Question about General Electric Adora GHDA670N Built-in Dishwasher
Leaking around heating element posts that protrude through dishwasher body
    Problem Solver:
  • 8 Answers
Some dishwashers like your model number are under recall for a potential fire hazard due to water leaking through the heating element posts onto the wiring.
Your serial number must begin with the 2 letters listed . Below is the list of recall serial numbers: FL, GL, HL, LL, ML, VL, ZL, AM, DM, FM, GM, HM, LM, MM, RM, SM, TM, VM, ZM, AR, DR, FR, GR
Call the phone # below or check out GE recall website. What GE does is replace the element and gaskets, unless there is burnt or arcing visible on the wires, they may replace the dishwasher.
www.geappliances.com/products/recall
GE has determined that an electrical failure in the dishwasher's heating element can pose a fire hazard. GE will provide a free repair to all consumers with units affected by the recall. We ask that you not use your dishwasher until it is repaired and to disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire.
Consumers who instead wish to replace their dishwasher with a new model can receive a rebate towards the purchase of certain new GE and Profile brand dishwashers. Consumers can use a rebate of $75 for the purchase of certain GE front-control plastic tub dishwashers, or a GE rebate of $100 for the purchase of certain GE front-control stainless tub dishwashers or GE Profile top control dishwashers. See the rebate form for eligible models.
GE is aware of 15 reports of dishwasher heating element failures, seven of which resulted in fire and smoke damage beyond the unit. No injuries have been reported.
The model and serial numbers are important, as not all dishwashers are included in the recall. Look at the inside on the front left side of the dishwasher tub to find the model and serial number.
This recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission, which will also monitor the effectiveness of the recall program.
Recall Hotline
866-918-8760
Monday through Friday, 8 a.m. - 5 p.m. ET.
Before calling, have the model and serial numbers on hand.
Customer Care
Posted on Apr 25, 2014
How to change dishwasher heating element
Remove the dishwasher from the cabinet after disconnecting the water,power and drain. turn upside down to access the nuts that hold the element in. also replace the gaskets on the element or it will leak.
Mar 29, 2014 | Whirlpool Dishwashers
Miele heating element
sorry - may seem odd - but your hot water tank is set to 120 or higher yes ? so why are you re-heating you water? - if you want to know you need the 2000w /230v - but really turn the re heat off - at 120 you kill the bacteria and will save $$
Mar 20, 2014 | Dishwashers
Dishwasher won't dry.
run it and open it after the drying cycle right away. what you should be looking for is heat. you will see a metal rod going around the bottom of the dishwasher in a square shape either that has stopped working or the circuit shorted out some where, people don't usually know this but dishwashers use only cold water they use that element to heat the water.
good luck
Feb 10, 2011 | Kenmore Dishwashers
Dishwasher is not heating water and wont dry dishes.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element for mineral deposit on it, clean the deposits using a soft brush and a cleaning solution (Don't scrub the element hard). If this doesn't resolves the issue then remove the panel and examine all the wiring connections to the heating element. Now, use a multimeter and check for the resistance reading (ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Dishwashers
LEAKING FROM HEATING ELEMENT
try to screw the nut, check the gasket(seal) or replace the heatimg element whit similar new one (if it is possible whit an original- that wil resist much longher) when you posting a help request please post more detail for an exacly recomandation!
Feb 23, 2010 | Dishwashers
Water leak at heater element connection seal, rusted connection
Mlecha, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Mlecha), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool DU1055XTSQ Built-in Dishwasher
Element is loose
It would be helpful to know about your manufacturer and model number of dishwasher.
There are a couple ways that a heating element can be loose. If it is broken inside the dish washing space, then replacing it will fix that problem.
If the element is loose where one of the ends connects to the bottom of the dishwasher, there is a fair chance that your dishwasher is leaking water under it. That needs to be checked out quickly.
Look closely and see what the situation is. Post here if you need more assistance.
Good Luck!
Apr 10, 2009 | Dishwashers
Maytag MDB6100AWB is leaking around the heating element
There is a gasket on the heating element. You could turn off the power and tighten the heating element or replace the gasket. good luck cathy.
Jan 27, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Water leak
TIGHTENED NUT ON UNDERSIDE OF DISHWASHER WHERE THE HEATING ELEMENT GOES THROUGH.
Sep 12, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
May 20, 2008 | Kenmore 24 in. 15953 Built-in Dishwasher
General Electric Adora GHDA670N Built-in Dishwasher Logo
183 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
