Question about Mitsubishi WD-65731 65" HDTV
I have a mitsubishi WD 6573TV. Sound Issue. Last night I came home and have picture but no sound. I completely powered it down and let it set overnight. Came in today had sound but could not control
I tried the input / Format reset as well as the small reset button under the front cover. Still not having any success. Hoping we dont have to buy a new TV.
    Master:
  • Mitsubishi Master
  • 687 Answers
Try a "REBOOT"
Reset, Initialization &
Option Menu
Front Panel Reset & Initialization
Many customer generated symptoms, intermittent symptoms
or symptoms that cannot be duplicated can be resolved
by performing resets or initialization from the front
panel. To avoid making nuisance service calls that may
not be covered under the warranty, ask the customer to
perform the following functions before going to their
home.
The most common are:
• System Reset (Re-boot)
• A/V Reset (Resets Customer Audio/Video
Settings)
• Initialization (Resets all customer options,
settings and menu items)
Use the Front Panel Guide as a reference to quickly
perform the desired function. Note: Button location may
differ by model.
The Reset - Initialization Guide details all resets and initialization
functions.
Front Panel Guide
FRONT PANEL
1) SYSTEM RESET1 - Reboots Set
(Same as Cycling AC Power)
Power LED will flash for about
1 minute.
2) A/V RESET2 <FORMAT+GUIDE>
Resets all Customer Audio/Video Settings
FORMAT GUIDE INPUT
ENTER CANCEL
SYSTEM
RESET
MENU
VOLUME
ADJUST
CH
ADJUST
3) INITIAL2 <FORMAT+INPUT>
Resets all Customer Menu and
A/V Settings
LED DIAGNOSTICS3 <INPUT+MENU>
In case of failure, a 2 digit error code will
be indicated by the POWER/TIMER LED.
1 Perform while the set is either On or Off. (See section on LED Diagnostics)
2 Perform while the set is On.
3 Perform while the set is Off.
Posted on May 15, 2014
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
ctf1800
  • 4402 Answers
SOURCE: mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Posted on Dec 08, 2007
Slinteriors
  • 8617 Answers
SOURCE: sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 01, 2008
  • 4 Answers
SOURCE: Can not change "Device" input, no sound control,no remote control
I unplugged the manual switch electrical connection. Everything works just fine with the remote.
Not sure what is wrong with the switches just yet, but suspect a resistor problem. I have checked all voltages and have 5.04 v feeding the switch assembly on what I feel are the correct circuits
(5v, ksco, ksc1, man/reset). I have no voltage on the ground circuit with the board plugged in, so the ground circuit should be ok. I have tested all switches with ohmmeter, all switches work. I suspect a resistor problem as I have one with no voltage drop and one resistor with no voltage pass-thru. Would need a wiring schematic with values to pinpoint better.
Posted on May 18, 2009
MNfisherman
  • 11896 Answers
SOURCE: No picture no sound....Mitsubishi WT-46809
Your Power supply will most likely have to be replaced. Very common, the capacitor's inside these units due tend to get overheated and burn out. You can test power coming from the power supply with a voltmeter
Posted on Sep 30, 2009
My WD 57733 will attempt to power up (almost like a whistling sound as it attempt to power up) then will power back down.
When was the last time you replaced the lamp? That sort of sounds like the ballast is unhappy with a bad lamp. The 57733 is a good TV. The other possibility is a stuck/dirty color wheel.
Check the lamp and see if it looks worn out(dark or grey in the tube down the center). Also make sure its either a Philips brand or Osram brand.
Let me know and Ill see what I can recommend next
Sep 12, 2016 | Mitsubishi WD-57733 57" HDTV
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
Dec 16, 2010 | Mitsubishi WD-65736 Television
No picture or sound
did you remove any covers,lamp or filter? unplug for a few and try again!
Jan 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd60737. It will turn on. Remote does work. Sound does work. But, the video won't show. It just stays black. There is a solid red light when it is off. Tried to reset it and it still did the...
make sure u set ur output to AV u will find this on ur remote control or on front of ur tv set
in regards ur tv will not show a picture since ur last adjustment try to go to menu and follow instruction how to set the tv back to factory setting......this may give u ur picture back......if not call mitsubishi service centre and tell them about ur problem u have......i am sure they will help u
Nov 28, 2009 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi wd-65831 one night worked fine next day nothin..
If you hear a whining noise, the odds are it is the color wheel, the bearings are bad in it and will need to be replaced as a whole unit, kinda pricey, my suggestion, sale the bulb and all boards in it and which should fetch about 400+ and invest in a new TV, a color wheel is pricey unless you can find a deal
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No sound from our WD-52525
does the picture clear?if does,check the sound output from the earphone if it is clear,if the sound is clear the problem is in the audio amplifier
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62327 no pix and no sound
First do the self diagnosis test, search threads here or go to www.ctechnicians.com
Dec 03, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-65731 65" HDTV Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
