Question about Panasonic DMR-ES10 DVD Recorder
Dvd-ram 4.7gb Trying to finalize to play on other players.I've pressed functions/others/disc management, but auto-play does not appear,only disc name protection erase format I'd be very grateful for your help
    Problem Solver:
  • 3 Answers
DVD RAM discs don't need finalised, hence its not an available option.
They will play directly on other players -*** BUT*** ONLY DVD
RAM players.
Don't expect your RAM disc to play on a normal
DVD+/-RW DVD +/-R device. Its not going to happen unless the
device supports DVD RAM also. If it does, it will play your RAM
disc once you've finished recording in your own DVD RAM
recording unit. Pop it out of your unit, straight into the other, and
the jobs done.
Posted on Nov 22, 2007
Cant find the function to finalize disc on DMR-BWT720 Panasonic blueray recorder.
To finalize the disk, press Function Menu (on the right of the direction keys and OK button). Then highlight and select Others by using the up/down arrows and then pressing OK. Select Blu-ray Management or DVD Management depending on the disc that you have used for recording. Now you should be able to find the Finalise option. See page 23 for the Function Menu tree that refers you to page 70/71 with the disc management sub-menus.
I hope this helps.
Oct 09, 2017 | Televison & Video
I got a new machine, when I transfer from VHS to DVD-R it records, but will only play on the machine I recorded on, it doesn't load on other DVD players, why is that?
You need to FINALIZE the DVD-R you recorded in that unit for it to be playable on other DVD players. This function should be part of the on-screen menu for your unit. (in Panasonic DVD recorders, it's under DVD MANAGEMENT in the FUNCTIONS menu).
If the disc you recorded is already loaded, but stopped, press SETUP on your remote - an on screen menu should appear.
Using the UP/DOWN arrow keys, select DVD MENU and press ENTER. Use the UP/DOWN arrow keys again to select FINALIZE and press ENTER.
A message box will popup 'Finalize disc?' use the UP/DOWN arrow keys to select YES then press ENTER. Finalizing should start and may take a while to complete.
Once complete, the disc is now playable on other DVD players. (from page 32 of the owners manual with the heading 'PLAYING THE DISCS IN OTHER DVD PLAYERS')
Feb 10, 2013 | Toshiba DVR620 DVD Recorder/VCR
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
How to finalize discs on DMR ES 10
It should be a menu option. Press [FUNCTIONS] button on remote to access on-screen menu, then press the UP or DOWN arrow buttons to select 'other functions' and press [ENTER] or [OK] depending on your remote. Then using the menu, enter your disc name, etc., then with the UP or DOWN arrow buttons again, select [FINALIZE] - this should make (example DVD-R) the disc - compatible playback ONLY for all players. You are basically looking within the on-screen menu for 'finalize' option. You should get a popup dialog asking you if you would like to finalise the disc - if you choose 'yes' the operation will begin.
Do you have the instruction manual? if so, refer to page 30 - 32 - disc management. I hope this helps a tiny bit. If you don't have the manual, you can download it as a .pdf free. = download this if you do not possess the original operation instructions.
Feb 21, 2011 | Panasonic DMR-ES10 DVD Recorder
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
I burn dvd -r and dvd+r and it will not play on it
It is possible that the disks are not finalized. You may need to configure it to auto finalize, which is off by default. It would be impossible to have more than one title on a disk if you always auto finalized. Check your manual, and finalize your disks. Many times marginal disks will play OK in the unit they were recorded on, but not so well in other players. The media (disks) could be the problem as well. On a side note, the DR410 will NOT burn DL (dual layer) disks. I hope this helps and good luck.
Oct 28, 2009 | Toshiba DR410 DVD Recorder
Can't play the DVD from Panasonic
Sorry for your loss. If he transferred everything using his Panasonic recorder, it is possible that he never finalized the discs to be played in other machines. If you still have the Panasonic, put the disc in and press the Functions button on the remote ---> choose Other Functions from the screen --> Disc Management --> Finalize your disc. This is one of many possible reasons but a good start. Good Luck - Tamara
Nov 08, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Recorded dvd
You are probably having an issue with the discs rather then what you are trying to play them on.
The discs need to be finalized before they can be used on another player.
  1. Put the disc in the drive (the ones you have already recorded)
  2. Press SETUP on the remote
  3. Select - Disc Edit Press OK
  4. Select - Finalize Press OK
Wait until it is finished then try to play them on another player.
Apr 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
HOw do I finaluze the disc?
I couldn't figure out how to finalize the first disc I recorded either. It wasn't offered on the menu where the manual said it should be. I finally called Panasonic and found out that the disc I used cannot be finalized. I am new with all this, and I just used the DVD-RAM that came with the DVD recorder. This may be obvious to you, but DVD-RAMs can be used over and over again but cannot be finalized. The person recommended -RW that is rewritable but can also be finalized. Maybe this will help you, too. In addition, if you have the correct disc, you should be able to go into "Functions," then "Other Functions," then "DVD Management," and see "Finalize" as an option there. Good luck!
Sep 25, 2007 | Panasonic DMRES15 DVD Recorder
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Panasonic DMR-ES10 DVD Recorder Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
