Question about LG Tromm Front Load Washer And Dryer Set
Washer wont drain showin IE
Washer showing IE . clothes are soaked, water wont drain. cleaned filter and still nothing
    Habit-Forming:
  • 119 Answers
Sonia, you either have a failed drain pump, or something has bypassed the filter ( bobby pins are notorious for this ) and is jamming up the pump impeller. If you can set the washer to drain/spin and can hear the pump running, you most likely have a impeller that has broken off of the pump motor shaft and will need to be replaced. If you cannot hear the pump running, and can hear a slight humming noise, then there is something jammed in the pump. The pump can be removed and cleared of the possible foriegn object. I can provide instructions on pump removal if needed.
Posted on Apr 21, 2014
Clothes still wet after washed
There could still be water in between the drums. Have a look at the filter, pump and all outlet pipes for a blockage. the excees water that you have when you have clothes in will be what's left in the clothes, wih the machine empty you may just be seeing what shows above the inner drum.
Dec 27, 2012 | Kenmore 22422 Top Load Washer
F28 appearing on display. What does it mean? how do I fix or override? Washer begins cycle as normal but at some point stops leaving clothes soaking wet. Can not spin either. Attempted to intiiate clean...
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The clothes in my duet washer come out soaking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Pl rate me ‘very helpful’ for the free help!
Jan 24, 2010 | Whirlpool AWM9000 Front Load Washer
Wont drain water Gorenje WA61111
locate the filter and clean, this should cure
Dec 16, 2009 | Asko W600
SPIN
Refer to manual; your filter could be blocked, or something could be clogged in the drain pipes. Plug off the wall & check the pipes, filter first.
Jun 06, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
Clothes soaking
Gregg, remove the bottom panel. Right in front you will see the filter. Get a flat pan and remove the filter cover. Pull the filter strainer out and remove the lint and whatever else you find. You should be fine after that...Catriver..post back
Oct 02, 2006 | GE Energy Star WCVH6260F Front Load Washer
Will not drain during spin???
Most likely your outlet filter of the machine is choked with dirt or something; clean out the filter & refit. Of course after taking of the wall plug & siphoning out the water from washer.
Sep 21, 2006 | GE Profile Prodigy WPSE4200A
LG Tromm Front Load Washer And Dryer Set Logo
76 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
