Question about Starbucks Barista Quattro Coffee Maker
Blown fuse for B31 mini plus keurig coffee maker
Unit not working as a result
My b31 Keurig is leaking from the bottom. What can I do?
if it is anything like my BUNN you will have to buy a new one . they won't fix .
Jan 05, 2015 | Keurig B31 Mini Plus Brewing System
Keurig B31 Mini Plus Brewing System not working
There is a transformer that take the 110 voltage and reduces it to 13.8 or 14 volts depending on your unit model, it runs an electronic board or little computer in the coffee maker. It's the brains of the coffee maker. I would say you fried the transformer and possibly the electronic board if the high voltage made it past the transformer. I have replaced the transformer in our sons Keurig and that fixed his problem but he didn't plug it into 220v. The transformer is not expensive, an eBay item at around $15 or so. Taking the unit apart is not an easy thing to do. But if your handy you could figure it out and test the transformer to see it it's putting out the right voltage. Just check the voltage tag of the one that it came with so you can order the right one for your pot.
Apr 21, 2014 | Keurig B31 Mini Plus Brewing System
Keurig mini plus b31 only half cup of the water dispenses
Reset the out-flow and dispensing format. See Manual for instructions.
Feb 16, 2013 | Keurig B31
Manual for Keurig B31
Call 1-866-901-2739 for a manual.
Aug 23, 2012 | Keurig B31 Mini Plus Brewing System
Starbucks Barista Quattro Coffee Maker Logo
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
