Question about Raypak 2100 Pool Heater Gas 266000 BTU' (Pilot Light) ()
What is a high limit condition
Circuit board temp sensor failure light is on. heater will not light.
    Champion:
  • 305 Answers
Temp sensor failure. when sensor read temps that are way too cold or way too hot
Posted on May 10, 2014
Sundance 605 Series spa. Recently had the motor replaced, but now the motor runs continually. Installer said I need a new board. Is there anything else that could cause this?
When a spa runs continually it can be a bad board but we would have you replace the Temp Sensor first. If the spa is not heating it could be the pressure switch is not working or it could be the Temp Sensor or the High Limit sensor.
Check the topside panel to see if the heat indicator light is on. If it is NOT on then your pressure switch needs to be changed.
If the Heat indicator light IS on then you probably just need a Sensor.
It is always possible that the heater relay on the circuit board is bad.
Rod
US Parts Center
888-521-6183
Mar 31, 2013 | Pool & Spa
1995 dodge ram 1500 318 motor it wont get fire where is the logic module located
Under hood,passenger side mounted on the firewall,but ...
Could be something else ,crank sensor or cam,or ign.rotor ect.
The module like 3 hundred bucks.Try this ,turn the key
on-off-on-off-on( without out hitting the starter) the check
engine light should begin to flash.
Here is a code list,may narrow down the problem.
Diagnostic Trouble Code Descriptions and service hints. Fault Code DRB Display Code Description. Service hints. 11 No Crank reference signal at PCM No Distributor reference signal detected during engine cranking. Check the circuit between the distributor and PCM. 12 Battery Disconnect Direct Battery input to PCM disconnected within last 50 ignition key-on cycles. Normal if battery has been disconnected, otherwise check battery power and ground connections. 13** No change in MAP from start to run No difference seen between the engine MAP reading and the barometric (atmospheric) pressure reading at startup. Indicates a problem with the MAP sensor vacuum system. 14** MAP sensor voltage too low or too high MAP sensor voltage output is outside the acceptable range. 15** No Vehicle speed sensor signal No signal received from the vehicle speed sensor during road load operation. 17* Engine is cold too long Engine temperature too high or too low while traveling. Check coolant level, radiator cap, temperature sensor, and thermostat. 21** O2S Stays at center O2S shorted to voltage O2 sensor does not detect rich or lean condition, or O2 sensor input voltage too high. DRB will indicate which side with dual sensors. The O2 sensor signal should fluctuate under normal conditions. 22** ECT sensor voltage too high or too low Engine Coolant temperature sensor input out of normal range. Check engine temperature sensor. 23** Intake air temp sensor voltage too high or low Intake air manifold temperature sensor is out of range. Check sensor. 24** Throttle position sensor voltage too high or low TPS sensor is out of normal range. 25** Idle air control motor circuits A short is detected in one or more of the idle air motor circuits. 27* Injector # control circuit Injector number # output driver circuit does not respond to the control signal. Check the affected circuit. 31** EVAP Solenoid Circuit Short or open in the EVAP solenoid circuit. Check for loose, broken, or shorted wire in the charcoal canister purge solenoid wiring and connectors. 32** EGR Solenoid circuit Short or open in the EGR solenoid circuit. Check for loose, broken, or shorted wire in the EGR valve wiring and connectors. Possible air fuel ratio imbalance not detected during diagnosis. 33* AC clutch relay circuit Short or open in the AC clutch circuit. 34* Speed control circuit or speed control switch always low or high An open or short in the speed control vacuum or vent circuits. Speed control switch input above or below normal range. 35 Radiator Fan low speed relay circuit Open or short in the radiator fan relay wiring. 37** Torque converter clutch solenoid CKT or Trans temp sensor too high or low Open or short in CKT wiring or connectors. Voltage out of range at transmission temperature sensor input. See NOTE #1 below 41** Generator field not switching properly Open or short in the generator (alternator) field control (regulator) circuit. This indicates a problem with the charging circuit and the fault is set when the battery voltage from the ASD relay falls below 11.75 volts. Wiring, connectors, fuses, and the ASD relay should be checked. A shorted battery cell can also trigger this fault. 