Question about KitchenAid KERA205PSS Electric Kitchen Range
Kitchenaid kera205pss convection oven feature not working
My regular bake option works but when I try to use the convection oven feature, the fans run, but no heat is provided to the oven.
    Habit-Forming:
  • 119 Answers
Beth, you either have a failed convection element, part number 9460769, possible bad terminal connection at the element or a failed oven control. A bad element is the most common failure. replacement instructions for a failed heater can be provided.
Posted on Apr 21, 2014
SOURCE: KitchenAid KERC506HWH3
Change the element?
Posted on Jun 13, 2007
  • 183 Answers
SOURCE: Oven not heating KitchenAid KERC506HWH3
if this cooker is fitted with a clock check that it is not set to delay start mode(auto) if it is reset clock and this will resolve problem
Posted on Jul 28, 2007
  • 126 Answers
SOURCE: KitchenAid convection oven - panel went black during self-clean SOS
turn power off. take back off range. manually unlock door. it sounds like your control panel is shot.after you have it unlocked turn power on try your oven
Posted on Nov 22, 2007
SOURCE: oven elements dont work / stove top works fine
Repair person also shut the power off before replacing the fuse...
Posted on Dec 20, 2007
  • 417 Answers
SOURCE: our oven won't work. it is a convection oven, and
Hi
If the fan is working then most likely it is the heating element gone bad.
You can check this if you have a multimeter or continuity tester.
Replacing the element is not too difficult, you have to get the back off, disconnect 2 wires, undo the fixing screws then fit the new one.
Don't forget to turn the power off first tho'.
Posted on Dec 17, 2010
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
Convection oven not working properly???
your correct the only difference between a regular oven and a convection oven is that it has a fan.when you open the oven door the fan should be spinning to a stop if this is not the case you may have a problem with the fan.
Aug 14, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Feature not available
I had the same problem with a new kitchenaid range which they have agreed to replace after 1 month. Oven shut off a couple times while baking and feature not available displayed when trying to turn on oven again. I tried starting clean cycle and waiting a couple minutes for element to heat then cancelled clean cycle. Oven worked fine after this but this shouldnt be a solution, obviously something not wired right.
Dec 09, 2013 | KitchenAid KIRS608BSS Induction Electric...
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
Bought oven second hand so no model no. it is a dual belling range with fan. the oven heats up but the fan has stopped working! single parent who hasnt a clue, please help!!!!!
most model numbers are located around the frame of the stove, inside the drawer area or on the oven door, call the manufacturer, most have a toll free number. Check to see if the fuses are okay first, if one is out, that could weaken the system. The fan is probably convection, and your controls will have a convection feature. If the fan has ceased to work, just use the regular bake mode.
Sep 03, 2009 | Belling Ovens
Oven will not stay on when baking regular none at all, convection have to set a couple of times
I had a similar problem when you turn the oven on it would shut off either on broil or bake,I tried switching the lock for the oven cleaner back and forth and now the oven works.
Jul 05, 2008 | GE JBP90 Electric Kitchen Range
Fan for convection oven not working
Maybe you could throw out the oven and buy a new fridge
Feb 02, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KERA205PSS Electric Kitchen Range Logo
149 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
