Question about Sole Fitness Sole E35 Elliptical
Motor error e-2
How to fix motor error e-2 on e35 elliptical
Sole E35 Elliptical powers off after 10 minutes of use??
If you wish to get some details about treadmill repair; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 10, 2016 | Exercise & Fitness
Error 20 on Q47 Octane Eliptical
Sounds like it needs to be fixed. It will need a new left motor and cord most likely, less likely a lower board.
Apr 14, 2013 | Octane Fitness Octane Q47 Elliptical...
What is error 45 on the EFX 546??
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Nov 11, 2012 | Precor EFX 546i Elliptical Version 4
Operating manual sole e35
go to www.iconservice.com for free download
or http://fitness.manualsonline.com
Good luck,sincerely. G-d bless you
ERNESTO CUADRA
MANAGUA,NICARAGUA
Dec 12, 2011 | RTO Sole Fitness Package F85 Treadmill &...
Whenever I use our eliptical precor efx, as soon as the elevation starts it says error 45
Aug 10, 2010 | Precor EFX 546i Elliptical Version 4
Error code 2 on schiwnn upright bike
Console displays “E2” error code
Solution: A. Check data cable integrity. All wires in cable should be intact. If any are crimped or cut, replace cable. B. Check data cable connections/orientation. Insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place. If the above tests reveal no problems, replace the DC Motor.
• TECHNICAL/CUSTOMER SERVICE Nautilus, Inc. World Headquarters 16400 SE Nautilus Drive Vancouver, Washington, USA 98683 Phone: 800-NAUTILUS (800-628- 8458) Fax: 877-686-6466 • CORPORATE HEADQUARTERS
Apr 01, 2010 | Schwinn 430 Elliptical Trainer
Error 45 on Precor EFX 546 Elliptical
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Sole Fitness Sole E35 Elliptical Logo
83 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