42* Auto shutdown relay circuit Open or short in the ASD relay wiring or connectors. 43** Ignition coil circuit # Open or short in number # coil circuit. Indicates that the ignition coil's peak primary circuit current is not achieved with the maximum dwell time. 44* Battery temp sensor volts out of range An open or short in the engine coolant temperature sensor circuit or a problem in the PCM's battery temperature circuit. 45* Trans OD solenoid circuit Transmission OD solenoid circuit failure. Open or short in the transmission overdrive solenoid circuit. 46** Charging system voltage too high Battery voltage sense input above target charging voltage during engine operation. Computer is indicating that the battery voltage is not being regulated. 47** Charging system voltage too low Battery voltage sense input above target charging voltage during engine operation. Also, no significant change in battery voltage was detected during a test of the generator output. 51** System lean L-Idle Adap at rich limit or lean R-Idle Adap at rich limit O2 sensor signal indicates lean air/fuel ratio during engine operation. The computer ran the mixture to the rich limit of programming, but the O2 sensor still indicated a lean condition. L or R indicate left or right side O2 sensor. Fuel pressure problems can lean the mixture and set this fault. 52** System rich L-Idle Adap at lean limit or rich R-Idle Adap at lean limit O2 sensor signal indicates rich air/fuel ratio during engine operation. The computer ran the mixture to the lean limit of programming, but the O2 sensor still indicated a rich condition. L or R indicate left or right side O2 sensor. Faulty ignition components, high or low fuel pressure, or leaking injectors can set this fault. 53* Internal PCM failure or PCM SPI comm failure An internal PCM failure or PCM communications failure has been detected. 54* No cam sync signal at PCM No fuel sync (camshaft signal) detected during engine crank. No camshaft position sensor signal was received from the distributor. Problem with the distributor synchronization circuit. 55 N/A End of message code. A DTC 55 is used to end all DTC messages. This code does not show on the DRB tool and indicates a completion of the stored codes on the Malfunction Indicator Lamp (check engine lamp). 62* PCM failure SRI miles not stored Unsuccessful attempt to update Service Reminder Indicator miles in the PCM EEPROM (memory). 63* PCM Failure EEPROM write denied Unsuccessful attempt to write and EEPROM location by the PCM. Controller failure, check the PCM. This code can be set when attempting an unauthorized reprogram of the PCM. 71** Aux 5V signal voltage low The auxiliary 5 volt supply output voltage is low. The 5 volt output signal is not reaching the required voltage level. 72** Catalytic Converter efficiency failure The catalytic converter is not converting emissions in the proper ratio.
Feb 22, 2013 | Cars & Trucks
P-1193
P1193 - INLET AIR TEMP SENSOR VOLTAGE HIGH
WHEN MONITORED
With the ignition ON and battery voltage greater than 10.4 volts .
SET CONDITION
The inlet air temperature sensor circuit voltage at the PCM goes above 4.9 volts .
POSSIBLE CAUSES
  • Intermittent condition
  • IAT sensor signal circuit shorted to battery voltage
  • IAT sensor internal failure
  • IAT sensor signal circuit open
  • Sensor ground circuit open
Hope helps.
Apr 28, 2011 | 2003 Chrysler Town & Country
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Ge true temp oven with an F1 code...what is it...model #J KP15AOA
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Feb 10, 2010 | Kitchen Ranges
Lock light flashing after cleaning. Will not
OK, what has happen here is, the actual temp sensor has failed during the cleaning process, this has cause a temp that reached a dramatic high range(above 915F-930F). At these temps, there will be major damage that will weld the contacts on the door lock switch mechanism and control board.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches for faults as well(welded contacts and burned wiring harness)
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 23, 2009 | GE Ovens
Service light comes on our Raypak RP 2100 pool heater.
