Question about Samsung ML 1710 Laser Printer
Samsung ml-1710 printer continues to jam paper; prints job and then feeds an extra page, which becomes jammed part-way through
    Champion:
  • 220 Answers
Pickup roller and seperaion pad req changing
Posted on Jun 22, 2009
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
My samsung ml-1610 printer always getting paper jam on print job. Is this problem related to fuser or something else? please help me...
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Feb 23, 2011 | Samsung ML 1610 Laser Printer
My samsung 1710 laser printer is not printing every page. It sometimes doesn't feed the paper through or misfeeds
you need to clean the feed rollers with rubbing alcohol or have them replaced...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 22, 2009 | Samsung ML 1710 Laser Printer
Hi i have a problem during printing is the paper is strucking in the middle of during printing processes the printer modle number is Dell 1710
Hi, the printer manual or the printer itself would have instructions on how to remove paper jams. Also loosen the guides alongside the paper feed a bit to ensure it is not holding onto the paper sides too tightly as this will continue to cause jams.
Nov 29, 2009 | Dell 1710 Laser Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Jun 11, 2008 | Samsung ML 1710 Laser Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
Printer malfunction
The samsung printer have three paper jam sensors. First (paper jam 0) after the feed rollers. Second (paper jam 1) at the left of the feed rollers and third (paper jam 2) at the fuser unit where it is hot. You can see the actuator between the two white rollers. Paper jam 2 is mainly cause by the scrappers out of position on the side of the upper heat rollers.You will have to clean it and put it back into position.
Dec 19, 2007 | Samsung ML-2150 Laser Printer
Paper jam/lockup
Check to see if the egg-shaped rubber feed roller is cracked. (Pull out the paper tray, it's in the middle at the front on top.) That's what I'm looking for now on the ML-1740. Seems Samsung used cheap rubber for the roller. It should only be a $.50 part if you can find one.
Aug 03, 2006 | Samsung ML1740 Laser Printer
Samsung ML 1710 Laser Printer Logo
1,006 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
