Question about Electrical Supplies
Eh29c robin engine
I purchased my ez go golf cart last spring/summer it run good for little while, then it started missing, loosing power, flooding. we tuned it up, put some kinda part on it. It helped but it had not been started since early fall, it started right off, some days it runs fairly well and some days, it won't hardly go at all, and floods it self. sometimes it will run like nothing is wrong with it. However , I do have to choke it every time i start it, and I'm told don't have do that especially when they running good. would you know anything of what could be wrong with it.
SOURCE: Coleman Powermate 6250 only runs with choke closed/air restricted
A call to Elliott Small Engine solved my problem - Oil Guard. I had checked the oil and it was just a little low but seemed well within the normal range. I was told to add more, bringing it just over the Full mark. It seems that the low oil protection system is very sensitive and shuts down the engine even when the oil is withing 1/8" of the mark. I added about 2-3 oz of oil and no more problems
Posted on Dec 16, 2008
  • 4088 Answers
SOURCE: Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Posted on Jul 14, 2009
SOURCE: won't run without choke on
i had this problem too. water was getting in the fuel tank. i keep it covered now and it runs great.
Posted on Aug 22, 2009
harlan301
  • 205 Answers
SOURCE: onan generator.will start but will flood out
your going to need to check the carburetor. sounds like your fuel sys is contaminated. when you unplug the fuel solenoid the plunger pops up and cuts the fuel off. the solenoid is used to shut off fuel to keep the unit from back firing
Posted on Oct 14, 2009
Rebgagnon
  • 382 Answers
SOURCE: Husky 5000w Generator with a Subaru engin.
Fuel system needs cleaned. Dirt or build up get's in the passages and it can not properly regulate the fuel/air mixture. Being it runs well in choke position I would suspect it is plugged on the idle passage. Sometimes you can add a very small amount of "Seafoam" to the fuel and let it run while slowly moving the lever to the run position and this will clean it out. It is also possible that the fuel tank has a small amount of water in it. Good luck and have a great day.
Posted on Feb 15, 2010
I have an older electric ez go cart, like 84 I think. There are 4 wires running to back where one connects to a spring looking thing. That spring is glowing red hot. Any suggestions?
That is your speed resistor coils and they are supposed to get hot. Electric current passes though those coils on the way to the motor. When all coils are in circuit, then that is your slowest speed. Check the coils, no broken loops and no loops touching each other. and check the cable connections also (corrosion, loose, etc)
Jun 05, 2016 | Golf
What will make my ez go golf cart pop out of the carb occasionally? It is a Robin eh29c engine.
Its dirty or needs ajust. Use some amsoil Product or BG tank. Igntion may need tune
Nov 26, 2015 | Cars & Trucks
Ez golf cart when I go up steep hill the cart loose power and smoke White smoke
Basic EZGO Golf Cart Problems And How To Fix -
www.golfcarthotrod.com > Golf Cart Repair
Apr 30, 2010 - Electric E-Z-Go Golf Carts are becoming more popular every day ..... I have a ezgo carryall gas golfcart. it has began to pour smoke from rear.
Aug 02, 2015 | Cars & Trucks
More power out of a EZ go golf cart
New batteries, clean the contacts on the speed control and lastly either rebuild the motor or replace it.
Sep 08, 2014 | Golf
I have a 2002 gas powered golf cart that won't start or run new battery it is a ez go txt
You definitely have an electrical problem hard to answer with little details here's a start check switch,all wiring connections for loose / broke wires and or rusty connections use a multimeter helps a lot of guess work good luck maybe there are fuses too
Aug 26, 2014 | Cars & Trucks
I have a 20-30 year old EZ-GO golf cart and need to know what oil to mix in the gas. It has a Robin 2 stroke engine that has been rebuilt in the last 5 years.
If you use a good, high quality 2 cycle oil such as Stihl, Echo, Husqvarna, etc. you can use a 40 to 1 mix in it.
Do not use a cheap "store" brand or some no-name product. The few pennies saved just isn't worth the price of a new engine.
Oct 30, 2009 | Garden
12lbs of compression is it the rings. I have a robins golf cart engine in an older ez-go
Most likely rings or possibly a blown headgasket. It isn't likely that worn valve guides could allow the compression to fall this far.
An old trick to help determine source is to put a teaspoon of oil into the cylinder through the spark plug hole and see if the compression rises a good bit further; if it does, it is caused by worn rings.
Sep 21, 2009 | Sport & Outdoor - Others
1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
Jan 05, 2009 | 1995 Volkswagen Golf
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
