Question about Jackson 25 in. Conserver XL Free-standing Dishwasher
Furnas J106814 reversing drum switch for Garbage diaposal needs replacement. Has 4 terminals on each side
I have a pilot light but furnace will not kick on,we replace control module but still will not kick on
your positive you have the gas turned on going to this furnas?
also make sure the power going to the furnace is on, it should have a switch with a fuse located close to it and the switch may be off or the fuse is blown out.
if so does the control valve have 2 wires going out to the t-state? if so for a test jumper those wires either at the furnas or at the t-state and see if the furnace turns on, don't forget to remove the jumper as the furnace will not shut off if you don't, this is just to test the wires and or valve.
Sep 27, 2017 | Heating & Cooling
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
Overfilling
Check the pressure switch and ensure small hose is attached and intact, this located at the rear of the drum, to gain access and lift the top cover, insert a knife or thin blade approx. 4" in the from each side in between the seam on the front panel, this will release the top cover clips and the top cover can be hinged up and back. The pressure switch is at the rear of the drum and has a small 1/4" hose attached which also attaches to the drum low down, ensure the hose is not perished and is securely attached, if this is ok then replace switch, note wire positions and disconnect hose. switch may be tested by blowing in where hose goes and testing continuity across terminals, as you blow the contacts should open.
Dec 10, 2013 | Admiral Washing Machines
Replace garbage disposal shredder disc
Which direction does disposal blade turn?
For example when looking straight-on at the nut holding power saw blade, the blade rotates counterclockwise, so the nut is reverse thread.
Most disposals are not made for repairs
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Add a comment and say where you are getting the parts and which model
May 25, 2013 | Kenmore 3/4 hp Food Waste Disposer
Just wired up the gp24 ,connected mains,switch and nuetral, working on manual mode but clock not turning
Reverse wires on terminals 3 and 4
1) GP24 appears to be 24-Hour version of Greenbrook T100 series mechanical timer, with Grasslin analog time dial.
http://waterheatertimer.org/pdf/Green-brook-T100_CInstructions.pdf
http://waterheatertimer.org/How-to-set-timers.html
2) If clock is not rotating, then probably your wires are reversed.
Reverse wires on terminals 3 and 4.
3) Power from Mains, and wire to Load each have 2 wires.
Hot live from Mains connects to terminal 3
Neutral from mai9ns connects to terminal 1
Neutral going to load connects to terminal 1
Hot going to load connects to terminal 4
Dec 08, 2012 | Hardware & Accessories
Kenmore Elite Gas Dryer: Dryer does not dry clothes completely, even when I set the times for 80-minutes. I usually need to set the timer an additional 60-minutes resulting in 2-hrs + 20-minutes of dryer...
    • 1 Check the dryer's fuse if the dryer's drum operates but does not heat. The fuse may not be working properly if there is a break inside. If it happens to be broken, replace it with a new fuse.
    • 2 The dryer's heating will not function properly if the timer does not work. Fix a bad timer by disconnecting the leads from the motor and setting the Volt-Ohm, or VOM, to RX100. Clip off the probes onto the leads. If the timer is set on infinity, then it needs to be replaced.
    • 3 If the drum is no longer spinning, first check to see if the motor pulley is working correctly. If it is not, then it will need to be replaced. Once everything is dissembled, take time out to clean out the compartment with a vacuum to remove dust and lint.
    • 4 If the dryer still is not functioning, then the dryer's belt may be broken. To fix the dryer's belt, you'll have to replace it with a new one. Line up the replacement belt with markings on the drums seen on the damaged one. Wind it around both the motor pulley and the idler pulley.
    • 5 The roller also could be damaged if the dryer still continues to not work. Fix the damaged roller by removing the tumbler to gain access, then remove the retaining clip on the roller by sliding it off. Reverse the process to install a new one
    • 6 If the dryer is not working at all (when you turn it on by the switch and it still does not work), consider replacing the terminal block. Use the VOM to check for voltage at the terminal block. Use extreme caution as the power needs to be on to run this test. Call an experienced electrician for help if need be.
    • 7 If the dryer is not working still, test to see if the dryer's switches are working properly. Set the VOM to RX1 and get rid of one of the leads to the switch, clipping the probes to the switch's terminals. When the reader is switched to infinity, press the start button. If the reader does not switch to zero, then the switch is bad and needs to be replaced by a professional.
Oct 07, 2011 | Kenmore Elite HE4 Electric Dryer
I would like to connect a pressure switch to the motor starter
hi! there, single phase compressor motor need a starting capacitor base on the rated capacity in horse power,you can check this on the tag of the compressor motor how many horsepower was indicated,it should be for single phase motor starting capacitor has a capacity of micro farads.for a 1 horsepower = 15 to 18 micro farads stating capacitor if you have more than 1 horsepower you can basically proportion the value of capacitor you need or ask the dealer how much capacitor you need on your motor the connection of pressure switch with a four terminal should be connected both on common line L1 and running capacitor line L2 .if you open the cover of pressure switch there are 4 terminals,2 terminals are connected when normally close or no pressure they connected on series connection on the common line one terminal connected to common line of the compressor and the other terminal on L1 to the pushbutton switch to L1 supply line.the 2 other terminals also connected in series withe line capacitors L2 to yhr power supply line.hope this will help you a lot.just rate my fix thanks a lot.
Apr 20, 2010 | Air Tools & Compressors
Vent Motor on all the time, and blower & furnas won't start
make shure you dont have trash in your vent that would cause that or may be the fan inside is broken but if you **** on that tube it should come on and if thats the case check the flue and fan blade behind the motor even leaves in the blower wheel will mess with the pres inside that fan housing
Apr 06, 2010 | Heating & Cooling
We have a Lennox furnas. It runs on propane. Sometimes it will not come on. If we turn off the switch by the fuse before the furnas, it will usually come on. This is not 100%. I have installed a new...
The unit is locking out on a safety. Do you have the model number of the heater? How old is it? This may not be a minor problem. You may want to call a Lennox dealer to assist you.
Jan 01, 2010 | Heating & Cooling
Jackson 25 in. Conserver XL Free-standing Dishwasher Logo
129 people viewed this question
Top Jackson Dishwashers Experts
gbob59
jhnolson
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
