Question about Whirlpool WTW4950XW Washer
Machine does not work
The washer make a noise when plugged in but nothing lights up on it and it cannot be turned off
  • MS_WI_3013 Apr 21, 2014
    Hi Dale Hodges, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Is there water in the washer?
Why does my washer stop working in the middle of wash cycle and then go dead and no response?
Should get some one to look at it. If there is a hot smell could be a short someplace.
Dec 22, 2016 | Kenmore Washing Machines
My LG Washer isn't working. The little chime that rings whenever it is turned on happens but then NOTHING else. No lights, no codes, nothing. I spin the dial but there's nothing, no noise and no lights....
the machine has suffered a power failure?push and hold the main power button plus another button together hold both buttons in for about 60 secounds the machine should reset.adrian.
Mar 16, 2011 | LG Washing Machines
Door won't unlock
try the cancel button it will drain the water and release the lock
May 30, 2009 | Maytag Neptune MAH9700 Front Load Washer
How do you restart washing machine?
plug in power and turn program button at off(0),then open water and choose a program
Feb 17, 2009 | Kenmore Elite 45986 Front Load Washer
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Zanussi aquacycle 1050 not turning on
First try another gadget, a lamp or something on the wall plug, to see if the point is live. Then check your washer plug, could be that the fuse in the plug has blown, check out your washer wire....
Jan 06, 2008 | Zanussi FJS1225W Front Load Washer
Machine won't work. kenmore 90 series
Might be a broken motor or a blown fuse. I would suggest having your machine looked at by a specialist. If it's old, you might consider replacing it.
Mar 21, 2006 | Kenmore 15864/15862 Top Load Washer
Whirlpool WTW4950XW Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
