Question about Waring WCT708 4-Slice Toaster
Toaster lever stays down. Won't return.
Toaster lever stays in down position and burns toast.
2 Suggested Answers
Ian Prins
  • 11 Answers
SOURCE: toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Posted on Dec 06, 2007
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
Just got 4 slice de longh iconai toaster and husband made toast last night in right hand side. No problem last night but this morning this side will not toast as the lever which one pushes down to keep...
I have no experience with the deLonghi toaster but in my experience automatic toaster all work in similar ways since they went electronic - toasters were about the first to do that.
Pressing the lever down against the spring pressure also presses an internal switch that sends current to the heating element as well as to the electronics that control an electromagnet, the purpose of which is to keep the mechanism engaged until the toast is brown enough and then the current to the magnet will be cut by the browning brain and the toast pops up.
If removing any crumbs from inside by inverting it and giving it a good shake and then pressing the lever a few times fairly vigorously doesn't make it work then nothing short of surgery will make it work so returning it will be the only realistic option.
Aug 22, 2017 | DeLonghi CTO4003 4Slice Toaster
The left side of the toaster does not stay engaged...if I hold it down it heats up but it doesn't stay down ..it doesn't catch.
There are two printed circuit boards inside front of toaster - One PC board for each side. The circuit board on the side that won't latch down in the "toasting" position , is defective. Now, does anyone have access to a schematic for this toaster?
Jul 02, 2011 | Cuisinart CMT-400 Cast Metal 4-Slice...
My toast lever wont stay down-I've loosened the cover and cleaned as best I can. How can I take the lever off so that I can fully remove the cover? It is a Cuisinart two slice black toaster.
On most appliances the knob on the lever pulls off and the cover is then lifted off the lever. Check that the bi-metal strip that latches the toast ejector has not been bent or damaged. Once you have the cover you will be able ot see the whole mechanism.
Jan 26, 2011 | Cuisinart Kitchen Appliances - Others
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
I have a Phillips toaster. It has been working
it sounds like the magnetic coil which holds the lever down to the toast position has burned out. you probably can't get the part for repairing it as it would be too costly
Oct 04, 2009 | Kitchen Appliances - Others
BTA320 bought today. Lever wont stay down to toast.
Since this is brand new, I would suggest return it for a new one.
May 02, 2009 | Kitchen Appliances - Others
Toaster will not stay down in toast position
uh, don't think there's a good chance, you could try to send toaster in for repair, but buying a new toaster is probably cheaper.
Nov 24, 2008 | Back to Basics TEM-500 Egg & Muffin...
Toaster lever wont stay down
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Waring WCT708 4-Slice Toaster Logo
49 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Colin Stickland
Colin Stickland
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
