Question about GE GMS10AARL Refrigerator With Ice Box
I WOULD LIKE TO TAKE OUT THE ICE MAKER.HOW DO I DO THAT?
THE ICE MAKER IS NOT NECESSARY FOR ME AND SINCE I NEED THE SPACE I WOULD LIKE TO KNOW WHETHER IT IS POSSIBLE TO TAKE IT OUT?
  • 135 Answers
Sure. There are likely 2 screws on the sidewall near the top; then just unplug it and take it out. Hope this helps!
Posted on Jun 19, 2009
WILL NOT DELIVER ICE CUBED OR CRUSHED
Please check the bellow link, if it helps-
http://www.ehow.com/how_7592870_whirlpool-refrigerator-wont-make-ice.html
However if the ice maker has completely stopped producing ice check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Let us know if you want something else please accept the solution.
Jan 02, 2011 | Whirlpool Refrigerators
Ice maker will not dipense ice
Hello, Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If these wire is in the raised position, the ice maker is turn off.On some unit you simply lowered the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in proper position, check the freezer temperature, it should be between 0-8 degrees Fahrenheit.If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seal and thermostat, repair/replace as necessary.
Thanks
Jun 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
The ice maker is not making ice and not working
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Apr 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice
Mar 31, 2010 | Sub-Zero 632 / S
Ice maker not working
Mar 28, 2010 | KitchenAid Superba KSRS27CN Side by Side...
Ice maker stopped working
Mar 28, 2010 | Refrigerators
Ice maker makes grinding noise (no ice)
Sep 25, 2009 | Maytag MBB2256G Bottom Freezer...
Ice maker stoped making ice
Hi
Thanks for using FixYa. Check to see whether the ice maker has been turned off. Here's how to check.
Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 09, 2009 | Kenmore Refrigerators
Ice maker stopped making ice and everything is thawing in freezer"
Mar 24, 2009 | Kenmore 57029 Side by Side Refrigerator
GE GMS10AARL Refrigerator With Ice Box Logo
66 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
