Question about Apple iPhone 5c
Retangular lines on phone
I have blue lines going down the phone and when it gets to the bottom it starts all over again.
    New Friend:
    Problem Solver:
  • 19 Answers
I would try at the moment and see if an apple representative could help at an apple store as it is either a screen problem or a screen connection problem which you can't open yourself and fix.
Posted on Apr 23, 2014
Blue Smoke .... Faulty PCV ???
does the engine idle smoothly? is the service engine soon light on? the engine is running rich causing the blue smoke.it could be pcv valve but unlikely
May 23, 2012 | 2002 Ford Explorer
Multipoint blue convergence cannot be adjusted
Sound like you need to replace the STK's and any blown pico's on convergence board.
Jan 20, 2008 | Philips 60PP9202 60" Rear Projection...
Our ice maker is not working. it will make some
Hi and welcome to FixYa. I am Kelly. It sounds like your icemaker is really acting up. Odd shaped cubes, and leaking water.
First thing is to disconnect the plastic water line from the icemaker on the back of the freezer. Then rotate the retangular head about 30 deg and pull out the rubber tube. Wash it but do not scrub it. Then reinstall it and reconnect the plastic tubing.
After that follow this link and perform the steps to check the performance and troubleshoot your icemaker:
Click on above.
That should isolate what is causing the problem.
Kelly
May 04, 2010 | Amana ABB1927DE Bottom Freezer...
I have a sciphone i68+ and dont have a manual and its not a easy phone to work? where can i get hold of one please?
If your phone came in a black box, your instructional manual is located at the bottom of it. It looks like part of the box but its actually a piece you can take out. It looks like a black piece of retangular paper. Unfold the the black paper and the manual should be somewhere inside.
Sep 07, 2009 | Cell Phones
Blue screen!
open... and clean the ui teminal of the lcd
Jun 29, 2009 | Nokia 6080 Cellular Phone
A blue line , 2mm, appearing at bottom of page.
Hi Info39684,
It sounds like your Cyan imaging unit has gone down.
Have you thought of changing the orientation of your paper from A4 protrait to A4 landscape. If the blue line is at the bottom, changing the orientation should hide the problem. It's not going to fix it, and if you use A3 then you will see the line again. It's just an idea and you could save yourself £250 on a new unit.
Regards
Taminol
May 18, 2009 | Konica Minolta bizhub C250 All-In-One...
At random a black retangular box appears on the screen
Go into the TV's closed-caption settings and turn off captioning. You'll find it's set for "text" mode right now. What's happening is that in text mode, the set blanks out the part of the screen where the text will go but there isn't any. On channels or programs where captions aren't being broadcast you don't see anything. With the captions turned off the box will go away.
Apr 10, 2009 | Toshiba 20AF41 20" TV
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Blue line down monitor screen of laptop
I have had the same problem
This happens from overheating or from physically abusing the screen
I have an acer, which can take a lot of punishment, but i throw it around and keep it on 24/7 until it gets so hot the plastic starts to smell and melt
Awesome computer, it still works very well for the price (500$)
It developed blue lines on the screen lately and i know from previous experience acer will replace your screen as this may be a factory problem
If you're a freak like me who runs his computer all the time though, they aren't going to listen to you for one second and you have to deal with it
A) Dont use your computer as much (that sometimes fixes it)
B) Buy a better cooling deck
C) Dont abuse the screen (any bending or even the slightest tap can kill it)
D) If the problem doesnt go away, make peace with it and get used to it
E) Replace the screen (i dont want to, so now i have kewl blue lines on my screen)
Apr 06, 2008 | Computers & Internet
Open Questions:
See all Apple iPhone 5c Questions
Apple iPhone 5c Logo
44 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
