Question about Midland GXT1000VP4 Two Way Radio
GXT 1000 indicates low battery. New batteries do not solve problem
The battery charge bars move continuously. Changing the NiCad unit with good radio does not fix problem, nor does using new AA batteries. Stll get the charging indication.
2 Suggested Answers
  • 157 Answers
SOURCE: midland radio battery pack constant vibrate
Hello pjbracht, I just responed to a duplicate of your problem. If they are new, return the battiers and confirm they are "by the book" replacements. If so ask for replacemrnts with a higher mAhr. It is not correct for vibration from a battery pack, lead, NiCad, Ni-MH, period.
Posted on Nov 07, 2008
Bought a new battery pack (jensen brand) for panasonic 5.8GHz gigarange supreme KX-TG6500 2Line cordless phone and it wont charge.
check that you got the right make of battery for the charger
some phones use a nicad battery and others use a lit ion battery
2 different recharegable batteries -- 2 different chargers required
Nov 29, 2016 | Panasonic Lands Phones
Ptt cant go through
It is possible you have a battery or charging problem. Transmitting takes more energy than any other function of the radio. Pressing the PTT can quickly reveal a bad or poorly charged battery pack. Check your charger, clean all battery contacts on the charger and radio with a pencil eraser and try charging again. Also, you can try changing a battery out of a known good unit and see if the problem moves with the battery.
Jul 28, 2017 | Motorola SX600R Two Way Radio
We purchasedn 3 bpr 40 and we justed ordered another, when we turn the bpr on to the channel of the 3 others that are in use, we just get a low continual tone, i tried a radio check on channel 1 with no...
Your new radio is likely not programmed the same as the others. A continual tone indicates a channel which is not programmed (doesn't have a frequency installed).
The other thing which can cause a tone, is a low or uncharged battery. You might try switching one of the known good batteries to the new radio to see if it will work. If you still have the same continual tone with a known good battery installed, you have a programming issue. If the battery swap solves the problem, then you need to investigate why your battery isn't charged up.
Either way, contact the dealer where you purchased the BPR40, they should provide programming free, or a warranty replacement battery for free. If you ordered online or by mail, and you just received the radio within the week, you should request they provide return shipping for you.
Best regards.
Sep 14, 2011 | Motorola Mag One BPR40 Two Way Radio
What lights indicate that the battery is charging and when the battery is full. Neither of the two batteries will charge and i have lost my receipt from argos
generally the red light indicates charging and the green one indicates full charge. If both flash at the same time it usually means the battery or the charger has a problem. Let me know if you need more assistance.
Apr 13, 2011 | Drills
I had a power failure, wiyh power off about 6 hours. Since power ws restored, I hav a low battery alarm for about 3 days. The system is about 11 years old. It currently has a hard-wired rechargeable...
The charge circuit probably only supplies a tiny charge current to prevent overcharging of the main battery and I suspect the original is a NiCad and has likely lost a cell or two (shorted; it's common with them) over that fairly long period.
Replacing it with either Lithium Ion or NiMh rechargeables with a honest voltage rating (*some aren't) is a good move; neither of these are as prone to failure as NiCad is. Don't be surprised if you still have a 'low battery' alert for several days since these batteries rarely have a full charge when shipped.
*So-called '9V' block batteries are, except for rare batteries, actually 8.4 or even only 7.2 volts. I have some instruments that indicate 'Low battery' with either of these even when fully charged.
Apr 08, 2011 | GE Iti Simon Burglar Alarm Home Security...
Nicad battery for makita want charge
For NiCd and NiMH batteries - check the battery voltage (for a good battery it is ~ 19, V); each battery contains 15 units 1.2 V each; you can test each unit after disassembling the battery case (my have 4 screws each, and the case has bottom and top parts). First charge the batteries; second, disassemble cases and check each unit voltage (shouldn't be less than 1.2 V); then take any battery tester (for AA, AAA and other batteries and accus for home usage), attach 2 long (~10 inches) wires to tester's testing contacts, and test each 1.2V unit for current - if it is in "yellow" or "red" zone - the unit is dead and needs replacement
Feb 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Eclipse Hitec 7 will not stop biip when turned on, battery has been charged for 24 hours, it still say low bat on display
Depending on the are and number of charges, the battery is dead. A NiCad battery is only good for about 400 charges. After that, it starts to go downhill. A NiCad battery will also take a memory. If it has the capacity to run for an hour but you only use it for 15 minutes, it will taka on a shorter than 1 hour memory. In time, it will only give you 15 minutes of use, even with a full charge.
Try TOTALLY draining it a few times and then charge it overnight. Do this at least 4 times. This is called reguvenating. About half of the time, it will increase the life of the battery.
Aug 04, 2009 | Eclipse Hitec 7 Fm Computer Aircraft/heli...
Flashing red light on the Kensington wireless mouse base
I still have the manual for my mouse.  Model number 64321.
When this mouse was manufactured it used NiCad batteries which developed a memory much more than the newer batteries.  The older NiCad batteries needed to be conditioned occasionally so Kensington provided a way to do that with the charging base.
The red light is for indicating discharge status of NiCad batteries.
The red light will flash quickly when you press the battery discharge button on the bottom of the base.  This indicates that you now have 5 seconds to place the mouse in the charging base for battery discharge.
The red light will flash flash more slowly when the battery is being discharged.
After the battery is fully discharged, the base will then charge the batteries.
It should be noted that very few manufacturers of products that utilized NiCad batteries provided a "battery conditioning" feature.  Kensington was unique in this regard.  Battery conditioning allowed NiCad batteries to have a longer useful life.
Now maybe you can help me....  I lost my power supply that plugs into the USB connector.  If you have yours, can you tell me what the output voltage is and what the polarity is of the inner pin.  This will be marked right on the power supply base.
I plan to just get a generic power supply from Radio Shack, but I need the voltage value and polarity.  Until then, I can still use the mouse, but it won't charge.  FOr now, I'm just using standard AAA batteries.
Thanks.
bartman9@earthlink.net
Mar 17, 2009 | Kensington StudioMouse Wireless
Midland radio battery pack constant vibrate
Nov 01, 2008 | Midland Radio Communications
Midland gxt-850 gets HOT!
It is very possible that the terminal of the positive end of the bottom battery is shorting to the battery's body hence the heating up. If this is the case, then when you charge the radio, excessive current is flowing since the battery set has one shorted. Again this would cause heat buildup specially on the bottom battery and the charging terminals.
A possible solution is to check the bottom battery's positive terminal and ensure that it only contacts with the positive terminal of the battery and does not touch the battery body (which is negative).
Alternately (and perhaps more to your advantage), seek replacement of the defective unit considering it is new and therefore should be under warranty.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 06, 2007 | Radio Communications
Midland GXT1000VP4  Two Way Radio Logo
27 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
