Question about Sony Car Audio & Video
I need wireing chart to wire CDX300 to a dodge truck
    Problem Solver:
  • 12 Answers
I would check Crutchfield for a wiring adapter. They sell adapters that go straight from new stereo receivers to the factory wiring harness.
Posted on Apr 21, 2014
1999 Dodge Grande Caravan. Left signal light works sometimes and sometimes it want. How to fix?
Basic automotive electrical testing with a volt meter is how to fix ! Find a wiring diagram and componet location chart - connector's wire harness , power and ground locations etc.... Diagnosing Turn Signal Problems http://www.bbbind.com/free_tsb.html Could be the turn signal switch , lose connection somewhere . Ground problem .
Feb 14, 2017 | Dodge Cars & Trucks
1983 Ram Van. Where can I get a radio wiring diagram?
1983 Dodge Ram Van Audio Wireing Chart
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Black/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Black/Red
Mar 27, 2016 | Dodge Cars & Trucks
I bought a power drivers seat from a 1998 dodge ram. I have the wiring out of the truck but need to know where the wires connect. I have a 1997 dodge ram with manual seats and it's not wired for power...
The wiring should be mostly self contained in the seat. All you should need to provide is a power source and a ground. There are many places to tap into a 12V source.
I have linked to a nice wire key for that truck:
1998 2001DodgeRam Vehicle Wiring Chart and Diagram
The video may not be much help but it may help identify the connections
Jan 03, 2015 | 1997 Dodge Ram 1500 Club Cab
How to test the asd relay on a 2003 dodge caravan 3.3l engine
This can be done with a ohm meter, but you need a chart of the internal wiring. Better, if there is another exactly the same relay you could swap them to test.
Mar 31, 2014 | 2003 Dodge Caravan
NEED CAR STEREO WIRING DIAGRAM FOR 2003 DODGE 1500 4X4
best thing to do is buy an wiring adaptor kit. it will ease the installation process by labeling all the wires and connects directly to the factory harness.
Jun 17, 2012 | Cars & Trucks
I wanted to know the audio wiring chart for a 2004 durango
This is from the manual, please rate my help jhere, thanks.
2004 Dodge Durango Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Blue
Car Radio Ground Wire: Black and Black/Light Green
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Brown/Light Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Dark Blue/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Orange
Nov 20, 2009 | 2004 Dodge Durango
Diagnostic Codes for a 1998 Dodge Caravan no ccd bus messages from pcm
could be a bad pcm, but a shorted or open bus wire is also possible. this kind of diagnosis is very time consuming chasing wires and would best be done with a shop manual with wiring diagrams and flow charts
May 11, 2009 | 1998 Dodge Caravan
Adding line out inputs for RCA cables to amp
Hello ssmotorcity,
Here's a link to modifiedlife's Durango page showing the wire colors.
http://www.modifiedlife.com/2005-dodge-durango-car-radio-stereo-audio-wiring-diagram/
If you are adding a LOC for an amp to drive a sub, you are probably better off using the rear speaker wires, the last four wires shown on the listing. If you are adding an amp to drive all 4 channels, then of course, you need to convert both fronts and rears. The simple method is to tap directly into the appropriate wires and connect them to the line converter. If you do not want to tap the wires, you can purchase aftermarket wiring harnesses that are made to plug directly into your vehicle radio and/or the vehicle wiring harness. The Metra part number for a stock radio harness is 71-6502. It plugs into the radio and provides pigtail connections for power and speakers. There is, of course, a harness that plugs into the vehicle harness itself, allowing you to make the connections without any cutting or tapping of the original wiring.
Hope this helps.
Apr 16, 2009 | Car Audio & Video
Need stereo wiring diagram
1998 Dodge Ram 1500 Truck Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amplifier Location: Behind the glove box.
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 30, 2008 | 1998 Dodge Ram 1500 4WD
Car Audio & Video Logo
37 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
