Question about Craftsman sears 18" Chain Saw Chain ( Model 35084 )
Headbolt tension Need headbolt tension
    Problem Solver:
  • 7 Answers
Hi Belinda, I am not sure what you are asking for when you say headbolt. If you mean cylinder bolt, jug bolt or head bolt then
approximately 125 inch pounds.. not foot pounds!!!
This image I found for a Poulan chainsaw site, Poulan makes most of Craftsman saws. If you match the size you should find your torque setting.
jeromekj
Posted on Apr 22, 2014
Have changed cylinder head gasket and need the torque settings for the zd30 nissan engine
try this head torgue link.. that wont highlight
http://www.cylinderheadsaustralia.com.au/torque-settings
the ZD30 is listed half way down the list
and picture of tension sequence
HEAD BOLT TIGHTENING SEQUENCE.
• STEP ONE: 102Nm
• STEP TWO: Loosen All Bolts.
• STEP THREE: 44Nm
• STEP FOUR: +90*
• STEP FIVE: +90*
• IMPORTANT: ALL BOLT THREADS, BOLTHEADS AND WASHERS MUST BE LIGHTLY OILED.
• USING AN OLD HEADBOLT WITH GROOVE CUT DOWN THREAD, CLEAN THE BLOCK HEADBOLT THREADS.
why are these torque setting and sequence
numbers no longer on the VRS head gasket packaging
Oct 28, 2016 | Nissan Cars & Trucks
Where can I get headbolt for ford falcon
What year? What engine? In general, ARP has better than stock headbolts for almost anything.
Oct 19, 2016 | Ford Cars & Trucks
Need head bolts tourqe sequence for a 89 tercel
1989 L4 headbolt sequence:
Cylinder Head Bolt Torque Sequence809142031993 L4 headbolt sequence:
Cylinder Head Bolt Torque Sequence80914199they appear to be the same,other than the torque angle. good luck!
Oct 20, 2011 | 1993 Toyota Tercel
Torque setting for the headbolts on a 106 1.1
While I don't know the exact torque or sequence you can find it in a Chiltons repair manual for the car. Don't waste the money to purchase the book, it's usually available at local public libraries.
Mar 26, 2010 | Raypak HEADER GASKET
Hi im a mechanic... I have a 2000 Deville with a northstar. Radiator, waterpump, thermostat, are all changed and good. There are no external leaks. I heard the Northstar motors have problems with there...
What happens is the head gaskets shrink causing the headbolts to loose torgue, and the headbolts are of one time use, whenever you do a headgasket job you will need to replace all the headbolts with new ones. and when ever you remove a cylinder head on any engine you should always chase the bolt holes with the proper tap, then blow out the holes with compressed air, this will help to insure a more accurate torque setting on the new headbolts...
Oct 01, 2009 | 2001 Cadillac DeVille
My 94 Cadillac DeVille has a coolant problem, what part(s) do I need and on average what would be the cost of part(s) and labor?
If you have a Northstar Engine, sorry to tell you buddy... Either HeadGasket blown, or pulled Headbolts.... Now cadillac repairs these engines for around 3000$ atleast in my area.... You can have a Local mechanic do it, but the headbolts must be Time-Serted http://www.timesert.com/html/gm.html
Jul 08, 2009 | 1995 Cadillac DeVille
Replacing head
There should be 10 headbolts. This vehicle uses torque to yield headbolts and should be replaced with the new gasket. Bolts 1-8 get torqued to 40 ft lbs initially, bolts 9 and 10 get torqued to 30 ft lbs initially, Then all bolts get turned an additional 90 degrees. I would strongly suggest borrowing a torque angle gauge for doing this or you might be doing the same repair next week.
Feb 12, 2009 | 1999 Chevrolet Malibu
What are the torque settings on chevrolet 2000 4.8L headbolts?
Assuming its a smallblock and they have not changed values, for just about forever they have been 65. I'd check a manual or even a dealer... even though they don't give out much info, they will likely tell you that even on phone!
Jan 02, 2009 | 2000 Chevrolet Silverado 1500
Craftsman sears  18" Chain Saw Chain ( Model 35084 ) Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
