Question about LG WM1814CW Front Load Washer
My Lg front load washer will not drain. clothes are soaked. showing IE error code
    New Friend:
    Problem Solver:
  • 15 Answers
The problem with air guider,,which is connect with presser sensor,might its block with durty. kindly check &cleand,,,
Posted on Apr 23, 2014
SOURCE: LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Posted on Aug 04, 2008
rickzilla
  • 706 Answers
SOURCE: Getting error code on lg front loader washer
Hello aj546,
Kinda figured there was a miscue there with your error code however... the error code FE refers to the fact that water is overflowing ( normally means the inlet water valve is stuck open and continues to let in water beyond the expected and/or sensed level.. so the water pump turns on to drain it and keep the level down. This kind of problem would probably warrant a aservice call from a tech since the majority of troubleshooting would require diagnosing the failed component itself and is not something that I recommend you try. There are too many pieces of hardware that have a direct impact on how this works and I highly doubt you want to play the shotgun approach..try this to see if it fixes the problem and if not..try that...
Before calling for service.. try this..
remove or disconect ac power from the washer..let it sit unplugged for at least an hour..then try washing 1 towel at the lowest cold water setting to see if that works ..if it does..repeat the process using only hot water.. if that works... then try the same test using warm water.. ( this test may help determine if the water inlet valve .,.either hot or cold is leaking through it)... If you still get the FE test..call for service.. That's the best I can offer via this chanel... BTW..if only one of the two tests fails.. ( Hot water only generates an FE error.. then chances are the hot water inlet solenoid valve assembly is either sticking open or the controls to that are commanding it to remain open... Hope that helped you..'
Regards,
Rick
Posted on Nov 29, 2008
DRACO A5OG
  • 22 Answers
SOURCE: LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Posted on Dec 31, 2008
jgwhomeequip
  • 1902 Answers
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Posted on Feb 10, 2009
rickzilla
  • 706 Answers
SOURCE: LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Posted on Feb 22, 2009
Washer wont drain showin IE
Sonia, you either have a failed drain pump, or something has bypassed the filter ( bobby pins are notorious for this ) and is jamming up the pump impeller. If you can set the washer to drain/spin and can hear the pump running, you most likely have a impeller that has broken off of the pump motor shaft and will need to be replaced. If you cannot hear the pump running, and can hear a slight humming noise, then there is something jammed in the pump. The pump can be removed and cleared of the possible foriegn object. I can provide instructions on pump removal if needed.
Apr 20, 2014 | LG Tromm Front Load Washer And Dryer Set
My clothes were in the washer and when I went down to check there was an error code. LE The clothes were still wet, and appeared to not have gone through the rinse cycle.
The LE is caused by over sudsing OR clothing trapped between the tubs. The LE: hall sensor shorted/destroyed from sudslock or clothes between tub. Correct the issue and party on.
LG errors:
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
LG service manuals and repair notes.
Apr 17, 2011 | LG WM2487H Front Load Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Cycle takes forever
IE is Inlet Error. Turn off the water valves behind the washer and remove the hoses from the machine end. Look inside the spot the hoses were attached to, and use a plier to pull out the screen and clean it out. (probably only need to do the cold side) Re-instert screen(s), re-attach hoses, and turn valves back on. (Also, make sure hoses are not kinked behind machine.) Times displayed are estimates, and vary due to water fill rates, and load type and size. In your case, the water fill rate is the problem.
Jan 25, 2010 | LG WM1814CW Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jul 30, 2008 | LG WD-1045FH Front Load Washer
IE Err
In my LG Manual, They IE error is water inlet trouble.
Possible causes
  • Water supply is not adequate in area
  • water supply taps are not completely open
  • water inlet hose are kinked
  • the filter of the inlet hose are clogged
Solutions
  • Check another tap in the house
  • Fully open tap
  • Straigten hose
  • check the filter of the inlet hose
Not sure if this helps, it's what is says in my book.
Good luck.
May 27, 2008 | LG WM1815CS Front Load Washer
Fixed!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG WM1814CW Front Load Washer Logo
98 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
