Engenius eoc3220-w outdoor access bridge set-up
  • Jerry Kramer
    Jerry Kramer Apr 21, 2014
    Hi Alice Corado, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?what is you question. I don't know where you are in the set up. Are you IP saavy?
  • Alice Corado Apr 21, 2014
    I JERRY, I AM TRYING TO INSTALL (WHERE TO PLACE OUTDOORS ) , WHERE DOES THE NETWORK CABLE FROM THE POE GO ? MODEM ? WIRELESS ROUTER ? DO I NEED WIRELESS ROUTER ? I WANT TO EXTEND WIRELESS CONNECTIONFROM MODEM @ 300 MTS. IS THIS POSBILE ? ANY ADVISE IS GREATLY APPRECIATED. THANKS
  • 3,904 Answers
The POE should have a balun/power supply. You plug a data cable with RJ45 connectors into the power injector and that will go to the access point. You will need either a cable running out to that or you will need the antenna (send and receive side) to get the signal there wirelessly. If you use this option the you will get up to two miles that you can shoot the signal. You will need a router to send the signal. If you give me a complete list of what you have from Engenious I can map this out for you.
Posted on May 01, 2014
How do I install a ENS200 long-range wireless outdoor bridge
http://www.smallnetbuilder.com/wireless/wireless-reviews/32008-engenius-ens200-long-range-wireless-80211n-24ghz-outdoor-bridgeap-reviewed?start=2
Oct 14, 2013 | EnGenius Ens200 Outdoor High Power Client...
Data communication problems accross my WLAN Bridge
The first step here is to identify exactly what portion of the link is the culprit. Clearly you must have some sort of AP in the remote building for the handheld devices to connect to, since the bridge radio won't perform that function. So I would attach an AP of that type directly to the ProCurve and see if the problem is present or absent when you try to sync devices using that AP without any involvement by the Engenius units at all. If you isolate the behavior to the Engenius units, you may have to play with the Data Rate and Fragment Threshold settings.
May 11, 2009 | EnGenius EOC-3220 (EOC3220)
Cannot get in to my Engenius 3220 with 192.168.1.10
Attach the 3220 directly to your computer with an ethernet cable (through the POE box, of course). Allow it 60 seconds to start up. Make sure the address of your computer is 192.168.1.something. Ping 192.168.1.10. If it answers, browse to 192.168.1.10 and it should let you in, or ask you for a name and password, however you have it set up. If the ping fails, 192.168.1.10 is not the address assigned to your bridge, and you may have to perform a factory reset on the unit using these instructions:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
If the ping and browse succeed, then make sure that 192.168.1.10 is not within the DHCP range of your Netgear router to avoid it giving out the same address to some other device. I assume that 192.168.1.x is in the LAN range of your router -- if not, that's your problem.
May 02, 2009 | EnGenius EOC-3220 (EOC3220)
Username password
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
Trying to get into my engenius 3220.using 192.168.1.254
If you have lost track of what IP address you have assigned your 3220, you can use the serial reset procedure documented here to return it to factory defaults:
http://www.engeniustech.com/datacom/support/general-details.aspx?id=65
Apr 16, 2009 | EnGenius EOC-3220 (EOC3220)
How do i reset my engenius senao eoc 3220 outdoor radio
back side one reset button is there pull out the power cable then pull in that same time you have to press the reset button for three to five sec then all lied's blink all to gather then your default ip address is came then you again configure at default ip
Apr 15, 2009 | EnGenius EOC-3220 (EOC3220)
I am using a EnGenius Senao 3220 plus bridge radio to pick up the signal from another same brand radio. i am able to connect to the network but i was not able to get in to the internet: "Unable to get...
If you have the radio configured as a bridge (not a bridge-router), you must ensure that your computer is in the same LAN IP subnet as the remote router. If the remote router supplies DHCP, this should happen automatically; if not, you must configure your computer manually.
Once there, you may have to manually define DNS servers on your computer in order to access machines on the internet by name. If you can browse to http://216.239.122.34, but not to http://google.com, your problem is solely lack of defined DNS servers. This is not an artifact of the Engenius units, but the remote server.
Oct 31, 2008 | EnGenius EOC-3220 (EOC3220)
SENAO EOC 3220 CONNECTIVITY PROBLEM
hello!
-- try to change wireless channel on your access point
-- try to enable wireless security on your wireless network
-- try to assign static ip address on your wireless computer
Apr 26, 2008 | EnGenius EOC-3220 (EOC3220)
Computers & Internet Logo
David Payne
David Payne
