Teac faults model LE3291HD stuck in scan mode with message displayed inverted and distorted saying do not switch off
3 Suggested Answers
  • 257 Answers
SOURCE: Thinkpad screen colors Inverted/Distorted in 256 color mode
not a epert just trying to help,, i dont know what windows you are using xp or higher will not work good with that low of color,, hope this help you
Posted on Feb 25, 2010
SOURCE: Problem with Yaskawa Varispeed 616G5 inverter
inverter shows the message sc on hmi
Posted on Jul 30, 2010
DVD/VCR stuck in Progressive scan mode
Hi jjbitt.
I found this in another post. This is what another expert say
"With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS.."
http://www.fixya.com/support/t123076-dvd_vcr_stuck_in_progressive_scan_mode
Let me know if you still have the problem
Jan 12, 2008 | Zenith XBV442 DVD Player/VCR
Fault finding
It sounds like blown output transistors
Apr 23, 2014 | Teac Audio Players & Recorders
Gateway fpd 1530says
If you see a message box that says "Power Saving Mode" after pressing the power button, then it simply means that the monitor/display is not detecting the computer. Check the connection/cable between the display and the computer and make sure your computer is not in standby mode by moving your mouse.
From what you stated in your problem, you dont need a inverter or a bulb. If you have any image like the message box displayed then its working fine. It just isnt seeing any signal changes on the input and therefore goes into power saving mde. Try another cable or hook it up to a different computer to check the cable.
Oct 16, 2012 | Gateway FPD1530 15" Flat Panel LCD Monitor
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
Sep 23, 2012 | Teac LT-1 Clock Radio
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
My teac ag-790a 'protect' error message on display. When I brought it to the audio shop for repair it worked fine; at home again the same problem? What is the problem? Tx.
Hello
Check the putput wirings to speakers. If any of them has short circuit, the set will go to protection mode. You can understand it well, as it did worked fine at the repair shope. The set has no fault at all, but the wirings, connects to it have.
Just power ON the set at your home, without connection any output or input to it. See, it will not show any protection mode display. Switch it OFF. Connect the output to speakers, one at a time, and switch ON the set. Just do it for all other speakers. This way, you can find out, which speaker line causes the set to go to protection mode. Fine out the reason.
Never connect any input to the system, until works fine with out showing any protection display.
I helped you somewhat fine, I assumes.
Ok.
Jan 31, 2012 | Teac Audio Players & Recorders
My TEAC 3340S (no, there is no "A" prefix) has three faults: 1: Plays back on channels 1, 2 and 3 but not 4 - unless the "simul sync" switch for head 4 is changed from normal to simul sync. 2: Records...
From what you are describing the firmware or software in the receiver is distorted. The firmware is a chip inside the unit that tells it what to do when the micro switches are pushed. So it is getting the wrong signal from the firmware.
Oct 18, 2010 | Teac Audio Players & Recorders
Xerox C20 displaying "Scanner Locked" message. Won't copy.
  1. Press the power switch to the OFF (O) position. The power switch is located on the lower, left side of the machine.
  2. Pull the scan lock switch toward the front of the machine to unlock the Scanner.
    NOTE: The scan lock switch is located on the bottom of the Scanner Module. Make sure the scan lock is completely free. It sometimes hangs at the halfway point.
  3. Press the power switch to the ON (|) position. A 'Warming Up, Please Wait' message will be displayed on the Display Screen. Warm up time is less than 40 seconds from power ON and less than 25 seconds from the Power Saver mode.
Aug 30, 2010 | Xerox CopyCentre C20 Black and White...
 Grubhead
Grubhead
