Question about Garden
My bolens riding lawn mower was working great til i hit a low spot with longer grass it got real loud than shut off, when i tried to start it it will start turning over than pop real loud a couple tim
Now it wont even try turning over just pops what happened
  • 3,904 Answers
Try starting this without the blades engaged. Bottoming out will affect the deck but not the motor. In fact, remove the drive belt for the mower altogether and see if the engine runs fine. If this is the case then you have to look at where the damage is on the deck.
Posted on Apr 21, 2014
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
  • 10865 Answers
SOURCE: I need a Bolens riding lawn mower manual, Do you
here is the link to your manual and all bolens manuals. enjoy.
http://sonnys_bolens.tripod.com/diagrams.htm
Posted on Jul 16, 2009
mickey813
  • 472 Answers
SOURCE: My riding lawn tractor made a loud popping sound
IT HAS VALVE PROBLEMS
Posted on Oct 04, 2009
miket756
  • 2702 Answers
SOURCE: craftsman riding lawn mower tries to start and
it sounds like its the exhaust is blocked up or/and air filter, its the back fire that makes me think its a blocked exhaust,, iv had it before!
try taking it off and starting it up,,,,and yes its going to be noisy if it go's! untill you clean out the pipe, then put it back on again,
Posted on Nov 16, 2009
2000 1.8t vw passat wont start
There are many possible issues that can cause the problem you are experiencing. A bad starter, a bad ignition switch, relay, wiring circuit for ignition / cranking.
If you are mechanically inclined, I recommend you begin to test all components to narrow your possible problem.
Jun 19, 2017 | Volkswagen Passat Cars & Trucks
I was trying to view my pics on my computer. i plugged the usb in the computer turned the camera on and nothing happened. then i unplugged the usb frm the computer with the camera turned on and now my...
remove batteries. try and turn camera on, of course it wont work without batteries but this may clear any capacitors.now fit new batteries or just refit the old if you know they are good. and try again, does it work now?
Nov 09, 2011 | Fuji Cameras
When i turn the key nothing happens no click no nothing and theres no resistance when turning the key i got home pull the key out and the car stayed running so i made it stall now it wont start or even try...
sounds like it. but you could always check the basics before spending a bunch. Check your: battery cables, no corosion or loose fitting. make sure your battery is good and full, pop the caps on the top of the battery and pour in some distilled water if the fluid is not 1/4 of an inch from the top. check all fuses ect...
Aug 08, 2009 | 1992 Dodge Stealth
It is frozen and wont even turn off
LEAVE THE BATTERY GO DEAD, THEN CHARGE IT AND IT WILL WORK
Apr 10, 2009 | Creative Labs Creative Technology Zen MP3...
Turned off automatically and made a pop sound
That is inverter or power supply that had blown. This two parts must be tested, and the faulty one replaced.
The TV now won't start , as it is on protection mode because of an internal fault.
Ring the number listed on the owner manual to get technical support.
Mar 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
EOS 350D Error Code 5
i have the same prob too on a 350D, in low light conditions, i used to ba able to turn it off and on and then it would work again... but now it wont pop up at all. U can manually pick it up- but i dont think on a regular basis.... mine now is jammed properly, cant even pick it up manually. this seems to be a common prob???
Dec 28, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Not again wont turn on
i had the same situation this happens when you dont turn off your t20 after you disconnet it from your pc IRIVERS T2O PROBLEM IS THAT IT AUTOMATICALY TURNS ON EVERY TIME YOU DISCONNET IT FROM PC AND IF YOU DONT TURN IT OFF AFTER THIS - IT FROZES it wont connect to pc after this happens so you have to wait ussualy (~12 hours) until the battery runs low, so after this has happened wait and then after some time try to press play button (to turn it on) and if the battery is dead - it will show LOW BATTERY sign and then you can connect it to your pc again normaly! hope this will help
Feb 28, 2007 | iRiver T20 MP3 Player
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
