony vaio pcg-9s1l
You may need to "Flash" (Update) the Bios. To do this, go online and download the latest Bios update for your machine.
Unzip the downloaded file and place it on an empty Memory stick.
Insert the memory stick and restart your machine. The Bios update should install.
Wait for the process to finish and then see if you now have the option in Bios>Boot Options to Boot from USB.
May 14, 2014 | Sony VAIO Notebook
Need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Jun 06, 2012 | Toshiba satellite c660
I have a Ntdetect Failed promt on toshiba p15-s479 laptop
LOL, sounds like you've got it trying to reboot from a Network or Lan first. Go back into the Bios and change the boot sequence to make the CD Drive your first boot option and the Hard Drive your second boot option.
You will want to boot from the CD to get the operating system installed. After it is installed be sure to remove the cd otherwise it will try to boot from it. Best option would be to go back into the bios and make the hard drive your first boot option after you get everything loaded.
You might be able to direct the system to boot from the cd as soon as you press the power button. Most systems will post an option to hit a certain key to get into the Bios or System Setup and a key to change the Boot order just for this one time.
Apr 21, 2012 | Toshiba Satellite P15-S479 Notebook
Dv6000 will not startup ,Black screen , hd isnit being accessed
When you first turn the laptop on is there a HP splash screen? Can you enter the BIOS (normally by tapping F2 or Del key). If so then it would seem the BIOS updated OK. If when you turn it on there is nothing the BIOS flash probably went wrong and the machine will need a new BIOS flash chip installed.
If you can access BIOS then it may be a simple problem that the new BIOS reverted to default values. The most common issue would be the boot mode of the HDD. Look through the BIOS menus and there should be an option for boot which will say AHCI/IDE/Compatibility. Try changing it to another option, save and exit BIOS and see if that helps. Try this for each option.
Alternatively tap F8 continuously when you turn the laptop on and see if the advanced boot menu appears, if it does try selecting Safe mode with networking.
Finally to test if the HDD is actually working, try downloading Hiren's BootCD and boot to it. Then run some HDD diagnostics to see if the HDD is operating correctly.
Hope this helps,
www.PuterCare.com
Jul 07, 2010 | HP Pavilion dv6000z Notebook
When i start up my computer (Accer 4230) i get this message "UNDI PXE 2.0, Media test failure, check cable, exiting PXE ROM. The message repeats over and over and it wont start up. I don't have an...
Start the computer and hit the F2 key until you get into the BIOS. When in the BIOS you can see in the Main/general page whether the hard drive is seen by the system. You will see HDD (hard drive) CD-ROM which is the optical disk drive.
If you see the hard drive the look for boot options in the tabs. When you get to boot options set the HDD as the first boot device, save the settings and exit the BIOS.
Hopefully the laptop will restart and boot from the hard drive, thus into Windows.
If the hard drive is not seen in the BIOS then the hard drive has failed and needs replacing.
If you have a BIOS password then start the computer hit F12 repeatedly until you see the boot option menu and choose the HDD.
Regards.
Feb 09, 2010 | Acer TravelMate 4230-6499 Notebook
This morning i got a update for windows.. well!! i updated it and then a error screen came on.. i tried to reboot the note book but its stuck in windows boot manager screen.. my lap top wont shut down.....
Boot into safe mode then go to system restore and restore it to before the update or go to control panel and uninstall the update.
To boot into safe mode:
Right after bios loads up and before windows starts loading start hitting the F8 key
Choose safe mode with or without networking doesn't matter
Nov 09, 2009 | Dell Inspiron 1525 Laptop
Resource Conflict - PCI in slot 03 acer aspire 1500
Try to Disable Boot from Network Option in BIOS
.if still the problem persists,Update the Last BIOS available for this LAPTOP this should be fixup
PP
Nov 05, 2009 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
Acer 1670 laptop will not boot in to bios
If what has happened is true, then the previous owner had killed the BIOS. He has tried to FLASH the BIOS and it failed. This then renderes the motherboard DEAD. Your only option is to try and find a replacement motherboard.
Aug 31, 2007 | Acer Aspire 3680 Laptop
Lenovo 3000 Y410 Notebook Logo
24 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
