Question about Bosch AQUATAK 150 PRO X Pressure Washer
Shampoo will not come through - Bosch AQUATAK 150 PRO X Pressure Washer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Remove pressure nozzle or use low pressure nozzle only for shampoo
Posted on Apr 21, 2014
What is the best Hair Growth Shampoo ?
You can use different type Shampoo for hair loss and hair growth such as Unisex, PURA DOR, Biotin Argan Oil Shampoo. but for buying Shampoo you have to know what type Shampoo you will be need so read this helpful article Hair Growth Shampoo Top 10 Best Hair Growth Shampoo Reviews
Jan 04, 2018 | The Health & Beauty
Used the flea and tick shampoo 3 hours later my dog is spinning on his bottom and wining I've rinsed him off a couple of times since still spinning
It could range from anything from a worm(s) to a problem with its glands. Perhaps some of the shampoo got into that area and caused it to become inflamed. If the problem persists, it would be best to see a vet.
Sep 06, 2017 | Pets - Others
Is Dabur Vatika with Egg Protein a good shampoo? I have thin and fine hair, is this a good volumizing shampoo?
Hello dear
Yes this is a good shampoo if you have normal hairs. Try the DOVE Daily therapy shampoo, its a mild shampoo and gives the volume strenghten your hair.
If you Want to go in a party or function and want your hairs feel volumized then use SUNSILK VOLUME SPRAY GEL, it really has a very nice result, make your hairs look strong and with volume.
Regards
(Dont Forget to rate the answer)
Feb 22, 2011 | Dabur Vatika Egg Protein Rejuvenating...
It is not dispensing the shampoo on to the carpet.
Firstly, please ensure that there is shampoo in the tank and the tank is correctly and fully inserted. There are 2 ways to dispense shampoo on to the carpet:
1. Use the solution trigger on the underside of the handle (numbered 2 in the picture below)
2. For tough stains use the "Clean Surge" button to dispense extra shampoo (numbered 3 in the picture below
Dec 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Can I use Rug Doctor steam cleaner shampoo in my Ultimate G series Kirby carpet shampoo system?
The answer is no. This type of shampoo doesn't work as well in the Kirby. It should be dry foam shampoo only.
Nov 20, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
May 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
Shampoo furniture
I have had a Kirby for over 20 years and yes you can shampoo your furniture. You do it just as you would your stairs or as if you were spot cleaning. There is really nothing to it.
May 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to shampoo stairs
HERE is the manual
When rating my solution rate the clarity of the explanation NOT whatever you like Kirby stair shampoo system. I do not believe this is the way to shampoo either but this is not me who designed it. Will get the job done but it is a lot of scrubbing and rubbing.
Good Luck
Rocky
Mar 24, 2009 | Kirby G5 Bagged Upright Vacuum
Shampoo
I used to sell these about 5 years ago and I never heard of a shampoo attachment for one.
I went to filterqueen.com to look at the current accessory set and there isn't a shampoo attachment listed.
Jun 22, 2008 | Filter Queen Majestic Canister Vacuum
Bosch AQUATAK 150 PRO X Pressure Washer Logo
151 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
