Question about Sony Audio Players & Recorders
Dav fx900kw says no disc when put in DVD
When I put DVD in I get a message no disc & if doesn't play
    Problem Solver:
  • 12 Answers
First try turning off the unit and unplugging for 15 seconds to reset. Next try a different DVD. If nothing works then you will probably need a professional to service the DVD drive.
Posted on Apr 21, 2014
techman
  • 3130 Answers
SOURCE: No disc message on DVD Player
What you might want to try before giving up would be to get a lens cleaning disc. If that does not work then you may have to take off the top, locate where the small laser lens is, and with a small cotton swab, soak slightly in alcohol, and in a swirling motion, clean the laser lens, now with the dry end, do the same. Wait a few minutes for all the residue to dry. Plug in the unit, and see if you made any differance. If you did GREAT!!. If not well at least you tryed, and there is not alot more you can do as a consumer, without test equipment, or speacial jigs. It most likly will not be worth taking into a repair shop, as these days these players are almost a dime a dozen!. Good Luck Ps Please do not forget to rate this.
Posted on Oct 16, 2006
SOURCE: DVD player does not play
Display of my DAV C450 does not work
Posted on May 11, 2008
SOURCE: ALL of a sudden dvd player does not play any disc and comes up with ( PAL DISC ) message on screen every time we put a dvd to play
switch to pal mode(theres a switch at the back of the player)
Posted on Jul 14, 2009
  • 736 Answers
SOURCE: hi, had my sony dav-s300 for 5yrs with no probs.
thats about the time china was making really bad aluminum electrolytic capacitors .. look inside for capacitors with the top bulged up .. if you find one you will probably find several ..if so, replacing those will probably fix the problem ..
Posted on Jul 25, 2009
SOURCE: SONY DAV-FX900KW - I am
there is a small circle just beneath the CD tray. If you click it using a toothpick or any tiny device, it will help eject the disk. I have tried that and it works... There might be a problem on the roller inside the disk tray, wherein it requires a technician to repair such device...
Posted on Dec 19, 2010
Type your question here...
I am having SONY DAV-DZ100 DVD Home theater system. The player is reading all the MP3 format cds and If I Insert any DVD, the message showing as "can't play this disc", even its a new DVD. Please suggest the solution.
Oct 12, 2011 | Sony DAV-DZ100 System
Hi!! I have a SONY DVD player(model- DAV DZ150K)...Recently it has refused to play DVDs (it says "cannot play this disc") and only plays VCDs and ACDs...please help!!!!
I have 1 sony DVD Model No-DAV-DZ150k .When i have select DVD mode so dest error show on VFD Disply .Pls tell me what is problem in DVD.
Oct 15, 2010 | Sony DAV-DX255 System
Sony dav dz100. Disc does not spin.
Please put few drops of WD-40 on spindle motor shaft that sound not spin smoothly.
Spindle motor is located in middle of dvd mechanism that holds and spins disc.
If that does not solve your problem, replace optical block.
Let me know if you need optical block part number.
Thanks.
Dec 05, 2009 | Sony DAV-DZ100 System
"No Disc" message when trying to play DVD or music CD.
Try a "Laser Lens Cleaner" preferably one that uses fluid, run that thru the machine a couple times. You can find them at just about any retail store that sells CD's/DVD's or electronics. Next, if you have any liquid car polish, take a couple drops and spread on the surface of the disc. Use a microfiber towel to clean off. This helps clean off smudges and protects the disc from scratches. And it works great on damaged discs too! If your discs still do not play, then the unit needs to be repaired or replaced. Hope this helps
Jun 14, 2009 | Sony DAV-DZ720 Theater System
Program play prohibited
This can happen if you have the "repeat" function turned on on your DVD player.
Nov 10, 2008 | Sony DAV-C450 System
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Jan 13, 2008 | Sony DAV-C450 System
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Oct 06, 2007 | Sony DAV-DZ100 System
No Disc
Stumpy, I think the first step could be to find out between the DVD player and the disc which one has a problem.If the DVD Player is able to play other discs then it is possible the problem is with the disc only. If that disc can be played quite alright in other DVD players then the problem is with your DVD Player. I suggest you trial that first. I think the indication of " No disc insert disc" could be that your DVD Player is failing to load or read the disc either because the disc has some scratches or because your DVD Player lens are not powerful enough. I am, Letsthank.
Jan 29, 2007 | Sony DAV-S400 System
100 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
