Question about GE Dishwashers
Ge dishwasher pdw9280n00ss
My wife was shocked twice when loading the GE PDW9280. I checked for voltage to case and found the inside door panel reading 120 VAC to ground. I have not disassembled the panel yet but do you have any thoughts or have you seen this before? I have had to replace the membrane panel x 2, soap dispenser x 1 and the unit is 7 years old. does not get much use (every 3rd day). I am wondering if I need to look for a new unit? I appreciate any thoughts on why I am getting 120 VAC to case. Thank-you, Pete
  • GE Master
  • 3,247 Answers
It is not very unusual to find 120V on the door panel. The voltage is fed straight to the control board from the mains from which it gets distributed to different components like door switch, detergent detector, motors and pumps. The layout is shown on this schematic
http://www.appliancepartspros.com/escutcheon-door-assembly-parts-for-ge-pdw9280n00ss.html
It is likely the door switch connection is leaking. You will need to take the multimeter (on ohms setting) and carefully measure the points on different components on the disassembled door panel for short to the panel body. Make sure the dishwasher is disconnected from the mains power.
Posted on Apr 23, 2014
SOURCE: Dishsoap stays in soap dispenser
We had problems with soap remaining in the dispenser and dishes not getting clean when we used gel dish doap. We changed to the cakes of soap with a Jet Dry Power Ball in the middle, and now they clean fine.
Posted on Apr 14, 2008
SOURCE: Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Posted on Dec 13, 2008
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
SOURCE: My GE Profile Dishwasher PDW7880 Soap dispenser does not empty
I had the same problem. After some investigation I found that the hose that brings water to the top arm was clogged. There was a piece of chipped china logged in there. I have no idea how it got there as it is at the top and facing the the back wall but once I managed to take it off it solved the problem.
Posted on Apr 09, 2009
  • 246 Answers
SOURCE: Replacement Door Panel for GE Profile Dishwasher
Are you trying to replace the microwave door or the GE dishwasher. Either way, www.applianceart.com (under the stainless steel section) has this roll of stainless material that you apply to your appliances. I saw it on the "Today Show." Its basically faux stainless. We put it on our refrigerator and it looks and even feels like real stainless steel. Its really cool. I think its called stainless foil or something like that. Also if you're looking for a stainless panel for your dishwasher they sell actual stianless panels there too.
Posted on Feb 25, 2010
GE Dishwasher won't fill with water
IF you replaced the valve then the problem is the power supply not getting the right voltage to the valve. This could be from the door switch not showing the control panel that the door is closed.
Apr 29, 2015 | GE Dishwashers
It is probably getting energized through a direct short. Normally this would trip the breaker but sometimes installers take shortcuts and don't properly ground the the unit. Find the correct breaker in the main panel and turn it off (double check with your VOM). then pull off the lower cover below the door. you should see where the romex cable enters a small junction box. pull the cover off and pull out the wires and see if you find any nicks in any of the wires. while the wires are pulled out and not touching the j-box turn the breaker back on. see if you get any voltage on the inside metal case. if not then you know the source of the problem. if you still see a voltage check the motor and see if the outside of the motor case has any voltage on it. if yes then the wiring to the motor or the motor itself is faulty. Without looking at it my first guess is a hot or neutral wire is in direct contact with the metal frame. Keep in mind neutral wires can carry returning current on them and thus can shock you as well.
Apr 20, 2014 | GE Dishwashers
My ge quietpower 1 will not shutoff when door is opened
There is an interrupt switch generally located in the door as part of the latching mechanism that stops the washer, yours is probably either shorted or has become damaged is some way.
Dec 16, 2011 | GE Dishwashers
My GE 24 in. GSD980X dishwasher detergent dispense door will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 24, 2011 | GE 24 in. GSD980X Built-in Dishwasher
Ge profile dishwasher panel won't turn on
out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
Front door panel, stainless for GE dishwasher
Ebay has a guy selling stainless panels, cut to size; search dishwasher stainless panel
Jun 09, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Max dishwasher no lights on panel
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
Feb 04, 2008 | Dishwashers
DISHWASHER WILL NOT POWER ON AND THERE IS POWER TO THE OUTLET
more than likely the door catch switch or the on off button, check these 2 first
Oct 13, 2007 | GE 24 in. PDW9880LSS Stainless Steel...
Dishwashers Logo
125 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
