Question about GE Dishwashers
Ge dishwasher pdw9280n00ss
Getting 120VAC to case. When the door is opened to load the PDW9280 the inside panel reads 120VAC to ground. Wife got shocked twice. Any ideas or help to solve this problem? Thansk, Pete
    Problem Solver:
  • 46 Answers
It is probably getting energized through a direct short. Normally this would trip the breaker but sometimes installers take shortcuts and don't properly ground the the unit. Find the correct breaker in the main panel and turn it off (double check with your VOM). then pull off the lower cover below the door. you should see where the romex cable enters a small junction box. pull the cover off and pull out the wires and see if you find any nicks in any of the wires. while the wires are pulled out and not touching the j-box turn the breaker back on. see if you get any voltage on the inside metal case. if not then you know the source of the problem. if you still see a voltage check the motor and see if the outside of the motor case has any voltage on it. if yes then the wiring to the motor or the motor itself is faulty. Without looking at it my first guess is a hot or neutral wire is in direct contact with the metal frame. Keep in mind neutral wires can carry returning current on them and thus can shock you as well.
Posted on Jul 07, 2014
SOURCE: Dishwasher Heating element not working
my wife shut the water off to the dishwasher and forgot to turn it back on and then used the dishwasher.
the heating element went on but there was nop water.
when we turned the water back on,the drying cycle does not work.i would think that the element needs to be changed or is there a relay on the computer board?
this is a two year old Jennair unit.
any suggestions?
Posted on Apr 29, 2008
SOURCE: front door panel, stainless for GE dishwasher
Ebay has a guy selling stainless panels, cut to size; search dishwasher stainless panel
Posted on Nov 11, 2008
MNTECH
  • 1543 Answers
SOURCE: Poor wash performance with GE Profile PDW9280 dishwasher
Check the holes in the spray arms for obstructions.
Posted on Mar 28, 2009
  • 22 Answers
SOURCE: Maytag MDB9150 Dishwasher soap dispenser door doesn't open
the plastic lock of the soap dispenser in side the dish washer door is broken
Posted on Jun 09, 2009
  • 246 Answers
SOURCE: Replacement Door Panel for GE Profile Dishwasher
Are you trying to replace the microwave door or the GE dishwasher. Either way, www.applianceart.com (under the stainless steel section) has this roll of stainless material that you apply to your appliances. I saw it on the "Today Show." Its basically faux stainless. We put it on our refrigerator and it looks and even feels like real stainless steel. Its really cool. I think its called stainless foil or something like that. Also if you're looking for a stainless panel for your dishwasher they sell actual stianless panels there too.
Posted on Feb 25, 2010
Why was my dishwasher tripping the breaker when the ground wire touched the metal inside of the dishwasher?
The wiring may be reversed, colorwise, somewhere between the breaker panel and the dishwasher. Check for the correct polarity with a voltmeter.
Jul 19, 2014 | GE Dishwashers
It is not very unusual to find 120V on the door panel. The voltage is fed straight to the control board from the mains from which it gets distributed to different components like door switch, detergent detector, motors and pumps. The layout is shown on this schematic
http://www.appliancepartspros.com/escutcheon-door-assembly-parts-for-ge-pdw9280n00ss.html
It is likely the door switch connection is leaking. You will need to take the multimeter (on ohms setting) and carefully measure the points on different components on the disassembled door panel for short to the panel body. Make sure the dishwasher is disconnected from the mains power.
Apr 20, 2014 | GE Dishwashers
I keep getting a washer arm blocked error.
I have had the same problem for a couple of years. When it tops without opening the door just press the start button and it will resume and finish the load.
Aug 01, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Dishwasher - Built in
The most likely cause of the unit is not getting water. If you can remove the kick plate at the bottom and have a voltohm meter you can check: a.the continuity of the solenoid valve at the left front, unplug wireconnector set meter to ohms, touch leads to the terminals if no reading replace complete inlet valve. If you have a reading, then B.Turn on machine, set meter to volts, connect leads to plug, you should have a reading of 120vac. If not, Then the control board needs replacing. If the unit is in warrenty you'll need to contact where you purchased it.
Mar 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE dryer barely heating
If this is an ELECTRIC dryer, you're supposed to read 120VAC at both L1 and L2. With the cord UNPLUGGED, check the voltage across L1 and l2 at the wall receptacle. You should read a cumulative of 220-240VAC. If you're only getting 120VAC, the problem is at your receptacle, which would explain why the dryer is not heating. The heating circuits and timer require 220VAC, while the drive motor only requires 120VAC. If the power at the receptacle is good, leave the dryer unplugged and check the continuity of the power cord from the end of the plug at L2 to the terminal block at the back of the dryer. You should read a short or 0 ohms. If the continuity of the plug is good, the problem may be a loose connection at the terminal block or a broken wire. If the continuity is bad (open), then it looks like you may have a bad power cord. Please post back if you have questions. I hope this helps you.
Jan 03, 2009 | GE DVLR223 Dryers
Ge profile dishwasher panel won't turn on
out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
rclay How old is your dish washer? It has up to five years limited (parts only) warranty on the electronic control. If it is within this period of time, then you can call Maytag and they will send you a new part. If you are not sure how old is it, you can find it with Maytag by the model and the serial numbers (on the door frame). The warranty for your dish washer you can get here: http://www.maytag.com/cust_serv/pdf_use_care_manual/6_915728.pdf Gendos...post back
Jan 31, 2007 | Maytag MDB9100A Dishwasher
Dishwashers Logo
44 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
