Question about Yamaha DSP-A3090 7-Channel Amplifier
Shutoff itself within couple seconds.
Anyone knows what the reasonable cost to have this problem fixed? or anyway a novice like me can fix this by himself? thanks, Phillip
  • le_phillip Jun 20, 2009
    This is the Yamaha DSP-A3090. shut off by itself within couple seconds.
Liebert ap361
I'm an engineer and familiar with the innards of these things. My considered opinion is that I would not try what you are suggesting, which is a hot swap of the fan.
My reason is safety. Inside that unit are elements that generate 120V AC within a few thousands of a second of power loss. That can happen at any time. If you are in some random location up to your elbows, how will you know? Also, during this same interval, the unit is bypassing the AC generation and coupling AC to the internal outlets.
120V is sufficient to kill you if applied across the right points on your body at the right time.... say from hand to hand across your chest. Not worth the risk of a few minutes of downtime, especially for novices.
I'm not familiar with this specific UPS, but the standard method of doing this type of thing is shutting off the loads, removing the UPS, fixing it, re-installing it, and powering everything back up. If it's going to take HOURS and you need the machine, you can always power things up without a UPS OR you can borrow one for the moment. You should be comfortable with doing this sort of thing, anyway and practice is a good thing.
Jul 14, 2014 | Computers & Internet
Hi there My DS Lite has started to turn itself off straight after being turned on and its fully charged. It has had a new battery and I have got a brand new charger and the DS lite when turned on, turns...
You may want to send this in for repair. I know a really good place called www.videogame911.com. My friend told me about them and they do really good repairs, I had my DS back within a week.
May 03, 2011 | Nintendo DS Lite Console
Tv doesnt turn on...just clicks
the relay is clicking on. it mave have bad contacts internally. this controls the power supply for the audio and video circuits. you may just have a blown power supply fuse. since you are a novice. recommend service by tech should get an estimate 1st. shouldn't be too expensive
Sep 20, 2009 | Televison & Video
Hi, I have a colt Mk 282 air compressor that won't auto shutoff. eg the compressor keeps running on trying to fill the holding tank even thou it is full!! it will then blow the rear saftey plug out of the...
The shutoff valve (usually has a set of contacts like a relay) is probably stuck. For the most part, these are not adjustable. They can usually be removed, cleaned, and reinstalled to correct the problem. Sometimes that permanently fixes it. Sometimes, you have to bite the bullet and by a new shutoff valve.
Mar 20, 2009 | Air Tools & Compressors
Lcd screen leaked/broke by itself???
Yeah i bought the phone and 2 months later the screen went all funny. the phone shop said it was my fault and it would cost 80 euro to fix:o.....
I am going to buy a replacement screen on ebay and my dad is going to replace mine for me .... My friend had the same problem with a different make of a samsung and she bought a new screen and installed it and it works perfectly :)
hope this helps yuh guys :D
Nov 15, 2008 | Samsung J700 Cellular Phone
The backlight on my laptop is not staying on
There is settings for your screen in the display options. Sounds like you need to fix a couple settings.
Oct 17, 2008 | Acer Aspire 5610-4648 Notebook
Mitsubishi VS-55707 Rear Projection - Power button turned on, green light on television shows power but automatically shuts back off within a couple of seconds.
My brother had the same issue. I have the same set as well with this very issue. My brother had his fixed: repairman soldered the circuit board???? My brother could not tell me where on the circuit board or what circuit board???? IF there is anyone that knows about this....it would be helpful. I DO NOT WANT TO have someone else do what I can fix myself....besides by the time I pay a repairman I am 1/3 of the way or better to a new set anyway!!! Thanks a bunch - Pam
Apr 18, 2008 | Televison & Video
Unable to print and showing an 'unable to print 5A code
There are diffrent reasons for this error:
check, if something sticks in the machine (paper or metal clip)
The paperfeeder clutch gear is broken: check if the paper feeder works well.
The purge station has problems to do the cleaning jobs: gear broken or too much ink within the purge tubes.
Anyway, this problem is hard to handle for a novice due to so many diffrent reasons.
You should contact a service dealer and in case it is still in warranty let fix them.
Mar 06, 2008 | Brother MultiFunction Center MFC-440CN...
Dropped Camera Zoom Problem
Afraid not a novice or even an expert can fix this one. It will have to be a repair of the zoom mechanism. It will almost certainly be costly. Check your Olympus support site to see what your local repair options are.
Aug 30, 2007 | Olympus Camedia C-765 Digital Camera
PUSH POWER AND SHUTS OFF WITHIN SECONDS AUTOMATICALLY
just had this tv fixed for this exact problem-it cost 577 bucks to fix- some sort of control panel that had corroded
Jul 05, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Yamaha DSP-A3090 7-Channel Amplifier Logo
182 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