this usually indicates a high limit condition.you must first ascertain if you have a component failure or a true high tempature condition.your model has 2 limit controls and they are both located in side panel on water in/out header
Sep 16, 2009 | Raypak Pool & Spa
Error codes, oil pressure sensor and engine control moduale
Hello, It should actually be an oil sending unit, and is located on the back of the intake manifold to the left of the distributor. *The P0523 is Oil Pressure Sending Unit Voltage too high *P1693 Generic fault indicating a fault in the bus or PCM/ECM interface *P1682 - I can't find this code Anyways, I will post here all the error codes for future reference. Dodge Cummins Check Engine Error Codes Cycle Key on-off-on-off-on to read codes in odometer display P0002 ECM fuel calibration error P0016 Crankshaft/Camshaft Timing Misalignment/Out-of- Sync P0071 Ambient Temperature Sensor Performance / Rationality P0072 Ambient Temperature Sensor Low P0073 Ambient Temperature Sensor High P0088 Fuel Rail Pressure Too High P0106 Manifold Absolute Pressure Sensor Performance / Rationality P0107 Manifold Absolute Pressure Sensor Low P0108 Manifold Absolute Pressure Sensor High P0111 Intake Air / Charge Temperature Sensor Performance / Rationality P0112 Intake Air / Charge Temperature Sensor Low P0113 Intake Air / Charge Temperature Sensor High P0116 Engine Coolant Temperature Sensor Performance / Rationality P0117 Engine Coolant Temperature Sensor Low P0118 Engine Coolant Temperature Sensor High P0121 Accelerator Position Sensor (APPS) Signal Voltage Too Low P0122 Accelerator Position Sensor (APPS) LowAPPS Voltage Input Too Low P0123 Accelerator Position Sensor (APPS) Signal Voltage Too High P0128 Cooling System Error / Thermostat Rationality P0148 Fuel Delivery Error P0168 Fuel Temp Too High P0169 Water-in-Fuel Detected For Too Long P0192 Fuel Rail Pressure Sensor Low P0193 Fuel Rail Pressure Sensor High P0201 Fuel Injector 1 Circuit P0202 Fuel Injector 2 Circuit P0203 Fuel Injector 3 Circuit P0204 Fuel Injector 4 Circuit P0205 Fuel Injector 5 Circuit P0206 Fuel Injector 6 Circuit P0216 Fuel Injection pump Timing Malfunciton [new injector pump time] P0217 Coolant Temperature Too High P0219 Engine Overspeed P0230 Transfer pump circuit out of range P0234 Turbocharger Overboost Condition P0235 Turbocharger Boost Sensor A Circuit P0236 Turbocharger Boost Pressure Sensor Performance / Rationality P0237 Turbocharger Boost Pressure Sensor Low P0238 Turbocharger Boost Pressure Sensor High P0251 Fuel Injection Pump Mechanical Failure Fuel Valve Feedback Circuit P0252 Injection Pump Fuel Metering Control "A" Range/Performance P0253 Fuel Injection Pump Fuel Valve Open Circuit P0254 Fuel Injection Pump Fuel Valve Current Too High P0300 Multiple Cylinder Misfire P0301 Cylinder 1 Misfire P0302 Cylinder 2 Misfire P0303 Cylinder 3 Misfire P0304 Cylinder 4 Misfire P0305 Cylinder 5 Misfire P0306 Cylinder 6 Misfire P0335 Crankshaft Position Sensor Circuit P0336 Crankshaft Position Sensor Performance P0337 Crankshaft Position Sensor Circuit Low P0338 Crankshaft Position Sensor Circuit High P0340 Camshaft Position Sensor Circuit P0341 Camshaft Position Sensor Performance / Rationality P0370 Timing Reference High Resolution Signal "A" P0380 Intake Air Heater #1 Control circuit P0381 Wait-to-Start Lamp Inoperative P0382 Intake Air Heater #2 Control circuit P0460 Fuel Level Sensor A Circuit P0461 Fuel Level Sensor 1 Performance / Rationality P0462 Fuel Level Sensor 1 Low P0463 Fuel