Question about HP Officejet 7000 Wide Format Printer (C9299A)
Officejet 7000 wide format will not print black ink
I have cleaned the print head and tried 3 different new HP 920XL cartridges
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
  • 5 Answers
SOURCE: Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Posted on Nov 28, 2008
SOURCE: hp officejet 6110 not printing with black ink
I think I know what is the problem. I refilled my black ink cartridge and it printed for a while, but at some point it just stopped working. The head wouldn't touch the paper. Initially I thought the printer had a problem, but then I discovered that the color cartridge still worked.I had a spare new cartridge so I changed it. Everything worked just fine afterwards. My hypothesis is that HP tracks an identifier in the cartridge and does NOT allow you to refill (I even think they simulate for the cartridge to be failing, but I still have to corroborate this). I think this is outrageous and illegal. Please let other people with the same problem know about it. So, the solution is to stop using HP products.
Posted on Dec 05, 2008
ThiruBulls
  • 103 Answers
SOURCE: HP Officejet 7680 is having trouble printing in
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel. # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right). # Continue doing this until it looks clean. # Then dab the cartridge on the towel to make sure the ink is flowing. # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier. 2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Aug 21, 2009
  • 240 Answers
SOURCE: HP L7700 officejet printer leaves streaks on black
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Posted on Nov 28, 2009
Will it fit hp officejet 6500a
No the 92A cartridge will not an OfficeJet.
LaserJet printers take toner which is like a powder, both the toner and the paper are given an electrical charge so the toner will stick to the paper. In the OfficeJet printers the cartridges contain ink which is then sprayed onto the paper much like a spray paint.
The OfficeJet will take No 920XL cartridges.
Mar 17, 2013 | HP C4092A Laserjet 92A Black Print...
Hp 920xl black error
These cartridges can dry up. You can take a tissue and make an impression on the tissue. This will tell you if the cartridge is dryed up or not
Sep 24, 2012 | HP 920XL Black High-Capacity Inkjet...
Black ink will not print on officejet 6500
Replace print head assembly.. P/No: CD868-300018_20_2012_7_36_36_pm.jpg8_20_2012_7_37_03_pm.jpg
Aug 20, 2012 | HP Officejet 6500 Wireless All-in-One...
Hp 7000 won't print A3 paper size
mau nanya gan,printer ane hp k7000 gak mau print a3 tlng beri info gan ?
Feb 24, 2012 | HP Officejet 7000 Wide Format Printer...
Dear sir , i have hp officejet 7000 printer .but it is unable to print & m c y lights are blinking.pls give me solution
printer officejet 7000 ngeblink blog
ngblink berurutan semau chadtr .
akah head ya mati .. mohon petunjuk
Apr 19, 2011 | HP Officejet 7000 Wide Format Printer...
It won't print in black. We have tried 3 differant cartridges. At times it prints a shasding of the image. All the other colors work fine.
Use the HP Printing Assistant software to run a few "print-head-cleaning-cycles".
The BLACK ink-jets are CLOGGED. So, no ink from any of the 3 different cartridges reaches the paper.
Mar 15, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I recently recieved a new 7000 printer. I was not given any directions. The IT department set it all up . They told me it would use the initial ink cartridges pretty quick. On the front of the machine the...
The lights indicate you are out of Magenta and Black ink. Replace the carts. When you purchase them, make sure to buy the XL versions, as they have a much lower cost per page.
Sep 29, 2010 | HP Officejet 7000 Wide Format Printer...
HP will not recognise new cartridge
The problem you are describing with the yellow cartridge sounds like ink starvation possibly due to a clogged print head or an air bubble in the print head. Since the machine is so new I would contact HP to get the print head replaced. As for the magenta cartridge, exchanging it for a new one at the store you bought it from should fix the problem. It sounds like the chip on the one you have is either damaged or wasn't set to read full ink levels.
May 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet 7000 Wide Format Printer (C9299A) Logo
95 people viewed this question
Seeker5211
Seeker5211
