Question about LG WM1814CW Front Load Washer
LG trom wASHER wm20160W WONT DRAIN - LG WM1814CW Front Load Washer
  • 957 Answers
Start by getting to the drain on the pump there should be a hose hooked to the pump and there may be a filter that u can clean out. Check the pipe and make sure it is clear and also check the discharge hose to be sure it is clear as well. By the way do u hear the pump come on or try to. If lines are clear and the pump is running then you most likely have a bad pump,
Posted on Apr 21, 2014
4 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Posted on May 06, 2009
localwonder
  • 6784 Answers
SOURCE: IE code keeps coming on, the water wont drain -
HI. This code is in reference to your inlet valve assembly. There may be an obstruction, or the actual inlet assembly may be malfunctioning. Use the procedure below to help guide you through the necessary inspection.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are receiving proper water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
Posted on Apr 22, 2010
  • 91 Answers
SOURCE: My washer isn't working the washer is an LG TROM
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Posted on Sep 03, 2010
How do you clean the drain filter in a lg trom?
How to Clean the Filter on an LG Tromm Washer eHow Follow the preceding link for a really good instruction. I hope this helps you!
Nov 07, 2015 | LG Washing Machines
Lg trom. It says oe
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 13, 2011 | LG Washing Machines
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Aug 28, 2010 | LG WM-2277HW Front Load Washer
Drum will not spin
You will need to change the rotor and stator,
Jul 21, 2010 | LG WM1814CW Front Load Washer
May 06, 2009 | LG WM2277H Front Load Washer
LG Trom wm2077gw OE error code and won't come off and empty macine I washed a comforter and it shredded part of it and is stuck on OE what does this mean and how do I fix it. Thanks
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
May 20, 2008 | LG WD-14124RD Front Load Washer / Dryer
Washer
Anne,
The lint filter is clogged preventing the pump from draining all the water from the tub. Open the little panel on the front lower left of the machine, unscrew the lint filter and clean it. Make sure you drain the trapped water first (before you remove the filter), by pulling out the little rubber hose (you'll see it) and removing the plug from the end.
BW
Apr 02, 2008 | LG WM-2277HW Front Load Washer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
LG WM1814CW Front Load Washer Logo
67 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