Level Sensor 1 High P0477 Exhaust Pressure Control Relay Low P0478 Exhaust Pressure Control Relay High P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay) P0483 Cooling Fan Speed P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1 P0514 Battery Temperature Sensor Performance / Rationality P0516 Battery Temperature Sensor Low P0517 Battery Temperature Sensor High P0521 Oil Pressure Sensor Performance / Rationality P0522 Engine Oil Pressure Sensor/Switch Circuit Low Input P0523 Oil Pressure Sending Unit Voltage too high P0524 Oil Pressure Too Low P0532 A/C Pressure Sensor Low P0533 A/C Pressure Sensor High P0541 Intake Air Heater Relay 1 Low P0542 Intake Air Heater Relay 1 High P0562 Battery Voltage Low P0563 Battery Voltage High P0572 Brake Switch 1 Low P0573 Brake Switch 1 High P0576 Cruise Control Input Circuit Low P0580 Speed Control Multiplexed Switch 1 Low P0581 Speed Control Multiplexed Switch 1 High P0602 Control Module Programming Error/NotProgrammed P0604 Internal Control Module RAM Integrity Failure P0606 Internal ECM Processor P0607 ECU Internal Performance P0622 Generator Field Control Circuit P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High P0630 VIN Not Programmed in PCM P0633 SKIM Key Not Programmed in PCM P0642 Sensor Reference Voltage 1 Circuit Low P0643 Sensor Reference Voltage 1 Circuit High P0646 A/C Clutch Relay Circuit Low P0647 A/C Clutch Relay Circuit High P0652 Sensor Reference Voltage 2 Circuit Low P0653 Sensor Reference Voltage 2 Circuit High P0698 Sensor Reference Voltage 3 Circuit Low P0699 Sensor Reference Voltage 3 Circuit High P0700 Transmission Control System (MIL Request) P0743 Torque Converter Clutch Circuit Electrical P0753 Shift Solenoid "A" Electrical P0837 Four Wheel Drive (4WD) Switch Performance / Rationality P0838 Four Wheel Drive (4WD) Switch Circuit Low P0839 Four Wheel Drive (4WD) Switch Circuit High P1488 Auxiliary 5 volt supply output is too low P1492 Ambient/batt temp sensor volts too high P1493 Ambient/batt temp sensor volts too low P1596 Speed Control Switch always high P1597 Speed Control Switch always low P1652 J1850 Communication Bus P1687 No Cluster BUS Message or No Messages from the Mechanical Instrument Cluster P1688 Internal Fuel Injection Pump Controller Failure P1689 No Communication Between ECM & Injection Pump Module P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor P1691 Fuel Injection Pump Controller Calibration Failure P1693 Generic fault indicating a fault in the bus or PCM/ECM interface P1757 Governor pressure is above 3 PSI when 0 PSI is requested P1762 Governor Press Sensor Offset Volts Too Low or Too High P1765 Transmission 12 volt supply relay control circuit P2121 Pedal Position Sensor 1 Performance / Rationality P2122 Pedal Position Sensor 1 Low P2123 Pedal Position Sensor 1 High P2127 Pedal Validation Switch 2 Low P2128 Pedal Validation Switch 2 High P2146 Fuel Injector Group 1 Supply Voltage Circuit P2149 Fuel Injector Group 2 Supply Voltage Circuit P2266 Water in Fuel Sensor Circuit Low P2269 Water in Fuel Condition P2502 Charging System Output Voltage P2503 Charging System Output Low P2504 Charging System Output High P2509 ECM/PCM Power Input Signal Intermittent P2607 Intake Air Heater Relay 2 Low P2608 Intake Air Heater Relay 2 High P2609 Intake Air Heater System Performance Hope this will help you. Cheers! Ryan
Jun 11, 2009 | 1999 Dodge Ram
Raypak 2100 Pool Heater  Gas 266000 BTU' (Pilot Light) () Logo
143 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
