Question about Canon Rebel XT / EOS 350D Digital Camera
Cleaning the contacts of my rebel xt canon
Clean contacts with eraser
jackboy
  • 2985 Answers
SOURCE: Canon Rebel XT Auto focus Error 1 Problem HELP
This is a camera body contacts problem Canon Customer support will advise what to do next
Posted on Jul 22, 2007
SOURCE: Error 99 only when flash pops up
We ended up sending the camera in to Canon. $200 unless they find something more wrong. Luckily we have my Nikon D80 still. I will say that Canon replied via e-mail fairly quickly and one paid, said 7-10 business days for the repair.
Posted on Dec 09, 2007
t00nz
  • 4738 Answers
SOURCE: CANON REBEL XT -CF card error
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, you may elect professional repair (likely more than you'd be willing to pay), or you might want to try the following.
Remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Jul 02, 2009
  • 7 Answers
SOURCE: Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Posted on Aug 22, 2009
  • 164 Answers
SOURCE: Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Posted on Aug 25, 2009
Digital rebel will not read memory card. get error 99
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks!
Feb 22, 2011 | Canon Rebel XT / EOS 350D Digital Camera
No Power To Canon Digital Rebel XT
I believe this post will help you out..
Please CLICK HERE
May 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
My Canon Rebel XT shows a CF Error , I changed the card and when I tried to format it shows error 99. THe Vattery is new and fully charged and right about the middle of the CF socket there are apparently...
Welcome to Fixya
Err 99 could means several different things, such as... Memory Card, Lens or Lens contacts....
Thanks for choosing Fixya!
Jan 27, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Err 99
Hello hemantp. This error code in this model indicates that the lens electrical contacts are dirty or slightly oxidized. To clean them you will need a common pencil with a clean eraser on the end and a lens cloth.
Detach the lens from the camera and hold it so that the lens' gold contacts are pointing down. Lightly "erase" their exposed surfaces and then clean them with the lens cloth to remove any debris.
Do the same with the gold contacts inside the camera body. Although this is a wee bit more challenging, you can do it by holding the camera so that the lens opening points down. That way no debris will fall inside as you clean. Joe
Nov 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
No power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
Aug 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon digital camera 350D
this will fix error 99 in canon cameras 1 you take the lens of
2. you take a new pencil the kind with a red eraser and use the eraser to lightly clean of the little gold contacts (make sure that the lens contacts are pointing down so that none on the eraser gunk gets in the lens) 3. now you lightly erase the contacts on the inside of the camera and make sure that now erasings get in the camera put the lens back on and turn you camera on!! Good Luck!! :) have a great day!!!
Apr 19, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I have a Canon EOS Digital Rebel XT with the original 18-55mm lense and a Quantarey 70-300mm lense. Have had all pieces for 3 years now and everything worked great until last night. Camera focuses and...
This means that the communication with the Quantarey lens is not the right one.
You can try in cleaning the lens contacts and the camera contacts with a pencil eraser or a white erase (flip down the camera so no particles get inside the mirror box).
If still you are having problems, then that means the Quantarey lens is defective, and either needs to be service to be repaired, or you will need to get another zoom lens.
Best regards,
Jul 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rbl XT out of focus in viewfndr when shutter half way down
It's possible that the reason the "pictures turn out fairly good" is that your f-stop is set high enough that even though the image isn't properly focused, you have enough depth-of-field to bring your subject into "near focus". Does your lens try to focus back and forth when you half-press the shutter? If not, double check that the lens is in autofocus and not manual focus. You can also try cleaning the contacts between the lens and camera. Take the lens off, and then one-at-a-time clean the contacts on both the lens and the camera, using a clean pencil eraser. Gently rub the contacts. Be sure to hold the item upside down so that the eraser debris falls on to the table, not into the camera body or lens!
If none of this helps the autofocus may have become damaged and you need to have the lens and camera looked at by Canon Repair.
Jan 10, 2009 | Canon Digital Rebel XT / EOS 350D Digital...
Problems getting Quantaray AF 70-300mm lens to work with Canon xt
you could try cleaning the contacts on the camera and lens with an pencil eraser
Nov 13, 2008 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Err 99
cleaning the contacts ought to be done using a pencil eraser(i am very specific about this)to fix this error
vigorously scrub the lens contacts with an eraser. Then  gently use the eraser to clean the camera contacts (holding the contacts face-down to prevent eraser rubber from falling into the body).Put the lens back on… and the camera shoudl be fixed!
Try this and post back before you rate..
Nov 01, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
14 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
